Dashticz - v3.4.9 beta
Lokonli
Post by Lokonli »
Another small bugfix release, which might result in breaking changes:
In case you have defined a block with as key 'myblock' for Domoticz device 123 as follows:
    blocks['myblock'] = {
        idx: 123,
        width:4
then this will have the following consequences:
* The block will have the CSS class '.block_myblock' and not '.block_123'. You may have to change something in 'custom.css'
* On device change the function 'getStatus_myblock(block)' in custom.js will be called, and not 'getStatus_123(block)'
In case device 123 has subdevices:
* They will receive the CSS class '.block_myblock_1', '.block_myblock_2', etc. and not '.block_123_1'.
* The block settings of 'blocks['myblock_1']' and 'blocks['myblock_2]' etc. will be applied, not the block settings of 'blocks['123_1']
I've updated the documentation in the beta branch for this. See:
Release notes
Subdevices
custom.js
custom.css
Jimster
Re: Dashticz - v3.4.9 beta
Post by Jimster »
Great Lokonli.
I noticed the week starts on Monday now for Dutch, which is great.
But the bars are still not calculated correctly for the week view. The bar from this week (May 25th) contains data from Sunday. So I think somehow the calculation is still based on weeks starting on Sunday.
Some other things I found:
The garbage calendar now shows 'tomorrow' instead of 'Morgen'.
Edit: seems a browser issue, works fine on my phone.
I have a block named 'regen'.
I changed the custom.css to .block_regen, but this didn't work. I found out I have to name it .block_regen_undefined
Lokonli
Post by Lokonli »
The '.block_regen_undefined' is my mistake: Should be fixed already in latest beta.
I'll check the graph calculation.
Further, at some places title and values got switched. I've fixed that, but that could mean you have to switch them back again ...
HansieNL
Post by HansieNL »
Now I can remove a lot of addClass parameters from the blocks. :D
Blah blah blah
Jimster
Post by Jimster »
The device type 'Thermostat' is ignoring the title setting. Now it uses the name in Domoticz.
blocks['Tado-temp'] = {
  idx: 5,
  width: 6,
  title: 'Doeltemperatuur',
Vomera
Post by Vomera »
Yesterday i started to upgrade from 3.4.0 to 3.4.8
I had much to do with the custom.js, but everything works.
So i saw today there was 3.4.9 and i see many things from the custom.css doesnt work any more.
3.4.8 the buttons looks like this : No titles (i coded it like this in the custom.css and and in the config.js
I did not change anything and upgrade to 3.4.9
Also other blockes doesnt change, for example bigger titles.
I posted some code what is displayed in the screenshot
config.js
blocks['s3'] = {} // woonkamer alles aan
blocks['s3']['width'] = 2;
blocks['s3']['title'] = '';
blocks['s3']['icon'] = 'fas fa-toggle-on';
blocks['s3']['hide_data'] = true;
blocks['s10'] = {} //woonkamer uit
blocks['s10']['width'] = 2;
blocks['s10']['hide_data'] = true;
blocks['s10']['icon'] = 'fas fa-toggle-off';
blocks['s10']['title'] = '';
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_12',[b]'s3','s10','s4','s1',11094,690,[/b]'blocktitle_10',5079,3509,'longfonds','blocktitle_10','s8','s9','blocktitle_10',11066,7261,3286,3570,7367,'7344_1','blocktitle_10',10925,10926,10921,10922,'blocktitle_10',6973,6972,6974]
columns[1]['width'] = 4;
Another example
3.4.8
3.4.9
config.js
blocks[3962] = {} //buienradar voorspelling
blocks[3962]['title'] = '';
blocks[3962]['width'] = 12;
columns[3] = {}
columns[3]['blocks'] = [frames.buienradar,[b]3962[/b],3960,buttons.autovoor]
columns[3]['width'] = 4;
custom.css
/* Regenmelding groter maken */
.block_3962 .title {
  font-size: 25px !important;
  position: relative;
  bottom: 15px;
  left: 16px;
.block_3962
  margin-left:7px;
  width:96%;
I checked the documentation, but i dont use the custom key..
When i update, i download the whole beta branch and i always manual overwrite the files what i use
gielie
Domoticz version: latest β
Post by gielie »
@ Lokonli
The following code doesnt work anymore on my system in the latest beta
unction getBlock_233(device,idx){ //change 233 to the idx of your device!
   $('.block_'+idx).attr('onclick','switchDevice(this)');
   var html='';
   html+='<div class="col-xs-4 col-icon">';
      if(device['Status']=='Off') html+=iconORimage(idx,'fas fa-toggle-off','','off icon');
      else html+=iconORimage(idx,'fas fa-toggle-on','','on icon');
   html+='</div>';
   html+='<div class="col-xs-8 col-data">';
   html+='<strong class="title">'+device['Name']+'</strong><br />';
   if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
   else html+='<span class="state">AANWEZIG</span>';
   if(showUpdateInformation(idx)) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(settings['timeformat'])+'</span>';
   html+='</div>';
   return html;
the code is from this wiki page https://dashticz.readthedocs.io/en/mast ... omjss.html
Can you help me solve this one, the problem is that i wont get the afwezig/aanwezig istead of the on/off and the date/time when its changed, in fact the dashticz page wont load right if i use the code.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Lokonli
Post by Lokonli »
Jimster wrote: Tuesday 26 May 2020 9:25 The device type 'Thermostat' is ignoring the title setting. Now it uses the name in Domoticz.
  idx: 5,
  width: 6,
ok, noted. Will be fixed.
