Ik like to start with colums 3 and 4 at the same hight as colums 1 and 2.
But i tried and empty block title, but a blocktitle without tekst doesn't work…
is there an other sollution to do this?
is it possibility to lower the beginning of columns 3 and 4
NilsNijenhuis
- dashboard.jpg (256.48 KiB) Viewed 351 times
- HansieNL
Re: is it possibility to lower the beginning of columns 3 and 4
I haven’t tried it, but Did you try just a space for the title?
If that doesn’t work you can add a blocktitle and make the blocktitle color transparant via css.
Blah blah blah
NilsNijenhuis
if i use a empty space between the ' ' it doesn't work (see attachment), i will try to make the font of the blocktitle transparent
- dashboard 2.JPG (119.7 KiB) Viewed 312 times
NilsNijenhuis
indeed, maken the font transparent works good, thanks
