How to check presence of Beacon ?
- Domoticz version: 4.10717
Re: How to check presence of Beacon ?
Nope i didn't.
I'm back to my old system using l2ping ro ping my phone.
RPI3 Raspbian Buster + Domoticz v2020.1 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
- Domoticz version: 2020.2
Raspbian Buster 10
Domoticz 2020.2 (build 12067)
(both fresh new install)
There is a problem with this script:
https://www.domoticz.com/wiki/Presence_ ... _Beacon%29
https://raw.githubusercontent.com/jmleg ... _beacon.py
It gives a fault:
It's also described here:
https://stackoverflow.com/questions/598 ... -python2-7
We don't know what and where the script has to be changed.
Maybe the original script is in the meantime outdated?
Thanks for the support.
PS: this error becomes also for the main script:
https://raw.githubusercontent.com/jmleg ... resence.py
It gives a fault:
sudo python test_beacon.py
File "test_beacon.py", line 31, in <module>
import bluetooth._bluetooth as bluez
File "/usr/local/lib/python2.7/dist-packages/bluetooth/__init__.py", line 282, in <module>
AttributeError: attribute '__doc__' of 'instancemethod' objects is not writable
Python problem is solved.
There is a fault into the Wiki.
Subject: Bluez - the linux bluetooth stack
It installed Bluez also into a wrong directory:
(/usr/local/lib/python2.7/dist-packages/bluetooth)
This has to be;
And beside this, for the modern Raspberry's with standard Bluetooth, this line doesn't have to be installed:
Please could somebody fix the Wiki.
When the version will be higher , you could do a simple :
sudo apt-get install bluez
This has to be;
sudo apt install python-bluez
sudo apt-get install -y libusb-dev libdbus-1-dev libglib2.0-dev libudev-dev libical-dev libreadline-dev
I've just found this thread and found it very interesting.
I have problems with fencing etc and all decent beacon ideas have been very apple orientated
To me the concept of multiple RasPi/BLE boxes dotted about looks quite cool. I'd be interested in being able to recognize the approach of either my wife's car or my own and turn on external lighting and open an electric gate.
I think I'll be buying some NUT tags soon, but what is their range like?
many thanks....
Best Regards:
Jes74,,,
many thanks....
Best Regards:
Jes74,,,
The Official website of Sri Lanka ETA and Sri Lanka Visa Online . Fill the application form for Evisa SriLanka and get Visa online within 24 hours.
Hello Everyone,
Anyone got it working with a Tile Pro ? I know that Tiles are not broadcasting as soon as they've been paired with the app, so I've left them unpaired.
However, they "disappear" after a certain time. They only broadcast back when I push the button (discovery mode).
I also tried to pair them with my raspberry directly, but I got an " org.bluez.Error.AuthenticationFailed" :-/
Anyone has already had presence detection working with Tile pro ?
Thanks in advance
Pat
Thanks in advance
Pat
- Target OS: OS X
- Target OS: OS X
It seems like something weird had happened to my RPi3 and now the service stopped working. It seems to be a bluetooth problem.
I cant run hciconfig anymore. I've reinstalled Bluez. Bluetoothctl gives me an empty row where I cant input anything.
US Travelers planning to visit Sri Lanka can check mandatory information required for applying Sri Lanka Visa for US citizens here.
I used this script python3 script : https://www.domoticz.com/forum/viewtopi ... 13#p234199
for several weeks.
But since some weeks, it doesn't work anymore
When I run beacon.py script, I have this error :
I made no change in domoticz. I still have "4.10717" version.
I only periodically update raspian 9.13.
Can you help me to fix that ?
Thank you
for several weeks.
File "beacon.py", line 148, in <module>
pkt = sock.recv(255)
_bluetooth.error: (32, 'Broken pipe')
Thank you
Apart from detecting Beacon's, does this solution also detect iPhones with bluetooth enabled?
I want to get this feedback before installing and trying. Thanks.
Anybody feedback on my question? In stead of detecting beacons with this solution, can iPhones also be detected? Can somebody confirm?rgroothuis wrote: ↑Wednesday 14 October 2020 22:20 Apart from detecting Beacon's, does this solution also detect iPhones with bluetooth enabled?
hello.
this is so old but works. i use a raspi zero exclusive for this and works fine.
The problem is a "false away". the nut its static near the raspberry and detect HOME but, suddenly it detects a away and after a minute a HOME again.
I think is a problem.
someone have this problem?
nobody use this bluetooth method?
