How to install Conbee II on Domoticz? Topic is solved
BarryT
Domoticz version: 2024.3
Post by BarryT »
i'm suffering 2 days with trying to install that Conbee USB stick on domoticz with buster..
But, whatever i'm doing it doesnt want me to install :(
What am i doing wrong?
sudo sh -c "echo 'deb http://phoscon.de/apt/deconz \
            $(lsb_release -cs) main' > \
            /etc/apt/sources.list.d/deconz.list"
give me the lsb_release not found error...?
I did a deb install, but that also didnt work..
It does not open any port and also not start the deconz application.
Grrrrrr, plz help!
Thnxx
thomasbaetge
Domoticz version: 2023.1
Re: How to install Conbee II on Domoticz?
Post by thomasbaetge »
Just follow this sequence here:
https://phoscon.de/de/conbee/install#raspbian
Worked for me. After that you can login to the phoscon web app.
Gesendet von meinem Pixel 4 XL mit Tapatalk
BarryT
Post by BarryT »
thomasbaetge wrote: Monday 20 July 2020 21:34 Just follow this sequence here:
It does not :(
It gives the the "lsb_release not found error" ...?
Thorgal789
Post by Thorgal789 »
And if you make
sudo sh -c "echo 'deb http://phoscon.de/apt/deconz $(lsb_release -cs) main' > /etc/apt/sources.list.d/deconz.list"
If the package method don't work for you, you can just download the file and install it > http://deconz.dresden-elektronik.de/raspbian/beta/
Or with command line
wget http://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb
sudo dpkg -i deconz-latest-beta.deb
sudo apt update
sudo apt install -f
BarryT
Post by BarryT »
It's fixed!
I had to install the lsb-release, after that it worked!
sudo apt-get install -y lsb-release
and after install i did
sudo systemctl enable deconz
Thanks Guys!
Thorgal789
But lsb-release is not by defaut on buster ?
BarryT
Post by BarryT »
Thorgal789 wrote: Tuesday 21 July 2020 16:37 But lsb-release is not by defaut on buster ?
I don't know, it worked:
apt install lsb-release
Reading package lists... Done
Building dependency tree
Reading state information... Done
lsb-release is already the newest version (10.2019051400+rpi1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Linux Version:
Linux 5.4.51-v7+ armv7l
Buster:
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
elmortero
Domoticz version: 3.9639
Post by elmortero »
BarryT wrote: Tuesday 21 July 2020 14:35 and after install i did
That is the one that fixed for me too! Doesn't seem to be in the manual :)
Thorgal789
Depend of the installation, if you use a pre installed image you have nothing to do, else you have 2 modes.
First stop both
sudo systemctl stop deconz-gui
Second disable both, to be sure one is not already actived.
sudo systemctl disable deconz-gui
Then enable the mode you want:
- The headless, if you can't use the desktop
- The Desktop to be able to use the GUI
sudo systemctl enable deconz-gui
jimbou
Post by jimbou »
Next question is : how do I declare the conbee (which is 3 now) in Domoticz ?
I have followed the Phoscon steps to install Decons in my PI5, I have connected my temp/humidity probe to Decons and I can see it working in the Decons GUI interface.
How do I connect Domoticz with all that ?If I go to the Setup -> Hardware menu in Domoticz, I do not see anything saying Conbee, or Decons, or Zigbee. Nor do I see the probe itself.
RNEE
Domoticz version: 2024.7
Post by RNEE »
Domoticz on Docker on Raspberry PI 5 with 500 Gb NvME|Milight|RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya|deCONZ Conbee II| in development Marstek Homebattery 5,12Kwh via Modbus |
Thorgal789
And viewtopic.php?t=25631 if you have problem.
But you have the complete procedure to install the plugin on the previous link.
