Dividing  [Solved]
Varazir
Dividing
Post by Varazir »
I hade a script that worked when I created it ( some time ago ) isn't working now.
I found a workaround.
When I created the script the value I got when I used this was 1 ( if selector.level = 10 )
selectedGroupNumber = selector.level/10
But now I get 1.0
Is that work as design or a bug ?
Workaround was to use 10, 20, 30 in the script rater then 1, 2, 3
TIA
Daniel
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Re: Dividing  [Solved]
Varazir wrote: Wednesday 01 July 2020 15:03 When I created the script the value I got when I used this was 1 ( if selector.level = 10 )
But now I get 1.0
This is because of the change to Lua 5.3 in domoticz V4.11439. In Lua 5.3 a division of two integers result in a float.
If you need it to be an integer you can use
math.floor( selector.level / 10 )
Varazir
Re: Dividing
Post by Varazir »
Thanks then I know it was a change caused it. Well as I said I made it work without division.
