How to install Domoticz on a Synology NAS
tof92130
Re: How to install Domoticz on a Synology NAS
Post by tof92130 »
Thank's ! It works great
johnnyboy1984
Post by johnnyboy1984 »
Unfortunatly i removed my z-wave stick from the hardware excedently and all my z-wave devices are gone :( .
Since there is a new update perhaps a good time to install 2020.1 right?
But what is/are the 'critical bug(s)' that are fixed in 2020.2 exaclty and what could be the problems if i install 2020.1?
alkempter
Domoticz version: 2022.2
Post by alkempter »
johnnyboy1984 wrote: Monday 25 May 2020 11:20 Unfortunatly i removed my z-wave stick from the hardware excedently and all my z-wave devices are gone :( .
But what is/are the 'critical bug(s)' that are fixed in 2020.2 exactly and what could be the problems if i install 2020.1?
from my personal experience I cannot recommend 2020.1, I only had troubles with zWave devices and some minor with the LUA scripts (different level of underlying programming language). I have to admit, that I can live with the errors I constantly get, and that I changed my coding around the Aeotec motion sensor.
As it seemed uncertain when we can expect 2020.2 on Synology, I made a try with Raspbery PI with level 2020.2 and I saw no change in the behavior of my devices and LUA scripts from 2020.1 to 2020.2
The main problem with the 2020 levels seems to be the new level of OpenZwave. I also did not really see any activity on the forum toward a solution of those problems.
But moving to 2020.1 now will give you a better position once the fixes come out: you will already have adapted your scripts to the new software level (if necessary) and you will see the new abilities of your sensors that come with the new OZW level. Meanwhile there is good information on this forum to help you with potential problems.
If you want to give 2020.1 a go, I advise you to check the forum for information regarding the devices you are using in your setup.
Best regards
Al
johnnyboy1984
I already did a new install with 2020.1 and have only discovered small problems.
The settings don't save when i changed long/lat
Some hardware inclusion didn't work, like buienradar.
All of that was solved when i used Internet Explorer instead of Chrome.
I don't have any scripts running, so have no problems there.
I still have to include my z-uno and hope that that will work as well.
jumbotroll
Post by jumbotroll »
Domoticz 2020.2 Beta for DSM 6.2.
Building some 2020.2 packages today.
Always take backup before installing new beta packages!
These are without python plugin support.
http://www.jadahl.com/domoticz_2020.2_6.2/
These are with python plugin support.
http://www.jadahl.com/domoticz_2020.2_python_6.2/
https://paypal.me/Jumbotroll
Jumbotroll
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
jumbotroll wrote: Sunday 07 June 2020 12:18 Domoticz 2020.2 Beta for DSM 6.2.
Tnx :!:
Alcloud
Post by Alcloud »
Very cool, thank you very much!
Sjaakios
Post by Sjaakios »
Thanks you so much!!
teo1966
Domoticz version: 2024.7
Post by teo1966 »
whit version domoticz_braswell-6.2_2020.2.12173-8 and domoticz_braswell-6.2_2020.2.12127-8 don't work on my DS916+
i start domoticz and domoticz stop every time ( after uninstal and instal )
whit domoticz_braswell-6.2_2020.1.11839-8 no problem
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
RogerSch
Post by RogerSch »
Just installed Version: 2020.2 (build 12127) and it seems to work on my 418Play!
Thnaks a lot for the update!
jumbotroll
teo1966 wrote: Wednesday 17 June 2020 20:13 whit version domoticz_braswell-6.2_2020.2.12173-8 and domoticz_braswell-6.2_2020.2.12127-8 don't work on my DS916+
EDIT:
Sorry!
Seems to be a libssl problem with that version.
New version domoticz_braswell-6.2_2020.2.12173-8 with libssl is uploaded and should work.
Please test this version.
New packages for all ARCH will be uploaded tomorrow I hope :)
Jumbotroll
teo1966
Post by teo1966 »
this one domoticz_braswell-6.2_2020.2.12178-8 ?
Release: 11
Codename: bullseye
jumbotroll
teo1966 wrote: Thursday 18 June 2020 19:51 this one domoticz_braswell-6.2_2020.2.12178-8 ?
What is your question?
Did it not work?
Jumbotroll
teo1966
Post by teo1966 »
sorry i read your message not good
i instal this version domoticz_braswell-6.2_2020.2.12178-8 and it works on my ds916+
thanks for the good service
(sorry my English is not good )
Release: 11
Codename: bullseye
jumbotroll
teo1966 wrote: Thursday 18 June 2020 21:37 sorry i read your message not good
Great!
