Set dim level on power on
Draakje
Domoticz version: 4.11539
Post by Draakje »
I want to set a specific dim level at a specific time period.
Somehow the device is not acting on the setting.
this is my script
		devices = {
			'Dimmer 1'
	    local dimmer = domoticz.devices('Dimmer 1')
	    local PreviousState = domoticz.variables('Dimmer_1').value
        if ((dimmer.state == 'On') and (PreviousState) == ('Off')) then
            domoticz.variables('Dimmer_1').set('On')
            function timebetween(s,e)
            timenow = os.date("*t")
            year = timenow.year
            month = timenow.month
            day = timenow.day
            s = s .. ":00"  -- add seconds in case only hh:mm is supplied
            e = e .. ":00"
            shour = string.sub(s, 1, 2)
            sminutes = string.sub(s, 4, 5)
            sseconds = string.sub(s, 7, 8)
            ehour = string.sub(e, 1, 2)
            eminutes = string.sub(e, 4, 5)
            eseconds = string.sub(e, 7, 8)
            t1 = os.time()
            t2 = os.time{year=year, month=month, day=day, hour=shour, min=sminutes, sec=sseconds}
            t3 = os.time{year=year, month=month, day=day, hour=ehour, min=eminutes, sec=eseconds}
            sdifference = os.difftime (t1, t2)
            edifference = os.difftime (t1, t3)
            isbetween = false
            if sdifference >= 0 and edifference <= 0 then
                isbetween = true
            return isbetween
            if timebetween("21:30:01","23:59:59") or timebetween("00:00:00","05:50:00") then
                dimmer.switchSelector(70)
        elseif ((dimmer.state == 'Off') and (PreviousState) ~= ('Off')) then
            domoticz.variables('Dimmer_1').set('Off')
When I manually set the level (in domoticz) it does work.
Any pointers?
regards,
Hardware: Raspberry Pi 3, OTGW, 433MHz Superheterodyne 3310 RF Link
Software: Ubuntu 16.04, Domoticz v3.5468, WiringPi, rc-switch
Re: Set dim level on power on
Draakje wrote: Friday 10 July 2020 23:00 I want to set a specific dim level at a specific time period.
Any pointers?
Can you check this?
return
    on =
        devices =
            'Dimmer 1',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'dimmer',
    execute = function(dz, item)
        if item.state ~= 'Off' and dz.time.matchesRule('at 21:30-05:50') then
            item.dimTo(70).silent()
Draakje
Post by Draakje »
waaren wrote: Friday 10 July 2020 23:24
Any pointers?
Can you check this?
return
    on =
        devices =
            'Dimmer 1',
    logging =
        marker = 'dimmer',
Hmm, yes this simplifies my script :)
one problem :) when I change the dim value (manually on switch) is is automatically set back to the value in this script. This is something I want to avoid.
Draakje wrote: Saturday 11 July 2020 9:14 Hmm, yes this simplifies my script :)
Can you check this modified script?
return
    on =
        devices =
            'Dimmer 1',
    logging =
        marker = 'dimmer',
        if item.sValue == 'On' and dz.time.matchesRule('at 21:30-05:50') then
Draakje
Post by Draakje »
waaren wrote: Saturday 11 July 2020 11:22
return
    on =
        devices =
            'Dimmer 1',
    logging =
        marker = 'dimmer',
Same results.
This was the reason I worked with a variable. :)
Draakje wrote: Saturday 11 July 2020 11:26 Same results.
If I test this script on my system (build 12202) it works as you described in your requirement.
What is the domoiticz hardware module, type and subtype of this device? and what do you see in the log if you test the script below? (added some loglines)
return
    on =
        devices =
            'Dimmer 1',
    logging =
        marker = 'dimmer',
	    dz.log('dimmed to 70', dz.LOG_DEBUG)
        dz.log('state: ' .. item.state, dz.LOG_DEBUG)
        dz.log('level: ' .. item.level, dz.LOG_DEBUG)
        dz.log('lastLevel: ' .. item.lastLevel, dz.LOG_DEBUG)
        dz.log('sValue: ' .. item.sValue, dz.LOG_DEBUG)
Draakje
Post by Draakje »
This is what I see in the log (I have tried setting the dimmer higher with the hardware buttons)
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.255  Status: dzVents: Info: Handling events for: "Dimmer 1", value: "On"
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.256  Status: dzVents: Info: dimmer: ------ Start internal script: test: Device: "Dimmer 1 (Virtual)", Index: 180
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.257  Status: dzVents: Debug: dimmer: Constructed timed-command: Set Level 70
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.258  Status: dzVents: Debug: dimmer: Constructed timed-command: Set Level 70 NOTRIGGER
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.259  Status: dzVents: Debug: dimmer: dimmed to 70
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.260  Status: dzVents: Debug: dimmer: state: On
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.261  Status: dzVents: Debug: dimmer: level: 40
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.261  Status: dzVents: Debug: dimmer: lastLevel: 40
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.261  Status: dzVents: Debug: dimmer: sValue: On
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.261  Status: dzVents: Info: dimmer: ------ Finished test
Jul 11 11:40:40 domoticz domoticz[17336]: 2020-07-11 11:40:40.263  Status: EventSystem: Script event triggered: /home/domoticz/domoticz/dzVents/runtime/dzVents.lua
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.971  Status: dzVents: Info: Handling events for: "Dimmer 1", value: "On"
