Desktop Raspberry Debian Buster deamon (No such file or directory)
mrevil08
Dear All,
I am trying to install Domoticz from scratch and are unable to get it working.
OS: Debian Buster Desktop Raspberry
<<<<Installation is fine with no errors>>>
curl -L https://install.domoticz.com | bash
Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Checking for libcurl4... installed!
::: Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port: 8080
HTTPS Port: 443
<<<Troubleshooting>>>>
Domoticz is not reachable, also not with manual start service with or without root access, i find out daemon wont start, cannot find the file.
i@raspberry:~ $ sudo /etc/init.d/domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Wed 2019-11-27 10:22:52 CET; 1h 5min ago
Docs: man:systemd-sysv-generator(8)
Process: 2689 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Nov 27 10:22:52 raspberry systemd[1]: Starting LSB: Home Automation System...
Nov 27 10:22:52 raspberry domoticz.sh[2689]: start-stop-daemon: unable to start /home/pi/domoticz/domoticz (No such file or directory)
Nov 27 10:22:52 raspberry systemd[1]: Started LSB: Home Automation System.
pi@raspberry:~ $ systemctl daemon-reload
pi@raspberry:~ $ systemctl enable domoticz.service
Failed to enable unit: Unit /run/systemd/generator.late/domoticz.service is transient or generated.
Can anyone help with the installation? my os is up-to-date with apt-get update.
Tryed it many times from scratch with clean OS the installation is not working.
HTTP Port: 8080
HTTPS Port: 443
sgsdebruijn
Re: Desktop Raspberry Debian Buster deamon (No such file or directory)
Same problem here, Buster on Vmware.
Also tried the NTP trick, no solution
with sudo service domoticz status the following,
pi@Vm05Domoticz:~ $ sudo service domoticz status
Active: active (exited) since Thu 2019-12-12 20:06:40 CET; 3s ago
Process: 1385 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Dec 12 20:06:40 Vm05Domoticz systemd[1]: Starting LSB: Home Automation System...
Dec 12 20:06:40 Vm05Domoticz domoticz.sh[1385]: start-stop-daemon: unable to start /home/pi/domoticz/domoticz (No such file or directory)
Dec 12 20:06:40 Vm05Domoticz systemd[1]: Started LSB: Home Automation System.
Do any of you had this issue solved at any point, and how?
I've got the exact same problem and it's driving me mad!
Hey Guys,
I made a guide recently about installing Domoticz on Debian Buster, updated with the latest Domoticz 2020.
I used a virtualised Debian for that, should this be relevant.
Perhaps this can be of use for you:
https://sancla.com/domoticz/domoticz-on ... e-vsphere/
Check these howto's: https://sancla.com
derinus
Same issue here. I reinstalled Domoticz but the error remains.
root@raspberrypi:/home/pi/domoticz# ./domoticz
bash: ./domoticz: No such file or directory
- erem
- Domoticz version: 2021.1
@derinus
did you install domoticz as root?
domoticz installs in the home directory of the user installing the package, almost always username is pi, not root
just my $.02
just my $.02
Regards,
Rob
Rob
derinus
Thanks @erem. I installed in /home/pi/domoticz/ The "domoticz" file exist and are owned by user "pi" (100% sure)
EDIT: Ok I found out what the problem is.
I had switched to a 64-bit kernel (still using 32-bit user libs)
After switching back to the 32-bit kernel and running ./updaterelease every was working fine again!
Raspberry OS 64-bit is still in beta. guess I need to wait installing that as well. I wonder if Domoticz runs on arm64
- erem
@derinus
you can find domoticz compiled for x64 unix (cubie etc) here -> https://domoticaboard.nl/index.php?board=19.0
Regards,
Rob
Rob
- waaren
Yes it does but you have to compile on an arm64 as well.derinus wrote: Tuesday 02 June 2020 19:36 Raspberry OS 64-bit is still in beta. guess I need to wait installing that as well. I wonder if Domoticz runs on arm64![]()
Binaries compiled on arm64 do execute on 32 bits though..
Daniel Pocock, Debian Developer
https://danielpocock.com