Jumbotroll
Ayep
Domoticz version: 2023.1
Post by Ayep »
Thank you so much.
Will be donating towards your work.
Atis
Post by Atis »
Hello, I have a 1019+ syno NAS. Python 3 plugin installed. I download the last domoticz version with python plugin.
I copy the py file to var/plugins/NUT_UPS folder.
Domoticz and NAS restart but I can not see in hardware list. What is wrong?
I think the error that the upload domoticz file not include python:
Version: 2020.2 (build 12192)
Build Hash: 8f82b73ff-modified
Compile Date: 2020-06-29 16:15:42
dzVents Version: 3.0.9
Python Version: None
jumbotroll
Atis wrote: Tuesday 07 July 2020 9:37 Hello, I have a 1019+ syno NAS. Python 3 plugin installed. I download the last domoticz version with python plugin.
Sorry, I think something went wrong with python module i the last build.
I will start with uploading new Apollolake DS1019+ beta version later tonight or tomorrow.
Remember you also need to install the official Python3 package from synology to make domoticz with python to work.
https://global.download.synology.com/do ... 1-0108.spk
Last edited by jumbotroll on Wednesday 08 July 2020 22:57, edited 1 time in total.
Jumbotroll
arkoko
Post by arkoko »
Hi!
I also stucked with problem that python version do not recognize pyhon on my DS214play.
Python installed:
admin@ds214:/var/services/homes/admin$ python3 -V
Python 3.5.1
Domoticz version 6.2 with python installed: 2020.2 (build 12190)
I don't know is it normal or not, but About screen shows: "Python Version: None".
In log no word about PluginSystem.
2020-07-08 23:13:29.250  Status: Domoticz V2020.2 (build 12190) (c)2012-2020 GizMoCuz
2020-07-08 23:13:29.278  Status: Build Hash: 574e17d87-modified, Date: 2020-06-28 18:29:54
2020-07-08 23:13:29.279  Status: Startup Path: /usr/local/domoticz/
2020-07-08 23:13:29.606  Sunrise: 04:17:00 SunSet: 22:30:00
2020-07-08 23:13:29.607  Day length: 18:13:00 Sun at south: 13:24:00
2020-07-08 23:13:29.607  Civil twilight start: 02:58:00 Civil twilight end: 23:50:00
2020-07-08 23:13:29.607  There is no nautical twilight in the space of 24 hours
2020-07-08 23:13:29.608  There is no astronomical twilight in the space of 24 hours
2020-07-08 23:13:29.716  Active notification Subsystems: email, pushover (2/13)
2020-07-08 23:13:29.762  Status: WebServer(HTTP) started on address: :: with port 8084
2020-07-08 23:13:29.867  Status: WebServer(SSL) started on address: :: with port 8443
2020-07-08 23:13:29.900  Starting shared server on: :::6144
2020-07-08 23:13:29.929  Status: TCPServer: shared server started...
2020-07-08 23:13:29.929  Status: RxQueue: queue worker started...
2020-07-08 23:13:36.975  Status: Hardware Monitor: Started
2020-07-08 23:13:36.975  Status: Pinger: Worker started...
2020-07-08 23:13:37.045  Status: NotificationSystem: thread started...
2020-07-08 23:13:37.050  Status: EventSystem: reset all events...
2020-07-08 23:13:37.127  Status: dzVents: Write file: /usr/local/domoticz/var/scripts/dzVents/generated_scripts/Valve.lua
2020-07-08 23:13:37.135  Status: EventSystem: reset all device statuses...
2020-07-08 23:13:37.477  Status: OpenZWave: using config in: /usr/local/domoticz/Config/
2020-07-08 23:13:37.789  Status: OpenZWave: Starting...
2020-07-08 23:13:37.790  Status: OpenZWave: Version: 1.6-1173-g54bfecf2
2020-07-08 23:13:37.892  Status: EventSystem: Started
2020-07-08 23:13:37.905  Status: EventSystem: Queue thread started...
Domoticz uninstall/install did not help. Any idea how to fix?
jumbotroll
Latest beta packages will be updated because of missing Python.
Edit:
I have uploaded Apollolake,Evansport and x86 for test.
Please test and give me feedback if it´s working before I build all the packages, because this is a lot of work..
Jumbotroll