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.971  Status: dzVents: Info: dimmer: ------ Start internal script: test: Device: "Dimmer 1 (Virtual)", Index: 180
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.971  Status: dzVents: Debug: dimmer: Constructed timed-command: Set Level 70
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.971  Status: dzVents: Debug: dimmer: Constructed timed-command: Set Level 70 NOTRIGGER
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.972  Status: dzVents: Debug: dimmer: dimmed to 70
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.972  Status: dzVents: Debug: dimmer: state: On
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.972  Status: dzVents: Debug: dimmer: level: 38
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.972  Status: dzVents: Debug: dimmer: lastLevel: 70
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.972  Status: dzVents: Debug: dimmer: sValue: On
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.972  Status: dzVents: Info: dimmer: ------ Finished test
Jul 11 11:40:44 domoticz domoticz[17336]: 2020-07-11 11:40:44.973  Status: EventSystem: Script event triggered: /home/domoticz/domoticz/dzVents/runtime/dzVents.lua
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.256  Status: dzVents: Info: Handling events for: "Dimmer 1", value: "On"
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.256  Status: dzVents: Info: dimmer: ------ Start internal script: test: Device: "Dimmer 1 (Virtual)", Index: 180
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.256  Status: dzVents: Debug: dimmer: Constructed timed-command: Set Level 70
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.257  Status: dzVents: Debug: dimmer: Constructed timed-command: Set Level 70 NOTRIGGER
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.257  Status: dzVents: Debug: dimmer: dimmed to 70
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.257  Status: dzVents: Debug: dimmer: state: On
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.257  Status: dzVents: Debug: dimmer: level: 38
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.257  Status: dzVents: Debug: dimmer: lastLevel: 70
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.257  Status: dzVents: Debug: dimmer: sValue: On
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.257  Status: dzVents: Info: dimmer: ------ Finished test
Jul 11 11:40:46 domoticz domoticz[17336]: 2020-07-11 11:40:46.259  Status: EventSystem: Script event triggered: /home/domoticz/domoticz/dzVents/runtime/dzVents.lua
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.353  Status: dzVents: Info: Handling events for: "Dimmer 1", value: "On"
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.353  Status: dzVents: Info: dimmer: ------ Start internal script: test: Device: "Dimmer 1 (Virtual)", Index: 180
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.353  Status: dzVents: Debug: dimmer: Constructed timed-command: Set Level 70
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.354  Status: dzVents: Debug: dimmer: Constructed timed-command: Set Level 70 NOTRIGGER
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.354  Status: dzVents: Debug: dimmer: dimmed to 70
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.354  Status: dzVents: Debug: dimmer: state: On
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.354  Status: dzVents: Debug: dimmer: level: 38
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.354  Status: dzVents: Debug: dimmer: lastLevel: 70
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.354  Status: dzVents: Debug: dimmer: sValue: On
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.354  Status: dzVents: Info: dimmer: ------ Finished test
Jul 11 11:40:47 domoticz domoticz[17336]: 2020-07-11 11:40:47.356  Status: EventSystem: Script event triggered: /home/domoticz/domoticz/dzVents/runtime/dzVents.lua
I am using a WF-DS01 dimmer (Tuya) running Tasmota v8.3.1
I did manage to get it to work with a variable like this
return
    on =
        devices =
            'Dimmer 1',
    logging =
        marker = 'dimmer',
        local PreviousState = dz.variables('Dimmer_1').value
        if item.sValue == 'On' and dz.time.matchesRule('at 11:00-12:50') and (PreviousState) == 'Off' then
            dz.variables('Dimmer_1').set('On')
        elseif item.sValue == 'Off' and (PreviousState) ~= 'Off' then
            dz.variables('Dimmer_1').set('Off')
(Don't mind the timeframe. Just changed it for test purposes )
Draakje wrote: Saturday 11 July 2020 11:43 This is what I see in the log (I have tried setting the dimmer higher with the hardware buttons)
OK. Seems your version or your device is reacting different then the ones I use. When I use a virtual dimmer on build 12202 it sets sValue to 'Set Level xx%' when controlled by the dim slider. When I switch it On the sValue is set to 'On' and when I switched it Off the sValue is set to 'Off'.
2020-07-11 11:20:03.406  Status: dzVents: Debug: dimmer: sValue: Off
2020-07-11 11:20:05.183  Status: dzVents: Debug: dimmer: sValue: Set Level: 18 %
2020-07-11 11:20:10.520  Status: dzVents: Debug: dimmer: sValue: Set Level: 44 %
2020-07-11 11:20:11.642  Status: dzVents: Debug: dimmer: sValue: Set Level: 57 %
2020-07-11 11:20:24.762  Status: dzVents: Debug: dimmer: sValue: Off
2020-07-11 11:20:26.256  Status: dzVents: Debug: dimmer: sValue: On
Kind of interesting to find out what is causing this different behavior.
Draakje
Post by Draakje »
Well it is controlled via MQTT and when I change the dim value on the device there is still a power on sent to domoticz (with additional value of the dim level)
I guess this is the trigger..
