Sunset in function  [Solved]
robbert1977
Sunset in function
Post by robbert1977 »
Just to check if there is an easier way.
I have triggers (devices) and based on their state there are several different actions.
One of them is if switch triggered and Lux < maxlux then postpone switching the lights till XX minutesAfterSunset.
As far as I know the sunset time is in a function only available in minutes after midnight not as a real time.. is that correct?
As a work around I now do:
            local hoursstring = dz.utils.stringSplit((dz.time.sunsetInMinutes+minutesAfterSunset)/60,".")
            local hours = hoursstring[1]
            local minutestring = dz.utils.stringSplit (hoursstring[2] / 100 * 60,".")
            local minutes = minutestring[1]
            local sunset = (hours..':'..minutes)
Which is working fine btw just wondering if it could be done smarter :)
Happy to learn.
Kind regards
Raspberry Pi 4
domoticzVersion: 2020.2
dzVentsVersion: 3.0.2
OpenZWave USB: 1.6-1033-g3661f170
RFXCOM - RFXtrx433 USB: Pro XL1/1043, Noise: 109 dB
Homebridge - Siri integration
Re: Sunset in function  [Solved]
robbert1977 wrote: Friday 29 May 2020 8:33 Just to check if there is an easier way.
Not necessarily smarter. But making use of what others invented for this. :)
        local lz = dz.utils.leadingZeros
        local hours, minutes = minutesToTime(dz.time.sunsetInMinutes)
        print (lz(hours, 2) .. ':' .. lz(minutes, 2))
        local hours, minutes = minutesToTime(dz.time.sunriseInMinutes)
        print (lz(hours,2) .. ':' .. lz(minutes,2))
robbert1977
thnx that helps :)
Yes it definitely helps..
mine had a flaw that it only worked on whole numbers ..
could solve that easily with decimals checked but this is much easier :P
Raspberry Pi 4
