DSC/Envisalink integration
This is a script I use as some sort of "middleware" to send events from my alarm system to domoticz. It's written in Perl and you have to have it running, so running it inside a screen is probably a good idea :)
You need some basic perl modules (included in ubuntu) and Mojolicious, see http://mojolicio.us/ for more information.
You need to create dummy devices in Domoticz and know the IDX for these devices.
In the top of the script you have to define your envisalink device and your domoticz server. You also need to map the zones in your alarm to the IDX in domoticz.
This is probably not the best way to do the integration and far from good looking code, but it works for me.
If you find any problem, please report them.
-- Update
As my first post lacked alot of information about how to get it running, here comes some quick steps:
1. Install the basic things needed (done via ssh):
sudo apt-get install libdatetime-perl libdatetime-format-strptime-perl libwww-perl libjson-perl build-essential curl screen
2. Install Mojolicious (done via ssh):
sudo -s
curl get.mojolicio.us | sh
exit
3. Create the virtual devices in Domoticz:
Click "Setup" in the main menu and click "Hardware"
In the "Type" dropdown, select "Dummy (Does nothing, used for virtual switches only)"
Enter a name on your virtual hardware, example: Alarm
Press the "Add" button
In the main meny, click "Switches" and then "Manual Light/Switch" to add a new virtual switch
In the popup, select your newly created virtual hardware.
Enter a name on the switch, example: Zone 1.
Select "Switch Type" of device. For motion sensors I use the type "Motion sensor" and for magnet contacts I use "On/Off".
For the rest of the options, select what you feel right. I don't think it matters.
4. Write down the Idx of each of your virtual devices (or Zones, if you wish to call them that)
Click "Setup" in the main meny and click "Devices"
You now have a table of all your devices. The first column contains the Idx of all the devices. Write these down, as you need them for the script.
5. Set up the script (done via ssh):
Open the script with nano; nano -w envisalink_domoticz.pl
Go down to the section/comment "information about the Envisalink module"
Edit the 3 lines below it, with your envisalink password, ip and port
After the Envisalink information you can toggle the debug flag. If it is set to 1, it enables debug, and 0 disables it.
The next section of the script is the information about your Domoticz installation. Please enter the IP to Domoticz and the HTTP port used. The default port is 8080
Next up is the mapping of zones to idx'es. From the previous steps you have your Idxes and I suppose you know the number of your alarm zones in your dsc setup.
The script comes with 11 zones defined, if you have more zones you just add them and if you have less you remove some of them.
The format is "'<zone id>' => <idx>"
Example; if your zone 1 got the idx 102, then set it like this; '001' => 102
When done, press ctrl+x and choose to save the file. This will also close nano
6. Run the script in a screen (done via ssh):
Start a new screen with the name envisalink; "screen -mS envisalink"
Start the script; perl envisalink_domoticz.pl
Detach the screen by pressing; ctrl+a+d
If you later want to return to the screen, attach it by running this command; screen -dr envisalink
7. Check that the virtual switches changes state in Domoticz when you move around or open a door.
Hopefully this will help you guys getting started with the script :)
-- Update
sudo -s
exit
- envisalink_domoticz-v1.0.zip
- (3.32 KiB) Downloaded 402 times
Re: DSC/Envisalink integration
This is great news!
I'm not sure exactly where to start though..... Any chance you could list down some install instructions for someone running it using the Raspberry Pi SD Image?
I've updated my original post with some installation instructions. Please report back if you need any more information.tommysharp wrote:This is great news!
Holy Cow!!!! It works!!!
Being that I barely know what I'm doing your instructions were perfect and worked first time without any issues! Fantastic....
I'm not sure I understand the whole concept of "Screens" but I suspect that with what you've documented I'd have to start a new "screen" manually if the raspberry pi ever rebooted?
I'm still a little new to Domoticz too so excuse this dumb question.... I sort of assumed that my Motion Sensor virtual switch would change in the UI once it detected movement, but I didn't see anything happen, although if I click on the log I can see it going on and off as expected in the chart... Maybe it just goes on and off too quickly to register in the domoticz UI?
A screen is a "virtual terminal" where you can run programs that you want to continue to run even when you have logged off your system.tommysharp wrote:Holy Cow!!!! It works!!!
