zwave switch control tasmota switch
Moosjes
Post by Moosjes »
I have a fibaro zwave dimmer 2+ and I would like to have the secondary button of this switch control the state of a tasmota mqtt wifi switch. first push on, second push off. Is this possible without scripts?
jake
Re: zwave switch control tasmota switch
Post by jake »
Yes, by setting the Tasmota switch a slave of the zwave switch. This makes it work one way. Updates on the Tasmota switch won't be copied to the zwave switch setting. Is you want it to work 2-way, you can put in each of the switch settings a Jason command to control the other one. This has been explained in the forum this week, I believe
jake
Post by jake »
Check this post for an example with 2 switches:
https://r.tapatalk.com/shareLink/topic? ... source=app
