aWattar integration
multifluid
aWattar integration
Post by multifluid »
There is a power provider (aWATTar) in Germany who charges by hourly power consumption. The fee is partly fixed and gets a variable on top driven by the price per kWh on the stock market. The price on the stock market can even be negative if there is too much power available. Only green energy is used.
The price will be announced 24h in advance so you can charge your car or switch on the washing machine base on the kWh price.
The API is availbale here https://www.awattar.de/services/api (German only).
Let me know you thoughts.
Thanks,
Multi
elmortero
Domoticz version: 3.9639
Re: aWattar integration
Post by elmortero »
Depends on how you would want to use it, but following dzvents script will fetch the value for now+24h
If what you want is to get it for the next x hours, some adaptations will be needed.
		timer = { 'every hour'},
		httpResponses = { 'aWATTar' } -- matches callback string below
	execute = function(domoticz, triggerItem)
    local WanIp = domoticz.devices('WanIp')
    local prevWanIP = tostring(WanIp.text)
		if (triggerItem.isTimer) then
			domoticz.openURL({
				url = 'https://api.awattar.de/v1/marketdata',
				method = 'GET',
				callback = 'aWATTar'
		elseif (triggerItem.isHTTPResponse) then
	local response = triggerItem
		if (response.ok and response.isJSON) then
		local price = tostring(response.json.data[24].marketprice)
        print('IN 24 hours the cost will be '..price..' Eur/MWh')
        -- do here other stuff
				print('**getip failed to fetch info')
This script just gets the value and prints it to the log, but of course you can add any action - given it's possible in domoticz 8) - to it.
multifluid
I guess, I need to learn how to use dzvents for this. :?
The API will only provide once per day the values for the next day. I would like to set a threshold under which a switch or my e car charger would be turned on.
In this example, I'd say, switch on when less than zero.
elmortero
Post by elmortero »
So basically you want:
  • You have a switch to start charging the car
  • Read the content of https://api.awattar.de/v1/marketdata which returns a json
  • From that json, find the time where the price is the lowest (in current data I don't see negative values, but anyways, the lowest
  • Then with that time create a timer on the switch that switches on at the time we fetched above
Is that about right?
What if the car is not connected at the time?
What if non of the rates is below the threshold? Do you then not charge it?
multifluid
elmortero wrote: Wednesday 27 May 2020 16:53 So basically you want:
    Yes, already working with Domoticz.
    Yes
    Either the lowest or a value you can set. I will need to learn the data myself over time.
    Yes
If the car is not connected, it will not get charged, no problem.
Right, it might be only some hours per week where the set criteria is true. Therefore the threshold need to be adjustable.
Yep, that sounds right.
Thanks,
Multi
elmortero
Post by elmortero »
Hi, this is what I came up with.
I am putting comments outside of the code to keep it clean.
The time to run the script is set to 23:55 - in fact any time between 23:01 and 23:59 should be ok - so that it does not mess with schedules. If you should run it for example at 0:01 and the cheapest time is between 0:00 and 1:00 the timer will be set for that timeframe BUT the day after.
This script is for the lowest value, you need to decide if you want the to use a threshold, it changes the way how (or rather how far) we need to iterate over the results. In that case the logical way would be to look through the prices and it will stop at the first price that is below threshold, stop there and use that timeframe for the schedule of the charger switch.
For learning purposes - you are right, you should get into understanding dzvents a bit (for adaptations, troubleshooting...) - I have not used special functions / objects(without this disclamer I might get a slap on the wrist from dannybloe 8-) ) so that it is an easy start for you.
What we do is :
  • Define the idx of your switch that needs to be scheduled (your charger)
  • Set the url to your domoticz instance, here it is http://192.168.x.x:8080 but you should of course put the IP address for your domoticz and the port number too
  • Set the time when the script will run, as you said one time a day, here it is set to 23:55
  • The api url is being opened, due to Asynchronous_HTTP_Request (at some point you should study that, in case you change provider, the url changes..)
