I finished the V1 code today.
Tested it for 24hours now. Works for me stable.
The wifi test is done. Let the device trying for 15 minutes, to connect to a non available ssid. After that i made the ssid available and it connected. Same test for MQTT.
The ledPin1 is ON at standby, 2x flash after that pause = wifi error, 4x flash after that pause = mqtt error
WS2812 rgb is not supported. The RGB is 4-pin LED in 1 housing (sorry, don't know the type)
Webserver to show all settings you made and 4 hyperlinks for the functions is not added.
Somehow this let the esp crash after a few hours running. Removed that part of the script, this will be a future project and will be back in V2.
#include "esp_camera.h"
#include <WiFi.h>
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
#include "fb_gfx.h"
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_http_server.h"
#include <PubSubClient.h>
#ifndef MQTT_MAX_PACKET_SIZE
#define MQTT_MAX_PACKET_SIZE 512
#endif
#include <HTTPClient.h>
//** Welke URL worden aangemaakt **
// http://IP/stream = live camera stream
// http://IP/capture = capture image
// http://IP/on = switch ledPin1 on (light from flash button, or standby light from rgb button)
// http://IP/off = switch ledPin1 off (light from flash button, or standby light from rgb button)
// The idea about the last 2 functions, is to disable the led in the button at night situation.
//** START SETTINGS START **
//** Setting Wifi credentials **
const char* ssid = "Wifi-SSID"; //Wifi SSID waarop ESP32-cam zich moet aanmelden.
const char* password = "Wifi-password"; //Bijbehorend wachtwoord welke bij het gekozen SSID behoort.
//** IP settings device **
//#define FixedIP //Haal de // weg om fixed IP te gebruiken, anders staat deze op DHCP.
#define IPaddr 192,168,***,*** //Voer IP adres is, digits tussen komma's invoeren.
#define SubnetAddr 255,255,255,0 //Voer subnet mask in, digits tussen de komma's invoeren.
#define GatewayAddr 192,168,***,*** //Voer Gateway adres in, digits tussen de komma's invoeren.
//Als device geen internet nodig heeft, voer een fake gateway in.
//** Setting Domotcz credentials **
String DomoticzIP = "192.168.***.***"; //Domoticz Server IP adres.
String DomoticzPort = "8080"; //Domoticz Server poort adres.
#define DomoticzIDX "***" //Domoticz IDX nummer welke geschakeld moet worden.
String DomoticzSwitch = "On"; //Domoticz IDX state. Bij activeren ingang, moet IDX dan On of Off gestuurd worden?
#define DomoticzResetSwitch //Haal de // weg, dan wordt er een tegengesteld commando van DomoticzSwitch gestuurd
//** Setting Domoticz data-signal **
#define DomoticzHttpJson //Haal // weg om HTTP/JSON commando te gebruiken naar Domoticz
//#define DomoticzMQTT //Haal // weg om MQTT commando te gebruiken naar Broker/Domoticz
//** Setting MQTT **
const char* mqtt_server = "192.168.***.***"; //MQTT Broker IP adres
#define mqtt_port 1883 //MQTT Broker port adres
#define MQTT_USER "" //MQTT username
#define MQTT_PASSWORD "" //MQTT password
const char* Subscriber = "ESP32CAM/Input"; //MQTT Subscriber name
const char* topicin = "domoticz/in"; //MQTT Topic name
// For switching ledPin1 ON, payload = on
// For switching ledPin1 OFF, payload = off
//** Setting PUSH button **
#define FlashButton //Verwijder de // om Button met enkele LED te gebruiken
// #define RgbButton //Verwijder de // om RGB LED Button te gebruiken
const int buttonPin1 = 12; //GPIO nummer voor de ingang van drukknop.
#define ButtonTimer 10000 //De tijd dat LED aangestuurd is.
