Error compare number with nil
kroonp
Post by kroonp »
Hello, a beginners question.
What do I wrong in this script.
I tried several options but I cant find the correct way.
Thanks in advance.
Peter
	active = true,
    	variables =
	    { 'situatie' },
		timer = {
			'every minute'
  execute = function(domoticz, variable)
	      -- variable is the variable that's triggered
        if (variable.value > 0) then
	    domoticz.devices('Keuken').switchOn()
		domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
variable
6 situatie Integer 1 2020-07-23 15:39:00
ERROR:
2020-07-23 16:44:00.524 Error: dzVents: Error: (3.0.9) An error occurred when calling event handler 00 var dag nacht
2020-07-23 16:44:00.524 Error: dzVents: Error: (3.0.9) ...r/scripts/dzVents/generated_scripts/00 var dag nacht.lua:15: attempt to compare number with nil
Re: Error compare number with nil
kroonp wrote: Thursday 23 July 2020 16:51 What do I wrong in this script.
The second parm of the execute function (in your script named variable) will be a variable when the script is triggered by the variable 'situatie' but every minute it will be a timer (trigger is 'every minute')
Regardless of what triggered it, your script tries to access the attribute value which is available for variables but not for a timer.
Try this
return
    active = true,
    on =
        variables =
            'situatie'
        timer =
            'every minute'
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'variable and timer',
        if item.isVariable then
            domoticz.log('Script triggered by variable: "' .. item.name .. '" (value = ' .. item.value .. ')' , domoticz.LOG_DEBUG)
            if item.value > 0 then
				domoticz.log('Value > 0 ==>> switching "keuken" On' , domoticz.LOG_DEBUG)
        elseif item.isTimer then
            domoticz.log('Script triggered by timer: "' .. item.trigger ..'"', domoticz.LOG_DEBUG)
kroonp
Post by kroonp »
I ran the received script. The switch is unfortunately not executed. I don't get an error either. Herewith the log.
2020-07-23 21:01:00.345 Status: dzVents: Info: variable and timer: ------ Start internal script: 00 var dag nacht:, trigger: "every minute"
2020-07-23 21:01:00.345 Status: dzVents: Debug: variable and timer: Script triggered by timer: "every minute"
2020-07-23 21:01:00.345 Status: dzVents: Info: variable and timer: ------ Finished 00 var dag nacht
kroonp wrote: Thursday 23 July 2020 21:06 I ran the received script. The switch is unfortunately not executed. I don't get an error either. Herewith the log.
This is intentional. The light will only be switched when the script is triggered by the variable.
From your script I could not determine what the script should do.
Please describe what you expect from the script when you change the value of the var and what your expectation is when the script is triggered by the timer.
kroonp
Post by kroonp »
Sorry, I didn't know that only changing the variable takes an action. Now that I know that, it is clear to me why the script did not do what I expected. So with your help it is now clear to me and I can move on. Thanks for the support.