  • We then wait for domoticz to trigger the callback event --> the url was opened and we got a response, the script gets triggered again and continues to go through the results
  • We set low_time = ''; low_price = 999 --> the cheapest time (empty because we don't know yet and the lowest price --> extremely high you will see why
  • An url is created based on your switch IDX to clear all schedules it might have !! This is important to know if you already use a schedule, it will be removed at this point. Should not be an issue if you are going to let this script decide when to charge
  • Then we go through the results one by one and check if the price is lower than the initial 999 (which it will be hopefully for our lifetime), if that is the case the variable low_price is updated with that price and we set the time (low_time) to the corresponding time
  • This goes on for all results and in the end the value of low_price will contain the value we are looking for with the matching timeframe
  • Then we create a url - that we will call later - with the time from low_time
  • Next we open the url so that for the switch defined by IDX (on the very first line of the script)
You must, sorry for the imperative form, read: Using dzVents with Domoticz, especially the first paragraph and of course the part on how to create a dzvents script.
Last, but not least, you should know I did some testing, not too much (I wrote the script an hour ago, spending more explaining that it took to write the actual code) but you might want to let it run dry for a while. You could create a virtual switch or put the IDX of a light at first to see if it activates on the correct time. Also, you will notice there will not be a schedule for switch off. I don't know how these (or yours) car chargers work, I assume they stop charging as soon as the battery is fully charged, and if you switch it of (in domoticz) when you disconnect. If you know how long (maximum) it takes to charge we could add a schedule to switch of at (starttime + max charge time)
local IDX = 'XXX'
local domo_url = 'http://192.168.x.x:8080'
		timer = { 'at 23:55'},
			domoticz.openURL({
				method = 'GET',
        		sched_clr = domo_url..'/json.htm?type=command&param=cleartimers&idx='..IDX
        		domoticz.openURL(sched_clr)
        	    t = 1
        	    repeat
            		local raw_start_time = (response.json.data[t].start_timestamp) /1000
            		date = os.date("*t",raw_start_time)
            		hora = (tostring(date.hour)..':00')
            		local price = tonumber(response.json.data[t].marketprice)
                		if price < low_price then
                		    low_price = price
                		    low_time = hora
                		    low_hora = tostring(date.hour)
            		t = t +1
                until t > 24
                print(low_time..' has the lowest price: '..low_price)
                sched_set =  domo_url..'/json.htm?type=command&param=addtimer&idx='..IDX..'&active=true&timertype=2&hour='..low_hora..'&min=0&randomness=false&command=0&days=0'
                domoticz.openURL(sched_set)
				print('**aWATTar failed to fetch info')
multifluid
Wow, I'm really impressed with your support!
Give my some time (couple of days) to get into the weeds of dzVents and your guide.
Thanks again for now
Multi
multifluid
Okay, some first feedback. The script is running, I changed some things with some other help. I adjusted the IPX, the timing and the trigger value. Now I will monitor how the switching works. No further questions for now.
Thanks again alot!
Multi
mgerhard74
Post by mgerhard74 »
Hello ,
does this script still working in domoticz 2022.2?
I got this in log
2023-01-21 11:30:05.647 Status: dzVents: Info: ------ Start internal script: aWattar:, trigger: "every minute"
2023-01-21 11:30:05.647 Status: dzVents: Info: ------ Finished aWattar
...but i got no new schedule in the switch IDX 141.
I use this simple code for test, but i get no result "start_timestamp":
		timer = { 'every minute'},
    	    starttime = os.time(os.date('*t')) * 1000
	        stoptime = (os.time(os.date('*t')) + 86000) * 1000
	        print('Start: '..tostring(starttime)..', Stop: '..tostring(stoptime))
			domoticz.openURL({
				url = 'https://api.awattar.de/v1/marketdata?start='..tostring(starttime)..'&' .. 'end='..tostring(stoptime)..'',
				method = 'GET',
        elseif triggerItem.isHTTPResponse then
        if (response.ok) then
        	print(response.json.data[1]['start_timestamp'])
Gerhard
Domoticz version: 2026.3
Perhaps the json from aWattar has changed?
Nothing really big has changed on dzVents the last releases.
