I am looking for the way to script 'Sun at South' in dzVents.
In the switches it is available, but in Lua I can't find the way to code.
The 'at daytime' is already a between and not a time value.
Do a overlook something, or is it possible to calculate with times like :
(between (sunset + sunrise) / 2 and sunset)
Sun at South
bagheerahans
- Domoticz version: V4.9700
- waaren
Re: Sun at South
You could usebagheerahans wrote: Tuesday 07 July 2020 18:57 I am looking for the way to script 'Sun at South' in dzVents.
return
on =
timer =
'every minute'
execute = function(dz)
local function minutesToTime(minutes)
local h = math.floor(minutes / 60)
local hh = ('0' .. h):sub(-2)
local mm = ('0' .. minutes - (h * 60)):sub(-2)
return hh .. ':' .. mm
dz.log("Sun at South is " .. minutesToTime(_G.timeofday.SunAtSouthInMinutes) )
}Debian buster, bullseye on RPI-4, Intel NUC.
hestia
- Domoticz version: 2022.1
Re: Sun at South
You could use a script that give solar data like
https://www.domoticz.com/forum/viewtopi ... 72&t=19220
the south is Azimuth = 180°. You could trigger the device
I did a simplified version without link to a weather site
You can simplify to remove the lux part if you want
Prerequisites
Requires dz v3.8551 or later
2 sensors with Cloud Cover and Pressure updated
Virtual Lux sensor and other real-time solar data
-- Authors ----------------------------------------------------------------
V1.0 - Sébastien Joly - Great original work
V1.1 - Neutrino - Adaptation to dz
V1.2 - Jmleglise - An acceptable approximation of the lux below 1° altitude for Dawn and dusk + translation + several changes to be more userfriendly.
V1.3 - Jmleglise - No update of the Lux data when <=0 to get the sunset and sunrise with lastUpdate
V1.4 - use the API instead of updateDevice to update the data of the virtual sensor to be able of using devicechanged['Lux'] in our scripts. (Due to a bug in dz that doesn't catch the devicechanged event of the virtual sensor)
V1.5 - xces - UTC time calculation.
V2.0 - BakSeeDaa - Converted to dzVents and changed quite many things.
V2.4.1-DarkSky - oredin - Use Dark Sky API instead of WU API
V x.x - SolarData_V0 by hestia - sources independent: use sensor with input values for CloudCover and Pressure
06/11/2019 - Function math.pow(x, y) has been deprecated in Lua 5.3. Please consider changing code to x^y
-- Variables to customize ------------------------------------------------
-- Dummy devices to create
local idxSolarAzimuth = 337 -- (Integer) Virtual Azimuth Device ID
local idxSolarAltitude = 338 -- (Integer) Your virtual Solar Altitude Device ID
-- dz devices to get data
-- local idxCloudCover = 309 -- (Integer) dz Cloud Cover (custom sensor device ID)
-- local idxCloudCoverPerCent = 339 -- (Integer) dz Cloud Cover (percentage device ID) => to choose the one you want
local idxOkta = 442 -- (Integer) (Custom) sensor device ID
local idxPressure = 303 -- (Integer) Your Pressure Device ID
-- dz devices to save result
local idxLux = 305 -- (Integer) dz virtual Lux device ID
local idxSolarRadiation = 304 -- (Integer) dz virtual Solar Radiation device ID
local fetchIntervalDayMins = 5 -- Day time scraping interval
local fetchIntervalNightMins = 15 -- Night time scraping interval
local latitude = 51.748485 -- Latitude. (Decimal number) Decimal Degrees. E.g. something like 51.748485
local longitude = 5.629728 -- Longitude. (Decimal number) Decimal Degrees. E.g.something like 5.629728.
local altitude = 100 -- Altitude. (Integer) Meters above sea level.
