I am trying to switch from RTF433 to Zigbee.
I am using the cc2531 stick and zigbee2mqtt.
So far I paired an Ikea E1603 wall socket.
That worked after a few tries.
Altough, the router from it appears as,
{"type":"response","requestid":3,"isError":false,"payload":[]}
Last seen:23020-07-31 13:36:44
Type: General, Text
with for me unexplaned text, but it is working.
(in a picture, but I dont know how in insert a picture
Now I paired an Ikea E1743 on/off switch.
So far so good. I can tockel the switch and connect it with blocky to trigger an event.
I like to use only the on/off functions and not the up/down/stop functions of that switch.
Is there a way to disable those three?
I always read about groups with Ikea switches. I don't understand what I have to do with that, why and how to do it.
Anyway, is there someone who works with Zigbee2mqtt and Ikea as well and can give me some advice?
zigbee2mqtt and Ikea
- Domoticz version: 2020.2
Pi3B+ with Domoticz 2020.2, RFXtrx433 USB Firmware 62
Oregon temp. sensors, klikaanklikuit switches
Youless monitor, Samsungtv via SamsungCTL
Speech with HomeBridge, Edomoticz and Homebridge-gsh to Google Home
Zigbee2mqtt and Ikea switches
- heggink
- Domoticz version: 12451
Re: zigbee2mqtt and Ikea
I recently switched from the ikea hub plugin to zigbee2mqtt. I had a couple of issues that I managed to resolve. Let me know if you stiull have problems. If so, read my last posts. If then you still struggle, PM me.
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
- Domoticz version: stable
I think you can simply edit the switch from the dashboard and remove the selector levels.Borderman wrote: ↑Friday 31 July 2020 15:47 Hi
Type: General, Text
