VLC media player in command line URL HTTP ?
cyberbob69
Post by cyberbob69 »
I just tested this to change the volume:
http://192.168.1.1:8080/requests/status.json?command=volume&val=200
with the ip where vlc is executed, and val of value 0 to 256 corresponds to the volume from 0 to 100%
On the other hand during the first connection, VLC requests a password (without user name), to define in advanced preference / main interface / Lua / Lua by HTTP
So there is a window that opens to authenticate and put the password in it, of course you would have to put this password in the URL link, I tried this syntax but it does not work:
http://[email protected]:8080/requests/status.json?command=volume&val=200
Do you have any idea why ??
Domoticz Stable V4.9700 on Synology DSM 6.2 / 2xRFlink V48.4 - 433.92 & 433.42 MHz / Script in LUA & Blocky
erem
Domoticz version: 2021.1
Re: VLC media player in command line URL HTTP ?
Post by erem »
just a guess, but the http syntax is
http://username:[email protected]/
if you only need the password send, would it be
http://:[email protected]:8080/requests/status.json?command=volume&val=200
just my $.02
Regards,
Rob
cyberbob69
correct syntax :
os.execute('curl -u :password "http://192.168.1.5:8080/requests/status.xml?command=volume&val=256" ')
Request http for VLC :
https://wiki.videolan.org/VLC_HTTP_requests/