//** Setting LED button **
const int ledPin1 = 13; //ledPin1 is gebruikt voor flashbutton en standby licht RGB knop
const int ledPin2 = 14; //ledPin2 schakelt bij drukken RGB knop
const int ledPin3 = 15; //ledPin3 schakelt bij drukken RGB knop
//** Setting Camera type **
#define CAMERA_MODEL_AI_THINKER
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WITHOUT_PSRAM
// Not tested with this model
//#define CAMERA_MODEL_WROVER_KIT
//** END SETTINGS END **
char msgToDomoticZ[120];
const char* msgContact = "{\"command\": \"switchlight\", \"idx\": ";
const char* msgContactOn = ", \"switchcmd\": \"On\"}";
const char* msgContactOff = ", \"switchcmd\": \"Off\"}";
int buttonState1 = 0;
String ledState;
WiFiClient wifiClient;
PubSubClient client(wifiClient);
unsigned long check_wifi = 30000;
int repeatflash;
#define PART_BOUNDARY "123456789000000000000987654321"
typedef struct {
httpd_req_t *req;
size_t len;
} jpg_chunking_t;
static size_t jpg_encode_stream(void * arg, size_t index, const void* data, size_t len){
jpg_chunking_t *j = (jpg_chunking_t *)arg;
if(!index){
j->len = 0;
if(httpd_resp_send_chunk(j->req, (const char *)data, len) != ESP_OK){
return 0;
j->len += len;
return len;
#if defined(CAMERA_MODEL_WROVER_KIT)
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 21
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 19
#define Y4_GPIO_NUM 18
#define Y3_GPIO_NUM 5
#define Y2_GPIO_NUM 4
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
#define RESET_GPIO_NUM 15
#define XCLK_GPIO_NUM 27
#define SIOD_GPIO_NUM 25
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 19
#define Y8_GPIO_NUM 36
#define Y7_GPIO_NUM 18
#define Y6_GPIO_NUM 39
#define Y5_GPIO_NUM 5
#define Y4_GPIO_NUM 34
#define Y3_GPIO_NUM 35
#define Y2_GPIO_NUM 32
#define VSYNC_GPIO_NUM 22
#define HREF_GPIO_NUM 26
#define PCLK_GPIO_NUM 21
#elif defined(CAMERA_MODEL_M5STACK_WITHOUT_PSRAM)
#define Y2_GPIO_NUM 17
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define XCLK_GPIO_NUM 0
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#else
#error "Camera model not selected"
#endif
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t stream_httpd = NULL;
static esp_err_t stream_handler(httpd_req_t *req){
camera_fb_t * fb = NULL;
esp_err_t res = ESP_OK;
size_t _jpg_buf_len = 0;
uint8_t * _jpg_buf = NULL;
char * part_buf[64];
res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
if(res != ESP_OK){
return res;
while(true){
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("------- New message: Camera failure -----");
Serial.println("Camera capture failed");
Serial.println("");
res = ESP_FAIL;
} else {
if(fb->width > 400){
if(fb->format != PIXFORMAT_JPEG){
bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
esp_camera_fb_return(fb);
fb = NULL;
if(!jpeg_converted){
Serial.println("------- New message: JPEG Compression -----");
Serial.println("JPEG compression failed");
Serial.println("");
res = ESP_FAIL;
} else {
_jpg_buf_len = fb->len;
_jpg_buf = fb->buf;
if(res == ESP_OK){
size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
if(fb){
fb = NULL;
_jpg_buf = NULL;
} else if(_jpg_buf){
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
break;
//Serial.printf("MJPG: %uB\n",(uint32_t)(_jpg_buf_len));
return res;
static esp_err_t on_handler(httpd_req_t *req){
#define OKon "HTTP/1.1 200 OK, Output On"
httpd_resp_send(req, OKon, strlen(OKon));
GpioVarOn();
static esp_err_t off_handler(httpd_req_t *req){
#define OKoff "HTTP/1.1 200 OK, Output OFF"
httpd_resp_send(req, OKoff, strlen(OKoff));
GpioVarOff();
static esp_err_t capture_handler(httpd_req_t *req){
int64_t fr_start = esp_timer_get_time();
if (!fb) {
Serial.println("------- New message: Camera capture failure -----");
Serial.println("");
httpd_resp_send_500(req);
return ESP_FAIL;
httpd_resp_set_type(req, "image/jpeg");
httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
size_t out_len, out_width, out_height;
uint8_t * out_buf;
bool s;
size_t fb_len = 0;
if(fb->format == PIXFORMAT_JPEG){
fb_len = fb->len;
res = httpd_resp_send(req, (const char *)fb->buf, fb->len);
} else {
jpg_chunking_t jchunk = {req, 0};
