Count not correct  [Solved]
MeAlbert
Domoticz version: 2020.1
Count not correct
Post by MeAlbert »
I have a Heat Pump that has to defrost when the condenser is freezing in. This is recorded in Domoticz with a dummy switch. (off or on)
I want to count the number of defrost in a day in a counter. I found an example of a swith count in the manual like ths:
         devices = { 'MySwitch' }
        data = {
            counter = { initial = 0 }
        execute = function(domoticz, switch)
          if (domoticz.data.counter == 5) then
             domoticz.notify('The switch was pressed 5 times!')
             domoticz.data.counter = 0 -- reset the counter
             domoticz.data.counter = domoticz.data.counter + 1
I changed the code to:
         devices = { 55 }
        execute = function(domoticz,device )
    	    local numberDefrosts = domoticz.devices(78)
            numberDefrosts.updateCounter(numberDefrosts.counter + 1)
In my opinion simple and should work. It works BUT the numbers are not correct. I had 2 defrosts this night and the counter now is at 9. This morning it was 4. The switch logging looks like this:
2020-05-15 07:03:07	Off	MQTT
2020-05-15 06:58:08	Off	MQTT
2020-05-15 06:53:07	Off	MQTT
2020-05-15 06:48:08	Off	MQTT
2020-05-15 06:47:21	Off	MQTT
2020-05-15 06:43:07	On	MQTT
2020-05-15 06:41:05	On	MQTT
2020-05-15 06:38:08	Off	MQTT
2020-05-15 06:33:08	Off	MQTT
2020-05-15 06:28:07	Off	MQTT
2020-05-15 06:23:07	Off	MQTT
2020-05-15 06:18:07	Off	MQTT
2020-05-15 06:13:08	Off	MQTT
2020-05-15 06:08:08	Off	MQTT
2020-05-15 06:03:09	Off	MQTT
Rest of the day all Off.
I us version 2020.1 on a Pi
Re: Count not corrcet
MeAlbert wrote: Friday 15 May 2020 15:31 I have a Heat Pump that has to defrost when the condenser is freezing in. This is recorded in Domoticz with a dummy switch. (off or on)
         devices = { 55 }
This section triggers the script every time device 55 is updated. You should provide extra code in the execute section of the script if you want the counter only to be updated when the device gets an 'On' signal.
MeAlbert
Post by MeAlbert »
Ok. If I take an if statement that triggers when it is on how do I prevent the double count when the switch is on for 10 minutes?
It should only count the switch goes form Off to On. Do I use a persistent value like this to make this possible or is there a simpler method?
		devices = {	55 }
	data = { eerder = {initial = 'On' }
	    if (domoticz.data.eerder == 'Off' and device.state == 'On') then
	    domoticz.data.eerder = device.state
        numberDefrosts.updateCounter(0)
MeAlbert wrote: Friday 15 May 2020 18:27 Ok. If I take an if statement that triggers when it is on how do I prevent the double count when the switch is on for 10 minutes?
I would not know of a working method without having access to the previous state. Persistent data is probably the easiest way of doing that.
return
    on =
        devices =
            55,
    logging =
        level = domoticz.LOG_DEBUG,
    data =
        eerder =
            initial = 'initial',
        if domoticz.data.eerder ~= device.state then
            if device.state == 'On' then
                numberDefrosts.updateCounter(0) -- Not sure I understand why you reset the counter ?
MeAlbert
Re: Count not correct  [Solved]
Post by MeAlbert »
Waaren thanks.
I used this line to prevent red devices because they are not updated every hour. Did not realize that I reset the counter to 0 again.
Will change to numberDefrosts.updateCounter(numberDefrosts.counter) and move the else statement one if down. Then it should be all right I think.
Thanks for the help.