-- There is no simple conversion...it depends on the wavelength or color of the light
-- However, for the SUN, there is an approximate conversion of 0.0079
-- Lux.http://bccp.berkeley.edu/o/Academy/workshop_09/pdfs/InverseSquareLawPresentation.p
local LuxToWm2 = 0.0079
local scriptVersion = '2.4.1'
active = true,
logging = {
level = domoticz.LOG_ERROR, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level -- LOG_ERROR for normal execution
devices = {idxOkta, idxPressure},
-- timer = {
-- 'every '..tostring(fetchIntervalDayMins)..' minutes at civildaytime',
-- 'every '..tostring(fetchIntervalNightMins)..' minutes at civilnighttime',
execute = function(dz, item, triggerInfo)
_G.logMarker = dz.moduleLabel -- set logmarker to scriptname
local LOG_LEVEL = dz.LOG_INFO -- LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE -- LOG_INFO for normal execution
local function leapYear(year)
return year%4==0 and (year%100~=0 or year%400==0)
local arbitraryTwilightLux = 6.32 -- W/m² egal 800 Lux (the theoritical value is 4.74 but I have more accurate result with 6.32...) /!\
local constantSolarRadiation = 1361 -- Solar Constant W/m²
local relativePressure = dz.devices(idxPressure).barometer -- from dz sensor updated with other script or a sensor
local year = os.date('%Y')
local numOfDay = os.date('%j')
local nbDaysInYear = (leapYear(year) and 366 or 365)
local angularSpeed = 360/365.25
local declination = math.deg(math.asin(0.3978 * math.sin(math.rad(angularSpeed) *(numOfDay - (81 - 2 * math.sin((math.rad(angularSpeed) * (numOfDay - 2))))))))
local timeDecimal = (os.date('!%H') + os.date('!%M') / 60) -- Coordinated Universal Time (UTC)
local solarHour = timeDecimal + (4 * longitude / 60 ) -- The solar Hour
local hourlyAngle = 15 * ( 12 - solarHour ) -- hourly Angle of the sun
local sunAltitude = math.deg(math.asin(math.sin(math.rad(latitude))* math.sin(math.rad(declination)) + math.cos(math.rad(latitude)) * math.cos(math.rad(declination)) * math.cos(math.rad(hourlyAngle))))-- the height of the sun in degree, compared with the horizon
local azimuth = math.acos((math.sin(math.rad(declination)) - math.sin(math.rad(latitude)) * math.sin(math.rad(sunAltitude))) / (math.cos(math.rad(latitude)) * math.cos(math.rad(sunAltitude) ))) * 180 / math.pi -- deviation of the sun from the North, in degree
local sinAzimuth = (math.cos(math.rad(declination)) * math.sin(math.rad(hourlyAngle))) / math.cos(math.rad(sunAltitude))
if(sinAzimuth<0) then azimuth=360-azimuth end
local sunstrokeDuration = math.deg(2/15 * math.acos(- math.tan(math.rad(latitude)) * math.tan(math.rad(declination)))) -- duration of sunstroke in the day . Not used in this calculation.
local RadiationAtm = constantSolarRadiation * (1 +0.034 * math.cos( math.rad( 360 * numOfDay / nbDaysInYear ))) -- Sun radiation (in W/m²) in the entrance of atmosphere.
