Using domoticz without internet connection Topic is solved
Paul92
- Domoticz version: 2020.1
At home I'm running a Pi3+ with Domoticz for quite a while, added different hardware, scripts, etc.
For this setup everything is connected to the internet, accessible by phone, as 'usual'.
For another project I purchased a Pi4B with the raspberry 7"touch screen.
Goal is to implement and run Domoticz where no internet connection available. Therefore I decided to purchase the touch screen so I have a local control. Via the GPUI pins of the raspberry I want to switch relay contacts for devices(also purchased a relay board for this compatible with Pi).
Can you help /advise me how to set up the pi for this application?
Ofcourse I have an internet connection available during setup and programming. But not during final use.
Best regards and thanks in advance
Paul
Paul
- waaren
Re: Using domoticz without internet connection
domoticz does not need an active internet connection to run once it is installed. No special settings should be needed to achieve that.Paul92 wrote: Saturday 13 June 2020 11:20 Can you help /advise me how to set up the pi for this application?
Paul92
If all the automation is inside it can function without internet.waaren wrote: Saturday 13 June 2020 11:45domoticz does not need an active internet connection to run once it is installed. No special settings should be needed to achieve that.Paul92 wrote: Saturday 13 June 2020 11:20 Can you help /advise me how to set up the pi for this application?
Maybe my explanation was not completely correct...
But what I also would like is that I can visualize the domoticz interface on the touch screen, so I can do some manual actions and control switches.
If there is no internet connection available it shows domoticz offline when entering the IP.
foxmulder06
- Domoticz version: 2020.2
Both Domoticz Server equipment AND your equipment with a touch screen should be connected on the SAME LAN.
Even without any internet connection, one equipment could see and connect to another local LAN equipement, by using it LOCAL IP adresse like http://192.168.1.xxx for example
_____________________________________
Pascal
Pascal
Paul92
But I have no Wifi or LAN connection available (complete stand alone system: raspberry, raspberry touch screen end relay modules).
Then the raspberry doesn't receive an IP adress. Correct?
What I need is a stand alone system with domoticz dashboard visualized.
- waaren
It will not receive an external IP address but will still have 127.0.0.1 (localhost)Paul92 wrote: Saturday 13 June 2020 14:03 But I have no Wifi or LAN connection available (complete stand alone system: raspberry, raspberry touch screen end relay modules).
- FireWizard
Paul92
That's it! Didn't know this. Thankswaaren wrote: Saturday 13 June 2020 15:15It will not receive an external IP address but will still have 127.0.0.1 (localhost)Paul92 wrote: Saturday 13 June 2020 14:03 But I have no Wifi or LAN connection available (complete stand alone system: raspberry, raspberry touch screen end relay modules).
Paul92
Thanks! This is also usefull!FireWizard wrote: Saturday 13 June 2020 16:22 Hi,
Perhaps you should look at https://www.domoticz.com/forum/viewtopic.php?t=8678
solarboy
- Domoticz version: 2024.6
You'll need a real-time-clock such as the Adafruit, as Rpi gets it's time from the internet. I have fitted this and it works well.
- waaren
although handy it's not required. You can set the data/time manually after reboot.solarboy wrote: Friday 19 June 2020 21:21 You'll need a real-time-clock such as the Adafruit, as Rpi gets it's time from the internet. I have fitted this and it works well.
solarboy
Kind of defeats "automation" though no?
