I have installed a Qubino mini dimmer, and everytime I switch it from Domoticz, this results in three event triggers instead of one. For instance, if I switch it on, I get three device events (for instance in dzvents)
- First one with state "On" immediately when I turn the switch on
- Another one 800ms later with state "Off"
- Another one 1-2s later with final state "On".
This makes scripting complex and unreliable for advanced scenarios.
I have checked, other module such as Fibaro relays don't have this behavior. Is this something that can be fixed? Do you observe the same on Qubino mini dimmers? Do the Fibaro Dimmer 2 or Aeotec Nano Dimmer have the same issue? (These are the three zwave modules which work without neutral).
Multiple triggers with Qubino mini dimmer
- Domoticz version: 2022.1
Re: Multiple triggers with Qubino mini dimmer
Running latest build on RPi: same issue with nano switch (Z116) from Aeotech and using Aeotech Gen 5 controller. Starting point: widget state OFF, relay OFF > click > Relay ON and widget goes ON and stays ON or most of time widget goes ON a very short period of time and goes OFF (relays stays ON). The opposite is true as well. Any clue? Could it be a bug? I tend to stay away from zwave it is always a pain to setup. I have two others devices (Qubino) that work very well though.
Thank you
Thank you
Debian buster on NUC and three RPi with buster.