res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk)?ESP_OK:ESP_FAIL;
httpd_resp_send_chunk(req, NULL, 0);
fb_len = jchunk.len;
int64_t fr_end = esp_timer_get_time();
Serial.println("------- New message: Camera capture return -----");
Serial.printf("JPG: %uB %ums\n", (uint32_t)(fb_len), (uint32_t)((fr_end - fr_start)/1000));
Serial.println("");
return res;
void startCameraServer(){
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
config.server_port = 80;
httpd_uri_t stream_uri = {
.uri = "/stream",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
httpd_uri_t capture_uri = {
.uri = "/capture",
.method = HTTP_GET,
.handler = capture_handler,
.user_ctx = NULL
httpd_uri_t on_uri = {
.uri = "/on",
.method = HTTP_GET,
.handler = on_handler,
.user_ctx = NULL
httpd_uri_t off_uri = {
.uri = "/off",
.method = HTTP_GET,
.handler = off_handler,
.user_ctx = NULL
//Serial.printf("Starting web server on port: '%d'\n", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(stream_httpd, &stream_uri);
httpd_register_uri_handler(stream_httpd, &on_uri); //voor LED ON
httpd_register_uri_handler(stream_httpd, &off_uri); //voor LED OFF
httpd_register_uri_handler(stream_httpd, &capture_uri); //Still image capture
void GpioVarOn() {
Serial.println("------- New message: GpioVarON -----");
Serial.println("Output On");
Serial.println("");
digitalWrite(ledPin1, HIGH);
void GpioVarOff() {
Serial.println("------- New message: GpioVarOFF -----");
Serial.println("Output Off");
Serial.println("");
digitalWrite(ledPin1, LOW);
void RgbBut(){
Serial.println("------- New message: RGB Button start -----");
Serial.println("Start RGB Button Pushed");
Serial.println("");
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin3, HIGH);
#if defined(DomoticzHttpJson)
Serial.println("------- New message: RGB Button HTTP/JSON Command -----");
Serial.println("Send HTTP/JSON command to Domoticz for switch controle");
Serial.println("");
HTTPClient http;
String url="http://" + DomoticzIP + ":" + DomoticzPort + "/json.htm?type=command¶m=switchlight&idx=" + DomoticzIDX + "&switchcmd=" + DomoticzSwitch + "";
http.begin(url); //Specify destination for HTTP request
http.addHeader("Content-Type", "text/plain");
int httpResponseCode = http.POST("POSTING from ESP32");
#elif defined(DomoticzMQTT)
if (DomoticzSwitch == "On") {
Serial.println("------- New message: RGB Button MQTT On Command -----");
Serial.println("Send MQTT command to Domoticz for switch ON");
Serial.println("");
strcpy(msgToDomoticZ, msgContact);
strcat(msgToDomoticZ, DomoticzIDX);
strcat(msgToDomoticZ, msgContactOn);
client.publish(topicin, msgToDomoticZ);
} else {
Serial.println("------- New message: RGB Button MQTT Off Command -----");
Serial.println("Send MQTT command to Domoticz for switch OFF");
Serial.println("");
strcat(msgToDomoticZ, msgContactOff);
#endif
delay(ButtonTimer);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
#if defined(DomoticzResetSwitch)
Serial.println("Send HTTP/JSON command to Domoticz for switch OFF");
Serial.println("");
String url="http://" + DomoticzIP + ":" + DomoticzPort + "/json.htm?type=command¶m=switchlight&idx=" + DomoticzIDX + "&switchcmd=Off";
http.begin(url);
} else {
Serial.println("Send HTTP/JSON command to Domoticz for switch ON");
Serial.println("");
String url="http://" + DomoticzIP + ":" + DomoticzPort + "/json.htm?type=command¶m=switchlight&idx=" + DomoticzIDX + "&switchcmd=On";
http.begin(url);
#endif
Serial.println("Send MQTT command to Domoticz switch OFF command");
Serial.println("");
} else {
Serial.println("Send MQTT command to Domoticz switch ON command");
Serial.println("");
#endif
#endif
Serial.println("------- New message: RGB Button end -----");
Serial.println("End RGB Button Pushed");
Serial.println("");
void FlashBut(){
Serial.println("------- New message: Flash Button start -----");
Serial.println("Start Flash Button Pushed");
Serial.println("");
Serial.println("------- New message: Flash Button HTTP/JSON Command -----");
Serial.println("");
HTTPClient http;
Serial.println("------- New message: Flash Button MQTT On Command -----");
