Take an action only once if a certain threshold has been reached  [SOLVED]
jefstevens
Post by jefstevens »
As a newbie I cannot figure this one out so any tips/ideas are more than welcome…
I am monitoring my Solar panel production and I would like to be notified for every step of 10 kWh my solar production increases.
Since I am planning to be informed with a Telegram message this should only happen once with every “block of 10” increase.
I am checking my Solar production (among other things) every 10 minutes with a DzVents script.
I suppose I need to keep variables with their "current" value in between multiple runs of the dzVents script, i.e. var10, var20, var30,… are initialised at 0 at the start of a new day, and when the production reaches 10 kWh var10 = 1 and a message “10 kWh reached” will be send and will, that day, not be send again. Once production reaches 20 kWh var20 = 1, a message “20 kWh reached” will be send and will, that day, not be send again, etc…. I guess you all get the idea…
I guess only 1 variable could suffice as well, where the variable value evolves from 1 to 10, to 20, etc and the variable value is the message to be send.
Any suggestions, ideas on how to tackle this?
Re: Take an action only once if a certain threshold has been reached
jefstevens wrote: Saturday 30 May 2020 18:57 Any suggestions, ideas on how to tackle this?
What is the type and subtype of the Solar panel production device? (look at the devices tab)
jefstevens
Thanks for trying to help me!
type = General, subtype = kWh
I have no clue whether this is relevant or not but in the "Utility" tab I see the Solar block, with Log, Edit and Notifications. If I zoom in on Notifications the 2 types I can see are "Usage" and 'Last Update"
jefstevens wrote: Sunday 31 May 2020 10:23 type = General, subtype = kWh
below script should do it.
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
--  solarMessages Should work in dzVents >= 2.4
--------- Your settings below this line --
    local solarProductionDevice = 'Enphase production'
    local messageFrequency = 1000 -- in Watt
    local resetTime = 'at 01:07' -- a time that will always be after sunset and before sunrise
--------- No changes required below this line
return
    on =
        timer =
            'every 10 minutes at daytime',
            resetTime,
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when OK
    data =
        messageSend = { initial = 0 },
    execute = function(dz)
        local solarProductionToday = dz.devices(solarProductionDevice).WhToday
        if dz.time.matchesRule(resetTime) then
            dz.data.initialize('messageSend')
            dz.log('Produced today :' .. dz.utils.round(solarProductionToday / 1000,3 ) .. ' kWh', dz.LOG_DEBUG)
            local divider = math.floor( solarProductionToday / messageFrequency )
            if dz.data.messageSend == 0 then
                dz.data.messageSend = divider
            elseif divider > dz.data.messageSend then
                dz.notify('solar production','And another ' .. ( messageFrequency / 1000 ).. ' kWh!',dz.PRIORITY_NORMAL,'','',dz.NSS_TELEGRAM )
jefstevens
Re: Take an action only once if a certain threshold has been reached  [SOLVED]
Thanks, also for the tips!
