turn on switch from perl script
b0b99
Post by b0b99 »
Is it possible to turn on a switch in Domoyicz from a perl script? If so could you give me an example script?
Thanks, bob
I have tried the sample script listed in the perl wiki but no errors are returned and the light does not turn on.
#!/usr/bin/perl
no warnings 'uninitialized';
use LWP::UserAgent;
$url{domo}=>'http://myip:8080';
$idx=87;
$cmd='On'; # or 'Off'
$switch_url=$url{domo}.'/json.htm?type=command&param=switchlight&idx='.$idx.'&switchcmd='.$cmd;
$ua=LWP::UserAgent->new; $ua->timeout(5); $res=$ua->put($switch_url);
unless ($res->is_success) { warn $res->status_line };
freijn
Domoticz version: Stable
Re: turn on switch from perl script
Post by freijn »
THis is an buienradar script but basics are the same
#!/usr/bin/perl -w
=head1 buienradar_rain.pl
Installation:
Perl, you need to install the LWP module:
sudo apt-get install libjson-perl
In Domoticz create a Dummy Percentage sensor.
Next go to the Devices overview, and write down the 'idx' value of the sensor.
Copy this file to another location and edit the setting below to match your situation.
cp /home/pi/domoticz/scripts/buienradar_rain_example.pl /home/pi/domoticz/buienradar_rain.pl
nano /home/pi/domoticz/buienradar_rain.pl
Next add a Crontab rule:
crontab -e
Add the following line at the end:
*/5 * * * * perl /home/pi/domoticz/buienradar_rain.pl
In 5 minutes, the sensor should work
=cut
use strict;
use LWP::UserAgent;
use HTTP::Cookies;
my $lat=50.22041;
my $long=5.89744;
my $domoticz_ip="127.0.0.1";
my $domoticz_port="8080";
my $domoticz_sensor_idx="2442";
my $duration=15;
my @user_agents = (
		'Mozilla/4.0 (compatible; MSIE 4.01; Windows 98)'
my $ua = LWP::UserAgent->new(
		#Set agent name, we are not a script! :)
		agent		=> $user_agents[rand @user_agents],
		cookie_jar	=> HTTP::Cookies->new(),
my ($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst) = localtime();
my $startTime=($hour*60)+$min;
my $endTime=$startTime+$duration;
my $url = "http://gps.buienradar.nl/getrr.php?lat=$lat&lon=$long";
my $response = $ua->get($url);
unless ($response->is_success) {
	# hmm, let's retry
		# still no luck; sleep and retry
		sleep 1;
			print "Could not connect to buienradar.nl.\n";
			exit 0;
my $data = $response->content;
unless ($data =~ /\A((\d{3})?\|\d{2}:\d{2}\r?\n)+\z/) {
	print "Could not parse the data returned by buienradar.nl.\n";
	exit 0;
my $total_rain_predictions=0;
my $total_rain_values=0;
while ($data =~ s/\A(\d{3})?\|(\d{2}:\d{2})\r?\n//) {
	my ($value, $mtime) = ($1, $2);
	if (defined $value) {
		my @hour_min = split(':', $mtime);
		my $mhour = $hour_min[0];
		my $mmin = $hour_min[1];
		my $calc_time=($mhour*60)+$mmin;
		if (($calc_time>=$startTime)&&($calc_time<=$endTime)) {
			$value =~ s/\A0+(\d)/$1/;
			$total_rain_predictions+=$value;
			$total_rain_values+=1;
my $result = "0.0";
if ($total_rain_values!=0) {
	my $rain_0_100=($total_rain_predictions/$total_rain_values)*0.392156862745098;
	$result = sprintf("%.2f", $rain_0_100);
$url = "http://$domoticz_ip:$domoticz_port/json.htm?type=command&param=udevice&idx=$domoticz_sensor_idx&nvalue=0&svalue=$result";
    print "Error sending data to domoticz!\n";
    exit 0;
if (index($data, "\"OK\"") == -1) {
    exit 0;
print "OK, precip=$result\n";
b0b99
Post by b0b99 »
Hello freijn, Thank you for getting back to me. Unfortunately I am not all that familiar with coding so I could not pick out of your code what was necessary to accomplish what I was after. However, looking again at the sample code given in the wiki under perl, I found the problem.
The line "$url{domo}=>'http://192.168.xxx.xxx:8080';" should be "$url{domo}='http://192.168.xxx.xxx:8080';"
Removing the greater than sign solved the problem and the sample code now works.
Again, thanks for getting back to me. I appreciate your trying to help.
Bob
