'Dromotica' app for controlling Domoticz from Android
- Domoticz version: BETA
Re: Android app
On a enigma box perhaps?
Re: Android app
There's a special Android version coming for TV's. Will be released tomorrow. Google has send out developer units of a standalone box that has Android TV running on it.
More info on Android TV: http://www.android.com/tv/
- Brutus
Re: Android app
He Sebas,
You did more then just fixed some issues
I can now see my camera to
My wishlist would be:
- To see the Dashboard icons instead of all the switches.
- When you scroll down and look at some switches and a refresh is comming the screen scrolls back to the top.
- Notifications in the app so you don't need any other apps. (When doorbell is pressed you get a popup from your camera).
Greetings Brutus.
Greetings Brutus.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
Re: Android app
@Brutus and @Sebas. Thank you very much for help and updating; the app works fine!
Re: Android app
SurpriseBrutus wrote:He Sebas,
I can now see my camera to![]()
Greetings Brutus.
Notifications would require work on the Domoticz side as well so I need to see if the dev team has time to implement it. Dashboard should be doable and that refresh thing as well.
You're welcomeMart wrote:@Brutus and @Sebas. Thank you very much for help and updating; the app works fine!
Does someone know how I get that security panel to work? I entered a security code and set the delay to 0. It doesn't show anywhere event after I logout of Domoticz.
Re: Android app
I filled in my internal IP and port at both internal and external, and now it worksvmb wrote:@thinkpad Same situation here. When I connect through vpn (synology) I filled in Dromotica at field external and internal adress the internal adress of my Pi. Is works like a charm...
@sebas, thanks for adding support for protected switches so quickly!!
Re: Android app
Great, nice to hear. My first contribution to this forum...ThinkPad wrote:I filled in my internal IP and port at both internal and external, and now it worksvmb wrote:@thinkpad Same situation here. When I connect through vpn (synology) I filled in Dromotica at field external and internal adress the internal adress of my Pi. Is works like a charm...
Re: Android app
When will the widgets get a update? A custom short tag would we very handy! They are now a bit useless
- Domoticz version: 2024.7
Re: Android app
Sappien wrote:When will the widgets get a update? A custom short tag would we very handy! They are now a bit useless
Good morning,
I agree with that point.. A short label would be usefull to manage the widgets.
I am using Dromotica since yesterday with my Domoticz server installed on my Synology. It is a nice app, congrats for the job.
I have sent an e-mail to the developper to inform him about a bug with the "Form authentication"
I had to set my server to "Basic Auth" in order to solve my issue. I was able to list the devices and the scenes but no command could be sent.
Regarding a wish list... Would it be possible to add a STOP button for blinds ?
Schim'
Eric
Raspberry 3b+
Debian GNU/Linux 11 (bullseye)
Mobile App : Home made progressive web app
RFXTrx433E transceiver (for my RTS devices)
Somfy Tahoma Switch (for my IO devices)
Aeon Labs Z-Stick S2
Raspberry 3b+
Re: Android app
Hi, developer hereSchim57300 wrote:Sappien wrote:When will the widgets get a update? A custom short tag would we very handy! They are now a bit useless
Good morning,
Schim'
Stop button for blinds has been requested before. I have added it to the (long) list of features that I would like to include.
- bizziebis
- Domoticz version: 3.8805
Re: Android app
Tags would be great indeed. I now created them with a widget 'simple text'. Otherwise it's indeed almost useless. Or you must have a photographic memory
- Domoticz version: 2022.2
Re: Android app
Is there a way to get Dromotica working through a vpn? I think the problem now is the check of the home wifi ssid.
Re: Android app
Yes, there is. Copy your local settings to the remote settings.jan_nl wrote:Is there a way to get Dromotica working through a vpn? I think the problem now is the check of the home wifi ssid.
Re: Android app
Thx, that works. Should have thought of that myself.
Now the dashboard would be a nice feature tot have.
Re: Android app
Hi Sebastian,
Thanks for your answer on Google Play ^^
I have updated Dromotica on my smartphone. I have switched my Dromoticz server from "Basic Auth" to "Connection Form" and started Dromotica.
List of devices : ok
List of scenes : ok
List of Temp Sensor : ok
Opening one blind : ok
Getting my Temp sensor state : ok
Well done amd thank you very much !
I only miss a stop button which is available on Domoticz web interface
Yesterday I tried the widget. It works... It only remains to add a short tag but thanks to bizziebis, we have a way to bypass the problem
Schim'
List of scenes : ok
Schim'
Eric
Raspberry 3b+
Raspberry 3b+
Re: Android app
hi sebas
i have a problem with the last update, when i scroll down on switchs the dromototica goes down ( application turn off).
Scenes- ok
utilities- ok
temperature- ok
Weather - ok
cameras- ok
i think that is about switches are longer (more switchs) then the other tabs.
thanks
Scenes- ok
utilities- ok
temperature- ok
Weather - ok
cameras- ok
thanks
Re: Android app
Are you using the venetian blinds? For me those are the only one's with a stop button in the web interface. I haven't added support for them yet but will do soon.Schim57300 wrote:Hi Sebastian,
List of scenes : ok
Schim'
Do you have protected switches? If that's the case I fixed that this morning, that update should be available in the store about now.maluko wrote:hi sebas
Scenes- ok
utilities- ok
temperature- ok
Weather - ok
cameras- ok
thanks
Re: Android app
I m using SOMFY blinds :sebas wrote: Are you using the venetian blinds? For me those are the only one's with a stop button in the web interface. I haven't added support for them yet but will do soon.
I can send an "Open" command and then send a "stop" command via Domoticz
Domoticz type of Switch : Blinds
Protocol : RTS
Does that answers you ?
Last edited by Schim57300 on Sunday 09 November 2014 19:13, edited 1 time in total.
Eric
Raspberry 3b+
Raspberry 3b+
Re: Android app
Yes, and it adds some confusionSchim57300 wrote:I m using SOMFY blinds :sebas wrote: Are you using the venetian blinds? For me those are the only one's with a stop button in the web interface. I haven't added support for them yet but will do soon.
Protocol : RTS
This is how the blinds switch is shown in Domoticz for me:
And this is the Venetian blinds:
I expected to only have the stop command with the venetian blinds and I haven't implemented them yet. As the stop button works with blinds I can add that to the switch in Dromotica without a problem.
P.S. your second image doesn't show (403 error).
Re: Android app
Do you have protected switches? If that's the case I fixed that this morning, that update should be available in the store about now.[/quote]maluko wrote:hi sebas
Scenes- ok
utilities- ok
temperature- ok
Weather - ok
cameras- ok
thanks
Thanks sebas, i did the update now and works fine.
