Router or camera restart
Re: Router or camera restart
cobra045 wrote: Sunday 26 July 2020 15:13 I don't understand, who can explain this to me ??
Check this for a detailed explanation
Or what is the correct rule for this?
$ sudo setcap cap_net_raw = + eip path_to_domoticz_executable
example (my domoticz binary is in /opt/domoticz directory)
sudo setcap -v cap_net_raw+eip /opt/domoticz/domoticz    # returns >>  /opt/domoticz/domoticz: OK
sudo getcap /opt/domoticz/domoticz  #returns >> /opt/domoticz/domoticz = cap_net_raw+eip
cobra045
Domoticz version: 3.4834
Post by cobra045 »
waaren wrote: Sunday 26 July 2020 15:33
Hallo Waaren,
Thanks for this super quick response.
Unfortunately, this information is too much for my limited knowledge.
The question is therefore do I need this for internal use?
I ran a test and it works.
I also looked at the paths on the SD card but can find /opt/ but not /opt/domoticz
Best regards, cobra045
cobra045 wrote: Sunday 26 July 2020 20:13 Unfortunately, this information is too much for my limited knowledge.
It is an explanation for why a non root user should get additional capabilities for certain tasks and an overview of what these capabilities are
If it works and you are OK with not knowing why it works, I am not the person to tell you if you need to understand it or not. There are probably very few people in he world understanding everything there is to know of a system like Linux
See my remark that my domoticz binary is in /opt/domoticz. Youre domoticz binary will most likely in another directory. Most users on a raspberry have installed it in the directory /home/pi/domoticz, but you can install it in any directory.
meyland
Post by meyland »
after running setcap, you need to restart your domoticz service. It took me a while to get it to work, and all I should do was to restart.
@waaren, I'm stille looking into the problem I have with the script.I have create a complete test enviroment, so I think is should be possible for me to finde the cause to the problem. I'm going for a week - so until next weekend .... :-)
regards
Peter
