unexpected symbol near '}'  [Solved]
Varazir
Post by Varazir »
I get the greatest error of them all 24: unexpected symbol near '}'
The last line of the script.
Only think I'm not sure about is the array.
        devices = {
            'IKEA - Sensor Hall',
    execute = function(dz, item)
    local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_MODULE_EXEC_INFO)
    local lampgroup = devices(203)
    local lamparray = { 172, 180, 182, 186 }
    if (time.isDayTime) then
        for device in lamparray do
            device.dimto(60)
            device.dimto(100)
I need to add if ON and if OFF as well.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Re: unexpected symbol near '}'
Varazir wrote: Thursday 02 July 2020 14:38 I get the greatest error of them all 24: unexpected symbol near '}'
Could look like
return
    on =
        devices =
        local lampgroup = dz.devices(203)
        local dimLevel = 100
        if dz.time.isDayTime then
            dimLevel = 60
        for _, idx in ipairs(lamparray) do
            dz.devices(idx).dimTo(dimLevel)
Varazir
Post by Varazir »
waaren wrote: Thursday 02 July 2020 15:12
Could look like
return
    on =
        devices =
            dimLevel = 60
            dz.devices(idx).dimTto(dimLevel)
I added a ON and OFF if statement as well.
No errors so I hope it will work.
return
    on =
        devices =
    execute = function(dz, device)
            dimLevel = 60
        if device.state == 'ON' then
                dz.devices(idx).switchOff()
Re: unexpected symbol near '}'  [Solved]
Varazir wrote: Thursday 02 July 2020 16:00 No errors so I hope it will work.
Probably not because state 'ON' is not likely to happen. (most devices report either 'On' or 'Off')
because dimTo(0) is an implicit switchOff() you could do
return
    on =
        devices =
        if device.state ~= 'On' then
            dimLevel = 0
        elseif dz.time.isDayTime then
            dimLevel = 60
Varazir
Post by Varazir »
waaren wrote: Thursday 02 July 2020 16:10
return
    on =
        devices =
            dimLevel = 0
            dimLevel = 60
I'm getting
2020-07-02 17:21:41.597 (zigbee2mqtt) MQTT message: zigbee2mqtt/IKEA - Sensor Sovrum {'requested_brightness_level': 254, 'requested_brightness_percent': 100, 'linkquality': 68, 'occupancy': True, 'update_available': False}
2020-07-02 17:21:44.354 (zigbee2mqtt) MQTT message: zigbee2mqtt/IKEA - Sensor Hall {'occupancy': True, 'linkquality': 39, 'update_available': False, 'battery': 47}
2020-07-02 17:21:44.588 Error: dzVents: Error: (3.0.9) An error occurred when calling event handler IKEA - Sensor Hall
2020-07-02 17:21:44.588 Error: dzVents: Error: (3.0.9) ...scripts/dzVents/generated_scripts/IKEA - Sensor Hall.lua:17: attempt to call a nil value (global 'devices'
Varazir
Post by Varazir »
I'm removing line 17
Varazir
Post by Varazir »
I'm getting
2020-07-02 19:41:15.233 Error: dzVents: Error: (3.0.9) An error occurred when calling event handler IKEA - Sensor Hall
2020-07-02 19:41:15.233 Error: dzVents: Error: (3.0.9) ...scripts/dzVents/generated_scripts/IKEA - Sensor Hall.lua:30: attempt to call a nil value (field 'dimto')
Varazir wrote: Thursday 02 July 2020 19:42 I'm getting
it's dimTo
Varazir
Post by Varazir »
I think I found it, typo on the variable, it was dimlevel in the daytime and dimLevel in the rest of the script
