My (dzvents) code so far:
devices = {
"myTest"
customEvents = {
"myTestEvent*"
execute = function(domoticz, object, triggerInfo)
if object.isDevice then
domoticz.log('Device ' .. object.name .. ': state ' ..tostring(object.bState).. '.', domoticz.LOG_FORCE)
if object.bState == true then
local name = 'myTestEvent_' .. tostring(object.idx) .. '_' .. object.lastUpdate.raw
domoticz.emitEvent(name, { idx = object.idx, bState = object.bState, lastUpdate = object.lastUpdate } ).afterSec(10)
elseif object.isCustomEvent then
if object.json == nil then
domoticz.log('CustomEvent, ' .. object.customEvent .. ', json is nil.', domoticz.LOG_ERROR)
domoticz.log('CustomEvent, ' .. object.customEvent .. ', idx = '.. tostring(object.json.idx) .. ', bState = ' ..tostring( object.json.bState) .. '.', domoticz.LOG_FORCE)
if object.json.idx == nil then
domoticz.log('CustomEvent, ' .. object.customEvent .. ', json.idx is nil.', domoticz.LOG_ERROR)
local dev = domoticz.devices(object.json.idx)
if dev == nil then
domoticz.log('CustomEvent, ' .. object.customEvent .. ', device ' .. tostring(object.json.idx) .. ' not found.', domoticz.LOG_ERROR)
if dev.bState == object.json.bState and dev.lastUpdate.compare(object.json.lastUpdate).compare == 0 then
domoticz.log('CustomEvent, ' .. object.customEvent .. ', device ' .. dev.name .. ' is still on.', domoticz.LOG_ERROR)
domoticz.log('CustomEvent, ' .. object.customEvent .. ', device ' .. dev.name .. ' is no longer on. : ' .. tostring(dev.lastUpdate.rawDateTime) .. ' <> ' .. tostring(object.json.lastUpdate.rawDateTime) .. '.', domoticz.LOG_ERROR)
-- domoticz.utils.dumpTable(object.json.lastUpdate)
-- domoticz.utils.dumpTable(dev.lastUpdate)
domoticz.log( "unexpected trigger type.", domoticz.LOG_FORCE)
Output from the log (had to filter all other devices' output out):
2020-06-02 13:41:02.776 (dummy) Light/Switch (myTest)
2020-06-02 13:41:02.760 Status: User: Admin initiated a switch command (552/myTest/Off)
2020-06-02 13:41:03.014 Status: dzVents: !Info: Device myTest: state false.
2020-06-02 13:41:04.066 (dummy) Light/Switch (myTest)
2020-06-02 13:41:04.057 Status: User: Admin initiated a switch command (552/myTest/On)
2020-06-02 13:41:04.275 Status: dzVents: !Info: Device myTest: state true.
2020-06-02 13:41:14.534 Status: dzVents: !Info: CustomEvent, myTestEvent_552_2020-06-02 13:41:02, idx = 552, bState = true.
2020-06-02 13:41:14.553 Error: dzVents: Error: (3.0.5) CustomEvent, myTestEvent_552_2020-06-02 13:41:02, device myTest is no longer on. : 2020-06-02 13:41:04 <> 2020-06-02 13:41:02.
