Today I installed a xiaomi curtain motor and this works very well with domoticz. Only problem is that I use a type 'blinds percentage' . When I use the slider it works perfect but if I clic on the switch when I want my curtain 100% open or close nothing happens. Only when I use the slider it works.
1-99% works but 0 or 100% don't. I use this switch also in homebridge with edomoticz so this isn't very handy. I do can change my switch to open/close but I want both: and a slider and open/close (100%). Is there an solution for this?
Xiaomi curtain motor
Re: Xiaomi curtain motor
Could you clarify which gateway you use ?
The Xiaomi one, deConz, zigate ..,,
remko2000
I use the xiaomi gateway 2.
ABCArt
Same problem using zigbee2mqtt with zigbee stick and aqara motors.
"Blinds percentage" works only with slider on floorpaln, clickin on icon always switches it off (opening curtains if they are already closed, but not closing them after that), not toggling on/off.
And if i click on "open" or "close" icons on this switch in "switches" section (not on floorplan) - everything works great.
So the problem is only in icon on the floorplan.
