i have a nodemcu(running espeasy) with a INA219 between my 12v10w solar panel(will be upgraded) to a 1,5Kwh battery(3s60p off 18650cells). The INA219 give the Volts, amps and power, nicely logging to domoticz both directions.
Is there a way to create a percetage in domoticz on how full the battery is?
thanks before hand.
Battery percentage
Re: Battery percentage
How is your nodemcu logging to Domoticz?
What I ment was, do you use HTTP of MQTT.
You could use an Analog input with a resistance divider and/or some calculation rule to get the percentage and put that to a dummy sensor.
Or if you want that battery level in one or all of the devices use MQTT and NodeRed and combine all values with battery level to push it to Domoticz MQTT. You can do the calculation in NodeRed.
- Domoticz version: 2020.2
sorry, i use HTTP. never used nodred before so i will give it a try.
