Humidity Increase
hanskenpensken
Humidity Increase
Post by hanskenpensken »
I'm still in the learning phase.
But i can't figure out how i can get this wiki DzVents example to get to work.
The script
    on =
        timer = {'every 5 minutes'}
    data =
        previousHumidity = { initial = 100 }
    execute = function(domoticz)
        local bathroomSensor = domoticz.devices('SensorBerging')
        if (bathroomSensor.humidity - domoticz.data.previousHumidity) >= 5) then
            -- there was a significant rise
            domoticz.devices('DampkapLicht').switchOn()
        -- store current value for next cycle
        domoticz.data.previousHumidity = bathroomSensor.humidity
    nd
The error
2020-05-18 21:36:11.480 Error: dzVents: Error: (3.0.2) error loading module 'Script #1' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Script #1.lua':
2020-05-18 21:36:11.480 ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:1: unexpected symbol near '{'
Is here a setting i'm getting wrong?
niki_lauda
Re: Humidity Increase
Post by niki_lauda »
return (in line 1)
And
if (bathroomSensor.humidity - domoticz.data.previousHumidity) >= 5 then
And
in the last line!
hanskenpensken
Hi there,
apparently there is a typo in the wiki-example nd needs to be end.
However, i'm still getting the error
return
    on =
    data =
        if (bathroomSensor.humidity - domoticz.data.previousHumidity) >= 2) then
The error is still at line 13
"if (bathroomSensor.humidity - domoticz.data.previousHumidity) >= 2) then"
'then' expected near ')'
hanskenpensken wrote: Tuesday 19 May 2020 8:19 I'm still getting the error
If you remove the ) after >= 2
it should work
