Schript react very strange
dutchronnie
Post by dutchronnie »
I am running the following script:
	active = true,
	    timer = {
	        'at 07:00',
	        'at 19:20',
	        'at 11:30',
	execute = function(domoticz, myDevice, triggerInfo)
		local myDevice1 = domoticz.devices('Espressomachine')
		local myDevice2 = domoticz.devices('iDetect - Ronald')
		local myDevice3 = domoticz.devices('iDetect - Regina')
		if (triggerInfo.trigger == 'at 07:00') and (myDevice2.state == 'On') or (triggerInfo.trigger == 'at 19:20') and (myDevice2.state == 'On') or (myDevice3.state == 'On') then
		    myDevice1.switchOn().checkFirst()
		elseif (triggerInfo.trigger == 'at 11:30') then
            myDevice1.switchOff().checkFirst()
The script has to turn on my Espresso machine at 7:00 in the morning when i am at home (Ronald)
And at 19:20 when i at home or my wife (Regina)is at home.
And turn of the Espresso machine at 11:30 in the morning
But many often it turns on the machine on at 7:00 and an half hour later it turns of the machine.
Or in the evening when domoticz turns on the lights in the house, it turns on the espresso machine, but in that script there is no action for the espresso machine.
Is there a error in my script?
felix63
Domoticz version: 2020.1
Re: Schript react very strange
Post by felix63 »
Hi Ron,
When creating complex conditions I always throw in some extra brackets to make sure it works as I expect. For 'and' has higer precedence than 'or'. Haven't checked if this is truly the case here but you could check this version.
	active = true,
	    timer = {
	        'at 07:00',
	        'at 19:20',
	        'at 11:30',
		if (triggerInfo.trigger == 'at 07:00' and myDevice2.state == 'On') or
			(triggerInfo.trigger == 'at 19:20' and (myDevice2.state == 'On' or myDevice3.state == 'On')) then
dutchronnie
Thanks,
I try the extra brackets. Maybe it helps.
dutchronnie wrote: Wednesday 10 June 2020 10:17 Thanks,
This script is only trigered at 07:00, 19:20 and 11:30. If you see unexpected behavior at other times it cannot be caused by this script.
If you search for bugs or logic errors it is always good to add some log statements so you can see what happens. When everything is OK you can set the log level to LOG_ERROR which will show only errors if and when they occur.
return
    active = true,
    on =
        timer =
            'at 07:00',
            'at 19:20',
            'at 11:30',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when everything works as expected
        marker = 'Espresso',
        domoticz.log(myDevice2.name .. ' state is ' .. myDevice2.state ,domoticz.LOG_DEBUG)
        domoticz.log(myDevice3.name .. ' state is ' .. myDevice3.state ,domoticz.LOG_DEBUG)
            domoticz.log(myDevice1.name .. ' will be switched on (if not already on)' ,domoticz.LOG_DEBUG)
                domoticz.log(myDevice1.name .. ' will be switched off (if stil on)' ,domoticz.LOG_DEBUG)
dutchronnie
Thanks,
I add the Log statements.
Maybe the errors are caused by another script, but till now i can't find de cause.
I hope the log statements do clear something for me
dutchronnie wrote: Wednesday 10 June 2020 12:23 Thanks,
I forgot to add the 2 and 3 in the log statements after myDevice. Now corrected it in my previous post.