-- Coefficient of mitigation M
local absolutePressure = relativePressure - dz.utils.round((altitude/ 8.3),1) -- hPa
local sinusSunAltitude = math.sin(math.rad(sunAltitude))
local M0 = math.sqrt(1229 + (614 * sinusSunAltitude)^2) - 614 * sinusSunAltitude
--print ("MO= " .. M0)
local M = M0 * relativePressure/absolutePressure
dz.log('triggerInfo: ' .. triggerInfo.type, dz.LOG_INFO)
dz.log('', dz.LOG_INFO)
dz.log('============== SUN LOG ==================', dz.LOG_INFO)
dz.log('Latitude: ' .. latitude .. ', Longitude: ' .. longitude, dz.LOG_INFO)
dz.log('Home altitude = ' .. tostring(altitude) .. ' m', dz.LOG_INFO)
dz.log('Angular Speed = ' .. angularSpeed .. ' per day', dz.LOG_INFO)
dz.log('Declination = ' .. declination .. '°', dz.LOG_INFO)
dz.log('Universal Coordinated Time (UTC) '.. timeDecimal ..' H.dd', dz.LOG_INFO)
dz.log('Solar Hour '.. solarHour ..' H.dd', dz.LOG_INFO)
dz.log('Altitude of the sun = ' .. sunAltitude .. '°', dz.LOG_INFO)
dz.log('Angular hourly = '.. hourlyAngle .. '°', dz.LOG_INFO)
dz.log('Azimuth of the sun = ' .. azimuth .. '°', dz.LOG_INFO)
dz.log('Duration of the sun stroke of the day = ' .. dz.utils.round(sunstrokeDuration,2) ..' H.dd', dz.LOG_INFO)
dz.log('Radiation max in atmosphere = ' .. dz.utils.round(RadiationAtm,2) .. ' W/m²', dz.LOG_INFO)
dz.log('Local relative pressure = ' .. relativePressure .. ' hPa', dz.LOG_INFO)
dz.log('Absolute pressure in atmosphere = ' .. absolutePressure .. ' hPa', dz.LOG_INFO)
dz.log('Coefficient of mitigation M = ' .. M ..' M0 = '..M0, dz.LOG_INFO)
local okta = dz.devices(idxOkta).state
--print('okta: ' .. okta)
local Kc = 1-0.75*((okta/8)^3.4) -- Factor of mitigation for the cloud layer
--print('Kc= ' .. Kc)
local directRadiation, scatteredRadiation, totalRadiation, Lux, weightedLux
if sunAltitude > 1 then -- Below 1° of Altitude , the formulae reach their limit of precision.
directRadiation = RadiationAtm * (0.6^M) * sinusSunAltitude
--print ("directRadiation= " .. directRadiation)
scatteredRadiation = RadiationAtm * (0.271 - 0.294 * (0.6^M)) * sinusSunAltitude
--print ("scatteredRadiation=" .. scatteredRadiation)
totalRadiation = scatteredRadiation + directRadiation
Lux = totalRadiation / LuxToWm2 -- Radiation in Lux. 1 Lux = 0,0079 W/m²
weightedLux = Lux * Kc -- radiation of the Sun with the cloud layer
elseif sunAltitude <= 1 and sunAltitude >= -7 then -- apply theoretical Lux of twilight
directRadiation = 0
scatteredRadiation = 0
arbitraryTwilightLux=arbitraryTwilightLux-(1-sunAltitude)/8*arbitraryTwilightLux
totalRadiation = scatteredRadiation + directRadiation + arbitraryTwilightLux
elseif sunAltitude < -7 then -- no management of nautical and astronomical twilight...
directRadiation = 0
totalRadiation = 0
Lux = 0
weightedLux = 0 -- should be around 3,2 Lux for the nautic twilight. Nevertheless
weightedLux = dz.utils.round(weightedLux,0)
totalRadiation = dz.utils.round(totalRadiation,0)
-- dz.log('CloudCover = '.. dz_cloudCover, dz.LOG_INFO)
dz.log('Okta = '.. okta, dz.LOG_INFO)
dz.log('Kc = ' .. Kc, dz.LOG_INFO)
dz.log('Direct Radiation = '.. dz.utils.round(directRadiation,0) ..' W/m²', dz.LOG_INFO)
dz.log('Scattered Radiation = '.. dz.utils.round(scatteredRadiation,0) ..' W/m²', dz.LOG_INFO)
dz.log('Total radiation = ' .. totalRadiation ..' W/m²', dz.LOG_INFO)
dz.log('Total Radiation in lux = '.. dz.utils.round(Lux,0)..' Lux', dz.LOG_INFO)
dz.log('Radiation through cloud layer = '.. weightedLux..' Lux', dz.LOG_FORCE)
-- No update if Lux is already 0. So lastUpdate of the Lux sensor will keep the time when Lux has reached 0.
