NAS Synology shutdown: how to
Number8
Domoticz version: 2022.1
Post by Number8 »
Since most of the Synology NAS API are undocumented I thought it might be interesting to share how to shutdown Synology NAS using dzvents (currently running dzvents 3.0.9). Bare in mind that the user account used to log to the API has to be admin.
In order to have a general understanding of the Synology API, one might refer to https://global.download.synology.com/do ... eb_API.pdf
	active = true, -- optional
		devices = { 423 },
		httpResponses = { 'sid1', 'endOfAction' }
	data = {
		sid1 = { initial = "" },
		message = { initial = "" }
	logging = {
		level = domoticz.LOG_INFO,
		marker = "syno script"
	execute = function(dz, item)
		local _u = dz.utils
		local _h = dz.helpers
		local _d = dz.data
		local _ = dz.utils._
		local function messageAdd (msg, msgNew)
			if msg == "" then
				msg = msgNew
				msg = msg .. "\r" .. msgNew
			return (msg)
		if item.isDevice then
			_d.initialize("sid1")
			_d.initialize("message")
			if item.idx == 423 and item.state == "Off" then
				url= 'http://'.._h.saintPierreNasIP..'/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=2&account='.._h.nasUser..'&passwd='.._h.nasPass..'&session=mySession&format=sid'
				dz.openURL({
           		url = url,
            	callback = 'sid1'
		elseif item.isHTTPResponse then
			if item.trigger == 'sid1' then
				if item.ok then
					if item.isJSON then
						if item.json.success then
							_d.sid1 = item.json.data.sid
							-- send shutdown - for reboot replace shutdown by reboot
							url = 'http://' .. _h.saintPierreNasIP..'/webapi/entry.cgi?api=SYNO.Core.System&version=1&method=shutdown&_sid='.._d.sid1
							dz.openURL({
			           		url = url,
			            	callback = "endOfAction"
						dz.log ("Looging error, cannot get SID")
						dz.devices(423).toggleSwitch().silent()
						-- TBD
						dz.log ("API JSON malformed, cannot get SID")
					dz.log ("Can't connect to NAS - statusCode = " .. item.statusCode .. " | status - " .. item.statusText)
			elseif item.trigger == "endOfAction" then
				if item.ok then
					if item.isJSON then
							dz.log("NAS shutdown initiated")
							dz.log("NAS shutdown failed")
Debian buster on NUC and three RPi with buster.
