Venetian EU Blinds
bokan20
Venetian EU Blinds
Post by bokan20 »
I have a problem with setting blinds. I can not set "Venetian EU" switch. Attach an image to see how I set it up...
emme
Domoticz version: latest
Re: Venetian EU Blinds
Post by emme »
try with ON/OFF instead of Open/Close
"We always done this way"
bokan20
Post by bokan20 »
I tried that. I forgot to mention :(
emme
Post by emme »
can you describe a bit better the hardware type of the switches and blind?
bokan20
Post by bokan20 »
Of course,
the device i use for the relay is:
https://denkovi.com/smartden-lan-ethern ... n-rail-box
The electric motor for the blinds is classic 230V. Pictures below...
emme
Post by emme »
mmh ok...
let's resume...
The 2 relays that operate the motor are NOT a rolling shutter device, but a 2 relay manually (and indipendently) operated....
So... it must be clear that ALL the times you act a movement you MUST deny the other movement:
if you want to go UP you have to open the down contact anche close the open one for a certain amount of time (do NOT leave it closed!!!)
if you want to go DOWN you have to open the up contact anche close the down one for a certain amount of time (do NOT leave it closed!!!)
more... the venetian blind device is a virtual device, not really connected to anything.. correct?
so.. all the time you press the ventian UP/DOWN you have to operate as per upper description (you would have a script running for that)
you have problems operating the venetian (virtual) switch right?
if so... I'll make a try to replicate the scenario... I'll shortly will be in the same situation between a virtual blind object and a KNX shutter device, so it would be almost the same!
ciao
M
bokan20
Post by bokan20 »
Emma thanks for your suggestions. This morning I wiped out the "Switch, blockly" ... and now I'm working the blind switch.
Switch
Testing...
Off reley
Can you help me to do ON or OFF with the "script" to run from BLOCKY ???
clemberto
Post by clemberto »
sorry for digging up the thread, but I have almost same hardware setup, and there is a possibility my Blind motor gets power on its 2 phases (Up and Down command simultaneously).
What is the effect of this on blind motor? Is there any protection inside the blinds?
Call me not brave enough to test it myself, but I have a quite huge blind at home; any maintenance on it would be painful.
If anyone has some knowledge...