-- (Kind of timeofday['SunsetInMinutes'])
if dz.devices(idxLux).lux + weightedLux > 0 then
dz.devices(idxLux).updateLux(weightedLux)
dz.devices(idxSolarAzimuth).updateCustomSensor(dz.utils.round(azimuth,0))
dz.devices(idxSolarAltitude).updateCustomSensor(dz.utils.round(sunAltitude,0))
dz.devices(idxSolarRadiation).updateRadiation(totalRadiation)
bagheerahans
Re: Sun at South
Thanks for the first step.
To make the on timer, I want to make a time scope.
Therfore, is the 'timeofday['SunAtSouthInMinutes']' compatible with the 'between aa and bb' ?
- waaren
Re: Sun at South
This is not implemented yet. Will have a look over the next couple of days if it can be made part of the dzVents framework like sunset and sunrise without too much hassle.bagheerahans wrote: Tuesday 07 July 2020 20:21 Thanks for the first step.
- waaren
Re: Sun at South
Implemented in build 12213 (dzVents 3.0.11) as solarnoonbagheerahans wrote: Tuesday 07 July 2020 20:21 Thanks for the first step.
Therefore, is the 'timeofday['SunAtSouthInMinutes']' compatible with the 'between aa and bb' ?
(Thx to @dannybloe we are inclusive to domoticz users from the southern hemisphere
bagheerahans
Re: Sun at South
I upgrade to beta version (without any problem). And start using solarnoon.
Works good! Thanks.
My roller blind are now running with:
ZomerStandGordijn is a switch, so it can be overruled, which is set by the average of solar radiation and a value with hysteresis.
Works good! Thanks.
devices = {'Gordijn voor', 'Gordijn achter', 'ZomerStandGordijn'},
timer = {'at solarnoon'} },
logging = {level = domoticz.LOG_DEBUG, marker = "Gordijn4"},
if (device.isTimer or device.name == 'ZomerStandGordijn') then
if (domoticz.time.matchesRule('between solarnoon and sunset') and domoticz.devices('ZomerStandGordijn').state == 'On') then
domoticz.devices('Gordijn voor').switchSelector(20).afterSec(60)
domoticz.log("Gordijn voor dicht")
if (device.name == 'ZomerStandGordijn') then
if (domoticz.time.matchesRule('between solarnoon and sunset') and domoticz.devices('ZomerStandGordijn').state == 'Off') then
domoticz.devices('Gordijn voor').switchSelector(10)
domoticz.log("Gordijn voor open")
if(device.name == 'Gordijn voor' and device.state == 'Off') then
domoticz.openURL('http://192.168.2.125/control?cmd=relay,0,0')
domoticz.openURL('http://192.168.2.125/control?cmd=relay,1,0')
if(device.name == 'Gordijn voor' and device.state == 'Open') then
domoticz.openURL('http://192.168.2.125/control?cmd=relay,0,1')
domoticz.devices('Gordijn voor').switchOff().afterSec(60)
if(device.name == 'Gordijn voor' and device.state == 'Dicht') then
domoticz.openURL('http://192.168.2.125/control?cmd=relay,1,1')
if(device.name == 'Gordijn achter' and device.state == 'Off') then
domoticz.openURL('http://192.168.2.125/control?cmd=relay,2,0')
domoticz.openURL('http://192.168.2.125/control?cmd=relay,3,0')
if(device.name == 'Gordijn achter' and device.state == 'Open') then
domoticz.openURL('http://192.168.2.125/control?cmd=relay,2,1')
domoticz.devices('Gordijn achter').switchOff().afterSec(60)
if(device.name == 'Gordijn achter' and device.state == 'Dicht') then
domoticz.openURL('http://192.168.2.125/control?cmd=relay,3,1')
}Who is online
