The latest Android app 0.2.232 (7878) seems to have a bug:
Switches do not work from within the "Plans" screen after the app has been force closed.
The switch appears to toggle state momentarily then switch back to the previous state.
Same switch works fine from the "Switches" screen.
Thermostat Set Points work fine from within the "Plans" screen.
This happens on both mine and my wife's phone.
I've tried clearing all the data/cache for the app which did not help.
A workaround does seem to be to go to "Settings" --> "Fetch server configuration".
The switches then work until the next time the app is forced closed.
Switches not working in "Plans" after force close
ChrisKerswell
four2six
Re: Switches not working in "Plans" after force close
I can confirm this, same behaviour here.
Luigi87
Here the same with 3 diffrent devices.
2 times in the lite version.
1 time in the payed version
paolone919191
Same issue here:
seems to be sufficient to open and close the settings menu to fix the issue, until you close the app.
