Cant start domoticz Error: Domoticz(pid:2881, tid:2892('MainWorker')) received fatal signal 6 (Aborted) Topic is solved
Romel
Post by Romel »
before two days I tried to control domoticz via Alexicz but no response received by Alexa. Then I checked web server but with no luck.
Here are some logs:
sudo ./domoticz -log /var/log/domoticz.log
2020-05-14 22:35:27.464  Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2020-05-14 22:35:27.464  Status: Build Hash: b63341bc0, Date: 2020-04-26 13:47:55
2020-05-14 22:35:27.464  Status: Startup Path: /home/pi/domoticz/
2020-05-14 22:35:27.501  Sunrise: 05:08:00 SunSet: 20:26:00
2020-05-14 22:35:27.501  Day length: 15:18:00 Sun at south: 12:47:00
2020-05-14 22:35:27.501  Civil twilight start: 04:29:00 Civil twilight end: 21:04:00
2020-05-14 22:35:27.501  Nautical twilight start: 03:38:00 Nautical twilight end: 21:55:00
2020-05-14 22:35:27.501  Astronomical twilight start: 02:32:00 Astronomical twilight end: 23:01:00
2020-05-14 22:35:27.590  Status: PluginSystem: Started, Python version '3.7.3'.
2020-05-14 22:35:27.597  Active notification Subsystems: (0/13)
2020-05-14 22:35:27.599  Status: WebServer(HTTP) started on address: :: with port 8080
2020-05-14 22:35:27.604  Status: WebServer(SSL) started on address: :: with port 443
2020-05-14 22:35:27.607  Starting shared server on: :::6144
2020-05-14 22:35:27.607  Status: TCPServer: shared server started...
2020-05-14 22:35:27.607  Status: RxQueue: queue worker started...
2020-05-14 22:35:29.609  Status: Kodi: Started
2020-05-14 22:35:29.609  Status: (Romel LGTV) Started.
2020-05-14 22:35:29.609  Status: YeeLight Worker started...
2020-05-14 22:35:29.609  Status: NotificationSystem: thread started...
2020-05-14 22:35:29.648  Status: EventSystem: reset all events...
2020-05-14 22:35:29.650  Status: EventSystem: reset all device statuses...
terminate called after throwing an instance of 'Json::LogicError'
  what():  in Json::Value::resolveReference(key, end): requires objectValue
2020-05-14 22:35:29.703  Error: Domoticz(pid:2881, tid:2892('MainWorker')) received fatal signal 6 (Aborted)
2020-05-14 22:35:29.703  Error: siginfo address=0xb41, address=0xffffffff
2020-05-14 22:35:30.002  Status: PluginSystem: Entering work loop.
2020-05-14 22:35:30.208  Status: (Romel LGTV) Entering work loop.
2020-05-14 22:35:30.208  Status: (Romel LGTV) Initialized version 0.7, author 'Chris Gheen @GameDevHobby'
2020-05-14 22:35:30.212  (Romel LGTV) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2020-05-14 22:35:30.213  (Romel LGTV) Update interval set to 10 (minimum is 10 seconds)
2020-05-14 22:35:30.213  (Romel LGTV) Pushing 'PollIntervalDirective' on to queue
2020-05-14 22:35:30.213  (Romel LGTV) 'HardwareID':'8'
2020-05-14 22:35:30.213  (Romel LGTV) 'HomeFolder':'/home/pi/domoticz/plugins/LGTV/'
2020-05-14 22:35:30.214  (Romel LGTV) 'StartupFolder':'/home/pi/domoticz/'
2020-05-14 22:35:30.214  (Romel LGTV) 'UserDataFolder':'/home/pi/domoticz/'
2020-05-14 22:35:30.214  (Romel LGTV) 'Database':'/home/pi/domoticz/domoticz.db'
2020-05-14 22:35:30.214  (Romel LGTV) 'Language':'en'
2020-05-14 22:35:30.215  (Romel LGTV) 'Version':'0.7'
2020-05-14 22:35:30.215  (Romel LGTV) 'Author':'Chris Gheen @GameDevHobby'
2020-05-14 22:35:30.215  (Romel LGTV) 'Name':'Romel LGTV'
2020-05-14 22:35:30.215  (Romel LGTV) 'Address':'192.168.88.214'
2020-05-14 22:35:30.216  (Romel LGTV) 'Port':'0'
2020-05-14 22:35:30.216  (Romel LGTV) 'Key':'lgtv'
2020-05-14 22:35:30.216  (Romel LGTV) 'Mode1':'20'
2020-05-14 22:35:30.216  (Romel LGTV) 'Mode2':'20:17:42:1E:E9:F6'
2020-05-14 22:35:30.216  (Romel LGTV) 'Mode3':'Volume'
2020-05-14 22:35:30.217  (Romel LGTV) 'Mode5':'10'
2020-05-14 22:35:30.217  (Romel LGTV) 'Mode6':'Debug'
2020-05-14 22:35:30.217  (Romel LGTV) 'DomoticzVersion':'2020.2'
2020-05-14 22:35:30.217  (Romel LGTV) 'DomoticzHash':'b63341bc0'
2020-05-14 22:35:30.218  (Romel LGTV) 'DomoticzBuildTime':'2020-04-26 13:47:55'
2020-05-14 22:35:30.218  (Romel LGTV) Device count: 3
2020-05-14 22:35:30.218  (Romel LGTV) Device:           1 - ID: 22, Name: 'Romel LGTV - Status', nValue: 1, sValue: 'TimeoutError() occurred, is the TV off?
