Meteo handler 3.0.6 regression?  [Solved]
Number8
Domoticz version: 2022.1
Post by Number8 »
Hello
I noticed a new error in the log file that was not in 3.0.4
2020-05-23 23:33:00.545 Error: dzVents: Error: (3.0.6) An error occurred when calling event handler meteo
2020-05-23 23:33:00.545 Error: dzVents: Error: (3.0.6) ...domoticz/dzVents/runtime/device-adapters/wind_device.lua:27: attempt to perform arithmetic on a string value (local 'speed')
Debian buster on NUC and three RPi with buster.
Re: Meteo handler 3.0.6 régression?
Number8 wrote: Saturday 23 May 2020 23:49 Hello
The last update of this device adapter was with the update to 2.4.22 on May 26 2019.
If you see this error you are feeding the updateWind method a string as third parameter.
Number8
Re: Meteo handler 3.0.6 regression?  [Solved]
Post by Number8 »
You're right. There has been a change in the JSON data