Lokonli
Post by Lokonli »
Vomera wrote: Tuesday 26 May 2020 13:21 Yesterday i started to upgrade from 3.4.0 to 3.4.8
config.js
columns[1] = {}
Another example
3.4.8
3.4.9
config.js
columns[3] = {}
custom.css
  position: relative;
  bottom: 15px;
  left: 16px;
.block_3962
  margin-left:7px;
  width:96%;
ok, I admit, 3.4.9 was not the best release :(
Usage of empty strings as title didn't work anymore. Will be fixed.
Further, title and value were mixed up at several places.
I'm now changing it in such a way that title will be the device name, unless a title parameter has been provided in the block definition.
The value will be the value of the device.
If you add the 'switch' parameter, then title and value will be switched on the screen.
(and I still have to decide whether I will switch the css classes then as well...)
So for you that could mean you have to replace '.block_3962 .title ' by '.block_3962 .value'. But wait for the next update first.
Lokonli
Post by Lokonli »
gielie wrote: Tuesday 26 May 2020 14:37 @ Lokonli
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
Try the documentation of the beta branch:
https://dashticz.readthedocs.io/en/beta ... -idx-block
Vomera
Post by Vomera »
Lokonli wrote: Tuesday 26 May 2020 16:06
config.js
columns[1] = {}
Another example
3.4.8
3.4.9
config.js
columns[3] = {}
custom.css
  position: relative;
  bottom: 15px;
  left: 16px;
.block_3962
  margin-left:7px;
  width:96%;
Okay then i'm sure i didnt do anything wrong haha. im still using the 3.4.0 version instead before i everthing works with the newer versions, so take your time. i really appreciate you doing this in your time :)
HansieNL
Post by HansieNL »
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
@gielie I'm using the block parameters to change the on/off text:
blocks['thuis'] = {
	idx: 6,
	textOff: 'AFWEZIG',
	textOn: 'AANWEZIG',
	icon: 'fas fa-home',
Blah blah blah
Lokonli
Post by Lokonli »
I've just created 3.4.9.1-beta.
Most annoying bugs should be fixed.
Main goal of the latest releases is to clean up the code, and improve the consistency in behavior. This is necessary to improve the maintainability of the code, as you've noticed. But it's getting better step by step :)
It's almost impossible for me to test all device types with all settings at every code update. So I trust on you for willing to test the beta releases.
Focus now is on solving the remaining bugs. I expect we are close to releasing a new master. After that we will start working on adding functionality again.
gielie
Post by gielie »
HansieNL wrote: Tuesday 26 May 2020 17:26
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
blocks['thuis'] = {
	idx: 6,
	textOff: 'AFWEZIG',
	textOn: 'AANWEZIG',
This is even a simpler solution, thanks for the tip.
Now I have to change all my blocks to this new format, well keeps a man busy these days.
I also noticed something changed with the camera settings, I don't have a moving video anymore only a static picture and it won't refresh (only on f5)
- FIBARO FGS223
- Toon
- Kodi Media Server
Vomera
Post by Vomera »
config.js
columns[1] = {}
Another example
3.4.8
3.4.9
config.js
columns[3] = {}
custom.css
  position: relative;
  bottom: 15px;
  left: 16px;
.block_3962
  margin-left:7px;
  width:96%;
Okay i updated to 3.4.9.1 almost everything works, but still not the CSS part (making text bigger or change it with css), so i have to wait for your small update again ? or should i change the .tilte to .value ? :)
HansieNL
Post by HansieNL »
@Vomera Have you already tried to add switch: true, to the block?
To remove the old title (which is the new value then) you can try:
.block_3962 .value {
    display: none !important;
Blah blah blah
Vomera
Post by Vomera »
Everything seems to back and working, only the graph i have to remove the tilte and stuff, i do that later, its just a line in the graph.js.
Lokonli
Post by Lokonli »
Vomera wrote: Wednesday 27 May 2020 14:33 Okay i updated to 3.4.9.1 almost everything works, but still not the CSS part (making text bigger or change it with css), so i have to wait for your small update again ? or should i change the .tilte to .value ? :)
I will keep the code as-is.
Currently title is the name of the device and value is the value of the text device. That's most logical I would say.
As already indicated by @HansieNL you could add the 'switch' parameter if you want to switch block and title.
if you add switch: true the CSS classes will not switch, meaning the first row will still have the CSS class .title attached to it, but it will show the content of the text device. This behavior is consistent for all (?) blocks.
jake
Post by jake »
While cleaning up code and straightening out differences between several devices types, please have a look on the '.' symbol that separates the 1000 numbers. The one device type has it, others don't have it.
Vomera
Post by Vomera »
Okay i can see everything is working fine now , so in the next days i can check if every button responds now.
I was wondering if longfonds can also change by color if it get a certain value. Because many things changed in the last versions
https://www.domoticz.com/forum/viewtopi ... ds#p236662
Edit:
Also another question. I see there is an option for a customheader in the graph.
I have a temp sensor from outside. The only thing what i want to display in the header is the temp Min and temp Max from this day. from 00:00 till 23:59. Is that possible ?
edit2:
To disable the custom header on the wiki page there is formatted:
.graph_header {
  display: none;
but its:
.graphheader {
  display: none;
