I have a ZMEEUZBB z-wave controller stick, and the version of OpenZWave that comes with the current Domoticz doesn't work with this stick
Invalid homeid, driver failed to load, etc...
But before I updated I used version 4.10717 which works just fine with it, so I was wondering if there was a download link for a raspberry pi with that specific version ?
(I tried on windows as well, the current version just does not work with this stick, but 10717 does)
Or is there a way to configure the stuck using 4.10717 so it works with the new version ?
Download Raspberry version 4.10717 Topic is solved
danrob21
- Domoticz version: 4.10726
Re: Download Raspberry version 4.10717
Yes same for me. Worked perfectly with 4.10717, but having major issues with latest stable release.
EricHe
I managed to selfcompile from git and get openzwave 1.5 (took a while as first time it compiled without zwave, second time it hard froze inbetween compiling )
Also, to test, I updated the firmware of my z-wave me uzb stick and the newer version now works as well. Still have to do some more test
nschoot
- Domoticz version: 4.11590
I found an old downloaded package with 4.10547... but I updated domoticz already. I usually use the "upgrade" feature within domoticz.
This means that my 4.10717 backupped config is no long compatible with that...
Does anyone have 4.10717 somewhere?
(note that this easy upgrade feature also just installed 2020.2 on my machine without realizing that there are tons of ZWave problems with it)
Using Zwave, Philips Hue, Raspberry Pi, Machinon Theme
nschoot