And yes, when you reboot your raspberry pi you have to start a new screen. This is probably fixable with a startup script.
If you have any magnet contacts in your alarm system, open one of those zones and you should see the change. Motion sensors change the state pretty fast.
Some sort of start up script would be great!
I don't have any magnetic contacts but I'm pretty sure its possible to extend the "activated" time within the DSC alarm so I'll look into that.
Just watching the SSH screen I'm amazed how quickly your utility talks to the envisalink board.... Are you just constantly polling it?
The Envisalink board got a TPI (Third Party Interface) that you can connect to and that is what the script does. When a client is connected to the TPI the Envisalink board sends everything that happens to that client. So no polling, just an active stream of data directly from the Envisalink.tommysharp wrote:Some sort of start up script would be great!
For those of you who are interested in the TPI interface, Eyez-on have documentation of it here: http://forum.eyez-on.com/FORUM/viewtopic.php?f=6&t=301
Have you considered how to show a virtual switch for when the whole system is armed or not? Good for activating something when you get home and disarm the alarm.
That's coming in version 1.1tommysharp wrote:Have you considered how to show a virtual switch for when the whole system is armed or not? Good for activating something when you get home and disarm the alarm.
- Domoticz version: BETA
What hardware do in need?
And some one have a demo login or something?
The hardware se use (beside the DSC alarm system) is this ethernet module: http://www.eyezon.com/?page_id=176Derik wrote:What hardware do in need?
I don't think a demo login will do much good, as all you can see is virtual switches turning on and off in Domoticz.
The current state if the script makes it possible to do things based on events from the alarm system, the same way you do other things with Blockly.
Okay so I've had my alarm talking to Domoticz on the Raspberry Pi for over a week now and I've noticed a real slow down when you look at the log of each sensor. Some of them have over 18000 log entries so I guess this is what is slowing it down.
Is there any way to purge log entries for a certain sensor after x days?
At the moment the graph on the log just jumps from 0 to 100 each time the sensor is tripped. I think it'd be useful to also see a chart showing the number of trips per hour or day. One day when I get some central heating installed and hooked up I'd love to intelligently heat rooms based on how much they've been used recently, I think these sensors could give me that data. But I'm still too much of a newbie to conceptualize how I'd get this working
Do you think it will be feasibly to startup the screen and run your script using the "rc.local" startup script that is launched when the raspberry pi starts up?
@prozzerg
Hey! Any more thoughts on how we can make this great plugin/script start up automatically every time the Raspberry Bi starts up?
Hi,tommysharp wrote:@prozzerg
sorry for taking nearly 2 months to answer this. I've had alot to do lately and as Domoticz doesn't support (and probably never will) support the MySensors project I have replaced it with Ago Control.
Anyhow, to start it at boot, i would add it as a cronjob as a @reboot command.
Login as your user and start the cronjob editor;
crontab -e
Add this:
@reboot screen -mS <screenname> /path/to/the/script
Test it by rebooting.
Cool, thanks will give that a try....
Sad to see you have moved on from Domoticz because that means you won't be adding to your cool DSC Alarm script anymore
What are your thoughts on Ago Control... I haven't tried it because it doesn;t even have any screenshots to show what it looks like etc.... Might install it on a different SD card because I am also interested in the MySensors integration.
Okay have given this a try but it doesn't seem to be working....
I've tried adding both of the lines below to the "crontab" but it just doesn't seem to be running after a reboot...
@reboot screen -mS EnvisaLink /home/pi/envisalink_domoticz.pl
and
@reboot screen -mS EnvisaLink perl /home/pi/envisalink_domoticz.pl
Any sort of logs or something I could check?
and
I might was a big quick on that one and forgot that you need the -d parameter to screen (detached). So, please try this instead:tommysharp wrote:Okay have given this a try but it doesn't seem to be working....
and
@reboot screen -d -m -S EnvisaLink /home/pi/envisalink_domoticz.pl
Still no luck I'm afraid.... No idea what I'm doing really...
This is what I've added to my crontab..
@reboot screen -d -m -S EnvisaLink /home/pi/envisalink_domoticz.pl &>/tmp/tommy.log
The bit on the end was some stuff google told me to add to try and log any errors, it creates the log file but it's empty....
I don't suppose anyone is able to help me with getting this script to run automatically when my Raspberry Pi reboots?
