How to change the volume of the amixer With a virtual dimmer  [Solved]
besix
Post by besix »
I have domoticz v 2020.2 beta current RPI, dzVents Version: 3.0.8
I use a USB audio card where I do volume control using the selector and sh scripts
#!/bin/bash
amixer sset 'Speaker' 2dB+
#!/bin/bash
amixer sset 'Speaker' 2dB-
or
amixer sset 'Speaker' 0% - selector - level 1
amixer sset 'Speaker' 100% - selector - level 10
How to change the volume of the amixer With a virtual dimmer.
What is the best way to do this ; amixer sset Speaker value to virtual dimmer%
Of course, it's best at dzVents
thank you for your help
Re: How to change the volume of the amixer With a virtual dimmer
besix wrote: Monday 01 June 2020 19:40 amixer sset 'Speaker' 2dB+
Can you check if the dzVents command os.execute("amixer sset 'Speaker' 2dB+") does work ?
besix
Post by besix »
That's how it works
          devices = {'Button'}
   logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Volume up button ',
    execute = function(dz, device)
      if (device.state == 'On' ) then
      dz.log ('volume up +2dB')
besix wrote: Monday 01 June 2020 21:30 That's how it works
And what is the range of the dB+ and dB- ?
In other words if the slider of the dimmer goes from 0 to 100 how much should the dB do ?
besix
Post by besix »
Speaker [dB gain: -45,00, -45,00] - mute 0%
Speaker [dB gain: 0,00, 0,00] - full 100%
if gain = -45 and amixer sset 'Speaker' 2dB+
set gain = -43
I hope it's readable
besix wrote: Monday 01 June 2020 22:42 Speaker [dB gain: -45,00, -45,00] - mute 0%
set gain = -43
So 100 = 0 and -45 = 0 ?
Is my conclusion that every 100/45 point of the dimmer is 1 dB correct ?
besix
Post by besix »
Yes, this is it
besix
Post by besix »
I changed sh scripts to one dzVents script and it works
          devices = {'Volume'} -- Name of the dummy Domoticz selector
   logging =
        marker = 'Volume control ',
	  local  vol = dz.devices('Volume')
	  if vol.state == 'Off' then
         os.execute('mpc pause')
         dz.log ('volume mute')
	  elseif vol.state ~= 'Off' then
	     os.execute('mpc play')
	     dz.log ('Set volume to selector level')
	  if vol.state == '25%' then
	     os.execute("amixer sset 'Speaker' 25%")
	   elseif vol.state == '27%' then
	     os.execute("amixer sset 'Speaker' 27%")
	   elseif vol.state == '30%' then
	     os.execute("amixer sset 'Speaker' 30%")
	   elseif vol.state == '35%' then
	     os.execute("amixer sset 'Speaker' 35%")
	   elseif vol.state == '40%' then
	     os.execute("amixer sset 'Speaker' 40%")
	   elseif vol.state == '45%' then
	     os.execute("amixer sset 'Speaker' 45%")
	   elseif vol.state == '60%' then
	     os.execute("amixer sset 'Speaker' 61%")
	   elseif vol.state == '70%' then
	     os.execute("amixer sset 'Speaker' 70%")
	   elseif vol.state == '80%' then
	     os.execute("amixer sset 'Speaker' 80%")
	   elseif vol.state == '95%' then
	     os.execute("amixer sset 'Speaker' 95%")
However, this does not give as much opportunity as a dimmer
besix wrote: Tuesday 02 June 2020 9:46 I changed sh scripts to one dzVents script and it works
can you try this after setting up a virtual dimmer in domoticz
return
    on =
        devices =
            'Dimmer', -- Name of the virtual  dimmer
   logging =
    execute = function(dz, item)
        local percentage = 0
        if item.state == 'Off' then
            return
        elseif item.state == 'On' then
            percentage = 95
            percentage = item.level
        dz.log ('volume to ' .. percentage .. '%',dz.LOG_DEBUG)
        os.execute("amixer sset 'Speaker' " .. tostring(percentage) .. "%")
besix
Post by besix »
Thank you for your help, but it doesn't work ok.
I added the mpc play command because dimmer did not start playback.
The script works so that it always sets the value of percentage max
no matter where the slider is
            return
            percentage = 40
Record in Log
2020-06-02 14:25:41.210 Status: dzVents: Info: Volume control : volume mute
2020-06-02 14:25:41.210 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:45.941 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:45.963 Status: dzVents: Info: Volume control : volume mute
2020-06-02 14:25:45.963 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:48.814 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:48.844 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:48.871 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:50.993 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:51.016 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:51.051 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:52.715 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:52.737 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:52.763 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:54.105 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:54.128 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:54.158 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:55.345 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:55.368 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:55.401 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:56.650 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:56.672 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:56.698 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
Here max 95 as you did
            percentage = 95
And Log
2020-06-02 14:54:00.174 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Volume dimmer.lua
2020-06-02 14:54:12.030 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:12.064 Status: dzVents: Info: Volume control : volume mute
2020-06-02 14:54:12.064 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:54:15.143 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:15.176 Status: dzVents: Debug: Volume control : volume to 95%
2020-06-02 14:54:15.205 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:54:16.162 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:16.185 Status: dzVents: Debug: Volume control : volume to 95%
2020-06-02 14:54:16.212 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:54:16.833 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:16.862 Status: dzVents: Debug: Volume control : volume to 95%
2020-06-02 14:54:16.890 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:54:17.637 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:17.668 Status: dzVents: Debug: Volume control : volume to 95%
besix wrote: Tuesday 02 June 2020 14:44 Thank you for your help, but it doesn't work ok.
Can you try with this one ?
return
    on =
        devices =
   logging =
            item.dimTo(1).silent()
            item.dimTo(0).silent().afterSec(1)
            local percentage = item.level
            os.execute("mpc play; sleep 1; amixer sset 'Speaker' " .. tostring(percentage) .. "%")
besix
Post by besix »
Now works in the slider range.
The level change works with a second delay but it is probably by sleep 1? I have a question
Why when the dimmer is OFF need to set the dimmer to 1 and per second to 0
Second question After setting the dimmer to OFF and then He is always 1% level Does it have to be this way?
Third question. If you delete the mpc play and pausa commands, you can eliminate delays?
Many thanks for your time and help
besix wrote: Tuesday 02 June 2020 18:38 Now works in the slider range.
Answer 1+2: If you don't do this the slider will stay on the last level ==>> visual confusing
Yes, the sleep is only to ensure that the volume command does not interfere with the play.
Just experiment without it and you will see if it keeps working. I cannot test because I don't own the hardware.
besix
Post by besix »
Thank you again !
besix
Re: How to change the volume of the amixer With a virtual dimmer  [Solved]
Post by besix »
Without mpc play support, pause Works as I wanted
You were very helpful
Users browsing this forum: Google [Bot], jvdz and 1 guest
