I planning to write a script with multiple devices (i.e switches) in the selection field.
A question. How to detect, using if logic, which one triggers the script?
Which device triggers the scrip? [Solved]
Re: Which device triggers the scrip?
Use dzVents and you can find the trigger devices by name.
The first 2 post explain more.
- waaren
Re: Which device triggers the scrip? [Solved]
If you insist on using if logic (if logic is not needed to identify which device triggered the script) you can use something like below.
return
on =
devices =
'deviceA',
'deviceB',
logging =
level = domoticz.LOG_INFO,
marker = 'trigger identifyer',
execute = function(dz, item)
local deviceA = dz.devices('deviceA')
local deviceB = dz.devices('deviceB')
if item == deviceA then
dz.log('script was triggered by deviceA',dz.LOG_INFO)
elseif item == deviceB then
dz.log('script was triggered by deviceB',dz.LOG_INFO)