Serial.println("");
} else {
Serial.println("------- New message: Flash Button MQTT Off Command -----");
Serial.println("");
#endif
int Flashcount = (ButtonTimer / 1000) * 2;
for (int i = 0; i <= Flashcount; i++) {
delay(300);
delay(300);
Serial.println("");
http.begin(url);
} else {
Serial.println("");
http.begin(url);
#endif
Serial.println("Send MQTT command to Domoticz switch OFF");
Serial.println("");
} else {
Serial.println("Send MQTT command to Domoticz switch ON");
Serial.println("");
#endif
#endif
Serial.println("------- New message: Flash Button end -----");
Serial.println("End Flash Button Pushed");
Serial.println("");
void startWIFI(void) {
Serial.println("------- New message: Wifi Disconnect -----");
Serial.println("WiFi Disconnected, trying restart connection.");
Serial.println("");
WiFi.disconnect();
delay(5000);
WiFi.begin(ssid, password);
#if defined(FixedIP)
IPAddress ip(IPaddr);
IPAddress gateway(GatewayAddr);
IPAddress subnet(SubnetAddr);
WiFi.config(ip, gateway, subnet);
#endif
while (WiFi.status() != WL_CONNECTED) {
Serial.print(".");
delay(500);
int WaitFlash = 1;
for (int i = 0; i <= WaitFlash; i++) {
digitalWrite(ledPin1, HIGH); // Turn the LED on (Note that LOW is the voltage level
delay(150);
digitalWrite(ledPin1, LOW); // Turn the LED off by making the voltage HIGH
delay(150);
WaitFlash = 1;
Serial.println("Trying reconnect WiFi void startWifi");
Serial.println("");
delay(300);
check_wifi = millis() + 30000;
if (WiFi.status() == WL_CONNECTED) {
Serial.print(".");
Serial.println("WiFi reconnected void startWifi");
delay(500);
void wififlash(){
for (int j = 0; j <= repeatflash; j++) {
int WaitFlash = 1;
delay(150);
delay(150);
WaitFlash = 1;
delay(800);
void reconnect() {
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP32-Cam-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str(),MQTT_USER,MQTT_PASSWORD)) {
Serial.println("connected");
client.subscribe(Subscriber);
} else {
for (int i = 0; i <= 4; i++) {
delay(200);
delay(200);
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void callback(char* topic, byte *payload, unsigned int length) {
Serial.println("------- new message from broker -------");
Serial.print("channel:");
Serial.println(topic);
Serial.print("data:");
Serial.write(payload, length);
Serial.println("");
Serial.println("");
char rawvalue[length];
for (int i = 0; i < length; i++)
//Serial.print((char)payload[i]);
rawvalue[i] = (char)payload[i];
rawvalue[length]= '\0';
String svalue = String((char*)rawvalue);
//Serial.print(svalue);
if (svalue == "on"){
Serial.println("------- New message: MQTT On -------");
Serial.println("Output on by MQTT");
Serial.println("");
if (svalue == "off"){
Serial.println("------- New message: MQTT Off -------");
Serial.println("Output off by MQTT");
Serial.println("");
void setup() {
//WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
pinMode(buttonPin1, INPUT_PULLUP);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
Serial.begin(115200);
Serial.setDebugOutput(false);
Serial.println();
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
if(psramFound()){
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 10;
config.fb_count = 2;
} else {
config.frame_size = FRAMESIZE_VGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// Camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
// Wi-Fi connection
repeatflash = 0;
wififlash();
#endif
repeatflash = 3;
wififlash();
delay(500);
Serial.print(".");
randomSeed(micros());
Serial.println("");
Serial.println("WiFi connected void setup");
Serial.print("Camera Stream Ready! Go to: http://");
Serial.print(WiFi.localIP());
Serial.println("");
#if defined(DomoticzMQTT)
client.setServer(mqtt_server, mqtt_port);
client.setCallback(callback);
reconnect();
#endif
startCameraServer();
void loop() {
buttonState1 = digitalRead(buttonPin1);
if ((WiFi.status() != WL_CONNECTED) && (millis() > check_wifi)) {
startWIFI();
return;
} else {
if (buttonState1 == LOW) {
#if defined(RgbButton)
RgbBut();
#elif defined(FlashButton)
FlashBut();
#endif
if (!client.connected()){
reconnect();
} else {
client.loop();
#endif
