I have a Ilyama Touchscreen in the kitchen on which I Dashticz visualisize - but if nobody is home - I switch off the screen with tvservice -o
With DZevent I run (on motion in the kitchen) the script which enables the touchscreen with tvservice -p - screen turns on but stays black.
on ssh command I run DISPLAY=:0 xdotool mousemove 100 100 2 times and this works - now I add these commend in the Dzevent script as a screenon.sh bas script and as wel as stand alone os.execute lines - but both ways doesn't work. When I start the bash script with blocky I get the 256 error, by adding > /dev/null 2>&1 & the error disapears but still doesn't work
bash script
#!/bin/bash
#Touchscreen Off
tvservice -p
sleep 5
DISPLAY=:0 xdotool mousemove 10 100
sleep 3
DISPLAY=:0 xdotool mousemove_relative 10 100Code: Select all
devices = {
'SimMuis'
os.execute("/home/pi/domoticz/scripts/bash-on.sh")
Thank you in advance for your help and support
Peter
