Improve my script - array handling...
doh
Post by doh »
I'm creating a script that retrieves a list of devices attached to my router, and checks them against a local persistent dataset - so I can tell when new devices connect to my network, and also so I can use this for local presence detection.
The routine works fine, but I'm not 100% happy with the code. I'm ok with programming, but not an expert on LUA and how it handles tables/arrays.
What I do is to create a local persistent dataset as part of the script:
	data = {
		macs = { initial = {} }
I then receive a JSON file which lists all the devices attached to my router. I iterate through that data set, and check each mac address in the JSON file against the macs dataset above.
At the moment, I'm doing this by having two loops:
			for i in pairs(json) do
				mac = json[i].mac
				for j,regmac in ipairs(domoticz.data.macs) do
					if mac == regmac then ...
I'm convinced that there must be a simpler way - at least to remove the inner loop. I was hoping I could do something like:
if domoticz.data.macs[mac] then...
But that doesn't work.
Any pointers?
Re: Improve my script - array handling...
doh wrote: Wednesday 29 July 2020 11:57 Any pointers?
Can you please share the complete script. It will make it easier to help you.
If you use the script I posted in the other thread as a base it could look like below
return
    on =
        customEvents =
            'JSONFileReady',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Read JSON file',
    data =
		macs =
            initial =
    execute = function(dz, item)
        local function readFile(f)
            local file = io.open (f, "r")
            local data =  file:read("*a")  -- read all
            file:close()
            return data
        --main
        local convertedJSON = dz.utils.fromJSON(readFile(item.data))
	--  dz.utils.dumpTable(convertedJSON)
        for i, record in ipairs(convertedJSON) do
            if dz.data.macs[record.mac] == nil then
                dz.log(record.mac .. ' does not exist as Key in persistent data',dz.LOG_DEBUG)
                dz.data.macs[record.mac] = record
                dz.log(record.mac .. ' does already exist as Key in persistent data',dz.LOG_DEBUG)
        dz.utils.dumpTable(dz.data.macs)
doh
Post by doh »
Thanks - I've sorted it. I'll tidy up my script a bit and then share in case it's of use to others...
