Hey guy’s,
I have some strange behavior with my site, and I have the idea that’s related to dZventz.
Several times a week when a group of lights is dimmed or switched the action is reverted in exact 5 seconds!
Sometimes is the action “switch off” reverted after 5 seconds in “switch on”. Sometimes from “ dim to 40%” in the state before “dimmed to 80%”.
I see in the logging from the device two triggers within 5 seconds?
Not always the same devices, not always from a group. But ALWAYS after an action from DZVents.
Can someone give me an hint?
Thanks in advance, Martin
Action reversed within 5 seconds
MartinManders
- Domoticz version: 2023.2
- Reliability means:
never have to say i am sorry -
Rpi's 3B 1x RFX com + 20 dev 1x ZWave + 130 dev + rpi 4 remote
- waaren
Re: Action reversed within 5 seconds
If you suspect dzVents then a start to find a root cause would be to disable dzVents. If the problem does no longer occur after disabling dzVents then start dzVents with full debug logging and disable all dzVents script except one. Enable the other scripts one by one until you find which script is causing the issueMartinManders wrote: Saturday 20 June 2020 0:26 I have some strange behavior with my site, and I have the idea that’s related to dzVents.
MartinManders
Hi Waaren,
Thanks for your quick reply.
I guess I wasn’t clear enough;-)
This only happens when a device is started, stopped or changed trough a command from dzVents. All other devices for example controlled by the timers no problems.
I’ll try the debugging option. It occurs nevertheless with several different scripts. The only constant is the 5 seconds?
