Install stops after Checking for libcurl4
tejano96
Post by tejano96 »
I'm using OSMC in my Raspberry Pi 3 Model B. Below you can find the version used:
AME="OSMC"
VERSION="June 2019"
VERSION_ID="2019.06-1"
ID=osmc
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="https://www.osmc.tv"
SUPPORT_URL="https://www.osmc.tv"
BUG_REPORT_URL="https://www.osmc.tv"
When installing Domoticz with the following command it stops in the check for libcurl4, please see below the printout. Do you know what could be wrong with this?
sudo curl -L https://install.domoticz.com | bash
$ sudo curl -L https://install.domoticz.com | bash
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 16565  100 16565    0     0  51421      0 --:--:-- --:--:-- --:--:-- 51444
::: Script called with non-root privileges. The Domoticz installs server packages and configures
::: system networking, it requires elevated rights. Please check the contents of the script for
::: any concerns with this requirement. Please be sure to download this script from a trusted source.
::: Detecting the presence of the sudo utility for continuation of this install...
::: Utility sudo located.
::: You are root.
bash: line 100: test: 2019.06-1: integer expression expected
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
:::    Checking for apt-utils... installed!
:::    Checking for whiptail... installed!
:::    Checking for git... installed!
:::    Checking for curl... installed!
:::    Checking for unzip... installed!
:::    Checking for wget... installed!
:::    Checking for sudo... installed!
:::    Checking for cron... installed!
:::    Checking for libudev-dev... installed!
:::    Checking for libcurl4..
tejano96
Re: Install stops after Checking for libcurl4
tejano96 wrote: Thursday 18 July 2019 17:44 When installing Domoticz with the following command it stops in the check for libcurl4, please see below the printout. Do you know what could be wrong with this?
the domoticz install scriot recognize this OS as not being jessie or stretch and assumes it's a later version using curl4.
I don't know of domoticz will work on this OS but you can try this
sudo curl -sSL install.domoticz.com > install.sh
sudo sed -i 's/curl4/curl3/g' install.sh
sudo chmod 755 install.sh
sudo ./install.sh
tejano96
Post by tejano96 »
Thanks a lot it worked.
Tejano96
alacran
Domoticz version: 4.10717
Post by alacran »
waaren wrote: Friday 19 July 2019 0:50
sudo ./install.sh
I ve got the same issue.
And when I try the first command, I ve got this issue:
 osmc@osmc:/home$ sudo curl -sSL install.domoticz.com > install.sh
-bash: install.sh: Permission denied
How can I do ?
thank you
alacran
Post by alacran »
My bad, I was in /home and not in /home/osmc
Just saw it when I posted...
thank you :-)
