fontsize of a block value
rene2716
Post by rene2716 »
I can change the fontsize of a block with custom.css, but it does not change the value fontsize, only the title text of the block.
Any tips or tricks?
tnx in advance
René
hannuf
Re: fontsize of a block value
Post by hannuf »
I am also trying to change font size of value in one block, did you find out how to? or can someone help with this?
hannuf
Post by hannuf »
Found it on other topic, .block_6_3 .title { font-size:12px ; }
webrazor
Post by webrazor »
This worked for me to, but after update to 3.5 it is not working anymore.
Now i use:
.block_78 .value {
	font-size	: 48px!important;
Lokonli
Post by Lokonli »
Is this solved already?
What kind of device is it?
If the above is not working try with:
.block_78 .state{
Lokonli
Post by Lokonli »
webrazor wrote: Sunday 19 July 2020 0:24 This worked for me to, but after update to 3.5 it is not working anymore.
Now i use:
.block_78 .value {
From your other post I guess it's a temperature device. Correct?
On my system with device ID 2 as a temperature device the following is changing the size of the temperature value:
.block_2 .value {
    font-size: 35px!important
However, if you defined a block in CONFIG.js with a custom identifier, then you have to use that identifier as well in custom.css.
So, in case your CONFIG.js contains:
blocks['mytemp'] = {
	idx: 2
then you have to add the following to custom.css:
.block_mytemp .value {