I tested a simple version of the original script not updating schedules and devices, only logging and it works without problems.
			domoticz.openURL({
				method = 'GET',
        	    t = 1
        	    repeat
                		    low_price = price
                		    low_time = hora
            		t = t +1
                until t > 24
2023-01-21 17:07:00.122 Status: dzVents: Info: ------ Start internal script: awattar test:, trigger: "every minute"
2023-01-21 17:07:00.122 Status: dzVents: Info: ------ Finished awattar test
2023-01-21 17:07:00.435 Status: dzVents: Info: Handling httpResponse-events for: "aWATTar"
2023-01-21 17:07:00.436 Status: dzVents: Info: ------ Start internal script: awattar test: HTTPResponse: "aWATTar"
2023-01-21 17:07:00.437 Status: dzVents: 2:00 has the lowest price: 116.77
2023-01-21 17:07:00.437 Status: dzVents: Info: ------ Finished awattar test
mgerhard74
Thank you for testing, i used your script and i got only:
2023-01-21 17:15:43.634 Status: dzVents: Info: ------ Start internal script: aWattar:, trigger: "every minute"
2023-01-21 17:15:43.634 Status: dzVents: Debug: OpenURL: url = https://api.awattar.de/v1/marketdata
2023-01-21 17:15:43.635 Status: dzVents: Debug: OpenURL: method = GET
2023-01-21 17:15:43.635 Status: dzVents: Debug: OpenURL: post data = nil
2023-01-21 17:15:43.635 Status: dzVents: Debug: OpenURL: headers = nil
2023-01-21 17:15:43.635 Status: dzVents: Debug: OpenURL: callback = aWATTar
2023-01-21 17:15:43.635 Status: dzVents: Info: ------ Finished aWattar
2023-01-21 17:15:43.635 Status: dzVents: !Info: Debug: Writing module summary to /home/pi/domoticz/scripts/dzVents/module.log
2023-01-21 17:15:43.635 Status: dzVents: Debug: Commands sent to Domoticz:
2023-01-21 17:15:43.636 Status: dzVents: Debug: - OpenURL = {["_trigger"]="aWATTar", ["method"]="GET", ["URL"]="https://api.awattar.de/v1/marketdata"}
2023-01-21 17:15:43.636 Status: dzVents: Debug: =====================================================
Perhaps make callback and httpresponse value (now 'aWattar') different from your normal script. DzVents normally needs these to be unique for each script.
It seems that "triggerItem.isHTTPResponse" is not working.
mgerhard74
Thank you helping me to solve this problem. After changing 'aWattar' to 'WATT' it is working perfekt.
This is not clear for me, because it is my first and only DzVents script - maybe it was a problem, because my new switch has the name 'aWattar'.
mgerhard74
no HTTPResponse?
My Awattar script normally runs once per day (14:03), but in most cases, it did not correct finish.
Log:
return { on =
    {timer =
        { 'at 14:03'},
        httpResponses = { 'WATT' }
		domoticz.openURL({
		    url = 'https://api.awattar.at/v1/marketdata',
		    method = 'GET',
		    callback = 'WATT'
        	    t = 1
        	    repeat
                    if response.json.data[t].start_timestamp ~= nil then
            		    print ('Stunde: '..tostring(hora)..', Preis: '..tostring(price))
                		        low_price = price
                		        low_time = hora
                		        if (date.hour+1) == 24 then
                		            low_hora_off = '1'
                		            low_hora_off = tostring(date.hour+1)
            		t = t + 1
                until t>24
                domoticz.variables('aWattarTime').set(low_hora..':00')
                domoticz.variables('aWattarPrice').set(low_price)
                print('Um '..low_time..' Uhr gibts den niedrigsten Preis der nächsten 24h: '..low_price..' Eur/MWh')
Can anyone find the issue?
Just put some more logging in the script to debug where it fails.
If this is the only thing logged it like the response is not as expected (not ok or not a JSON)
mgerhard74
The problem is that triggerItem.isHTTPResponse is always "false".
As i checked with Firefox the https://api.awattar.at/v1/marketdata returns a content-type application/json; charset=utf-8.
The Api is described at https://www.awattar.at/services/api
Domoticz V2023.1 on a Raspi 3B Raspbian 10 Buster, dzvents 3.1.8
Is there a bug at https://api.awattar.at/v1/marketdata or in dzvents recognize not a application/json???
			domoticz.openURL({
				method = 'GET',
        print ('triggerItem.isHTTPResponse:  ' .. tostring(triggerItem.isHTTPResponse));
        	    t = 1
        	    repeat
                		    low_price = price
                		    low_time = hora
            		t = t +1
                until t > 12
The test script I used before in this thread is still working on my system (2023.1)
So if that is also still working on yours check the differences. Be aware of the callback names.