 ({'returnValue': True, 'channel': {'channelId': '1_22_1_0_61958_519_8395', 'programId': '1_22_1_0_61958_519_8395', 'signalChannelId': '61958_519_8395', 'chanCode': 'UNKNOWN', 'channelMode': 'Terrestrial', 'channelModeId': 0, 'channelType': 'Terrestrial Digital TV', 'channelTypeId': 1, 'channelNumber': '1', 'majorNumber': 1, 'minorNumber': 0, 'channelName': 'NOVA | P', 'skipped': False, 'locked': False, 'descrambled': True, 'scrambled': False, 'serviceType': 16, 'favoriteGroup': [], 'imgUrl': '', 'display': 1, 'satelliteName': ' ', 'fineTuned': False, 'Frequency': 482000, 'shortCut': 0, 'Bandwidth': 0, 'HDTV': False, 'Invisible': False, 'TV': True, 'DTV': True, 'ATV': False, 'Data': False, 'Radio': False, 'Numeric': False, 'PrimaryCh': True, 'specialService': False, 'CASystemIDList': {}, 'CASystemIDListCount': 0, 'groupIdList': [0, 1], 'channelGenreCode': 'UNKNOWN', 'favoriteIdxA': 250, 'favoriteIdxB': 250, 'favoriteIdxC': 250, 'favoriteIdxD': 250, 'imgUrl2': '', 'channelLogoSize': 'UNKNOWN', 'ipChanServerUrl': '', 'payChan': False, 'IPChannelCode': 'UNKNOWN', 'ipCallNumber': 'UNKNOWN', 'otuFlag': False, 'favoriteIdxE': 250, 'favoriteIdxF': 250, 'favoriteIdxG': 250, 'favoriteIdxH': 250, 'satelliteLcn': False, 'waterMarkUrl': 'UNKNOWN', 'channelNameSortKey': '20', 'ipChanType': 'UNKNOWN', 'adultFlag': 0, 'ipChanCategory': 'UNKNOWN', 'ipChanInteractive': False, 'callSign': 'UNKNOWN', 'adFlag': 0, 'configured': False, 'lastUpdated': '', 'ipChanCpId': 'UNKNOWN', 'isFreeviewPlay': 0, 'hasBackward': 0, 'playerService': 'com.webos.service.tv', 'TSID': 61958, 'SVCID': 519}, 'programList': [{'channelId': '1_22_1_0_61958_519_8395', 'duration': 2100, 'endTime': '2020,05,13,17,30,00', 'localEndTime': '2020,05,13,19,30,00', 'localStartTime': '2020,05,13,18,55,00', 'genre': '', 'programId': '8395_61958_519_167', 'programName': 'Comeback', 'rating': [{'ratingString': '', 'ratingValue': 3, 'region': 0, '_id': '276'}], 'signalChannelId': '61958_519_8395', 'startTime': '2020,05,13,16,55,00', 'tableId': 0}, {'channelId': '1_22_1_0_61958_519_8395', 'duration': 3000, 'endTime': '2020,05,13,18,20,00', 'localEndTime': '2020,05,13,20,20,00', 'localStartTime': '2020,05,13,19,30,00', 'genre': '', 'programId': '8395_61958_519_168', 'programName': 'Televizní noviny', 'rating': [{'ratingString': '', 'ratingValue': 3, 'region': 0, '_id': '279'}], 'signalChannelId': '61958_519_8395', 'startTime': '2020,05,13,17,30,00', 'tableId': 0}, {'channelId': '1_22_1_0_61958_519_8395', 'duration': 4200, 'endTime': '2020,05,13,19,30,00', 'localEndTime': '2020,05,13,21,30,00', 'localStartTime': '2020,05,13,20,20,00', 'genre': '', 'programId': '8395_61958_519_169', 'programName': 'MasterChef Česko', 'rating': [{'ratingString': '', 'ratingValue': 3, 'region': 0, '_id': '27c'}], 'signalChannelId': '61958_519_8395', 'startTime': '2020,05,13,18,20,00', 'tableId': 0}, {'channelId': '1_22_1_0_61958_519_8395', 'duration': 3300, 'endTime': '2020,05,13,20,25,00', 'localEndTime': '2020,05,13,22,25,00', 'localStartTime': '2020,05,13,21,30,00', 'genre': '', 'programId': '8395_61958_519_170', 'programName': 'Nova je s vámi', 'rating': [{'ratingString': '', 'ratingValue': 3, 'region': 0, '_id': '27f'}], 'signalChannelId': '61958_519_8395', 'startTime': '2020,05,13,19,30,00', 'tableId': 0}]}
2020-05-14 22:35:30.220  (Romel LGTV) Internal ID:     '22'
2020-05-14 22:35:30.220  (Romel LGTV) External ID:     '00080001'
2020-05-14 22:35:30.220  (Romel LGTV) Device Name:     'Romel LGTV - Status'
2020-05-14 22:35:30.220  (Romel LGTV) Device nValue:    1
2020-05-14 22:35:30.220  (Romel LGTV) Device sValue:   'TimeoutError() occurred, is the TV off?
