script to take screenshot every hour
judaca
Post by judaca »
Hello, can anyone help me ? I have a (working) Bash Shell Script to take a snapshot of an ONVIF camera. When i launch te script
at the command prompt in using "bash script.sh" it works perfect and saves the picture in the specified directory as photo.jpg with
as owner "pi" and rights "rwxr-xr-x" what is perfect for me !
To run the script every hour in Domoticz i call the script.sh using a Blocky script or dzVents script (i tried both). This also works, but
the wile is saved in de specified directory with other rights and owner !! Owner is "root" and permissions "rw-r-----". So i can't copy them,
can't change te permissions etc....
Anybody knows what the reason for this is or how i can solve this ?
breizhcat
Re: script to take screenshot every hour
Post by breizhcat »
I guess that the user used by domoticz to run is root. You can change the rights at the end of your scripts and the owner too with chmod and chown.
Btw, is it possible to share your script i'm interested by this idea.
Envoyé de mon Mi 9T Pro en utilisant Tapatalk
judaca
Post by judaca »
This is the code i use in the bash script :
#!/bin/sh
export DATETIME=`date +%Y%m%d%H%M%S`
ffmpeg -loglevel fatal -i rtsp://192.168.1.19:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream -vframes 1 -r 1 /home/pi/Pictures/$DATETIME.jpg
Can you help me how i can change the owner and permissions ? What do i have to add ? I'm a "newbie"
breizhcat
Post by breizhcat »
Thanks I will test it with my cameras
judaca
Post by judaca »
can you tell me what i need to change or add ?
breizhcat
Post by breizhcat »
For me you have to add these 2 lines. 1st allow you to change the owner of the file and 2nd change the auth on the file.
chown user:group your_file
chmod 755 your_file
judaca
Post by judaca »
Thanks ! It works now !
judaca
Post by judaca »
BTW how do you do that to set code in a window here on forum like you did with the things i need to ad ?
breizhcat
Post by breizhcat »
With the bbcode like xml tag but between [. You have to open the tag code put your code and close it.
judaca wrote: Tuesday 07 July 2020 18:25 BTW how do you do that to set code in a window here on forum like you did with the things i need to ad ?
By using the button
code button.PNG (37.32 KiB) Viewed 1461 times