2020-05-14 22:35:30.221  (Romel LGTV) Device LastLevel: 0
2020-05-14 22:35:30.221  (Romel LGTV) Device:           2 - ID: 25, Name: 'Romel LGTV - Volume', nValue: 0, sValue: '0'
2020-05-14 22:35:30.222  (Romel LGTV) Internal ID:     '25'
2020-05-14 22:35:30.222  (Romel LGTV) External ID:     '00080002'
2020-05-14 22:35:30.222  (Romel LGTV) Device Name:     'Romel LGTV - Volume'
2020-05-14 22:35:30.222  (Romel LGTV) Device nValue:    0
2020-05-14 22:35:30.222  (Romel LGTV) Device sValue:   '0'
2020-05-14 22:35:30.222  (Romel LGTV) Device LastLevel: -1
2020-05-14 22:35:30.223  (Romel LGTV) Device:           3 - ID: 24, Name: 'Romel LGTV - Source', nValue: 0, sValue: '0'
2020-05-14 22:35:30.223  (Romel LGTV) Internal ID:     '24'
2020-05-14 22:35:30.223  (Romel LGTV) External ID:     '00080003'
2020-05-14 22:35:30.223  (Romel LGTV) Device Name:     'Romel LGTV - Source'
2020-05-14 22:35:30.223  (Romel LGTV) Device nValue:    0
2020-05-14 22:35:30.223  (Romel LGTV) Device sValue:   '0'
2020-05-14 22:35:30.224  (Romel LGTV) Device LastLevel: 0
2020-05-14 22:35:30.224  (Romel LGTV) Notifications are off, add a Notifier Name to enable.
2020-05-14 22:35:30.224  (Romel LGTV) Processing 'PollIntervalDirective' message
2020-05-14 22:35:30.224  (Romel LGTV) Heartbeat interval set to: 10.
2020-05-14 22:35:30.609  Status: MQTT: Connecting to localhost:1883
2020-05-14 22:35:32.851  Error: Thread 12 (Thread 0x701ff220 (LWP 2892)):
2020-05-14 22:35:32.851  Error: #0  __waitpid (options=0, stat_loc=0x701fd208, pid=2900) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2020-05-14 22:35:32.851  Error: #1  __waitpid (pid=2900, stat_loc=0x701fd208, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2020-05-14 22:35:32.851  Error: #2  0x002db8ec in dumpstack_gdb(bool) ()
2020-05-14 22:35:32.851  Error: #3  0x002dbeb8 in signal_handler(int, siginfo_t*, void*) ()
2020-05-14 22:35:32.851  Error: #4  <signal handler called>
2020-05-14 22:35:32.851  Error: #5  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2020-05-14 22:35:32.851  Error: #6  0x76959230 in __GI_abort () at abort.c:79
2020-05-14 22:35:32.851  Error: #7  0x0096d02c in __gnu_cxx::__verbose_terminate_handler() ()
2020-05-14 22:35:32.851  Error: #8  0x008d04cc in __cxxabiv1::__terminate(void (*)()) ()
2020-05-14 22:35:32.851  Error: #9  0x008d0540 in std::terminate() ()
2020-05-14 22:35:32.852  Error: #10 0x008daff0 in __cxa_throw ()
2020-05-14 22:35:32.852  Error: #11 0x006ecaec in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2020-05-14 22:35:32.852  Error: #12 0x006f2b98 in Json::Value::resolveReference(char const*, char const*) ()
2020-05-14 22:35:32.852  Error: #13 0x0037bca0 in http::server::CWebServer::GetJSonDevices(Json::Value&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool, bool, long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2020-05-14 22:35:32.852  Error: #14 0x7c204156 in ?? ()
Aborted
cp        0      0 0.0.0.0:9091            0.0.0.0:*               LISTEN      462/transmission-da
tcp        0      0 0.0.0.0:51413           0.0.0.0:*               LISTEN      462/transmission-da
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      470/sshd
tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      457/mosquitto
tcp6       0      0 :::51413                :::*                    LISTEN      462/transmission-da
tcp6       0      0 :::22                   :::*                    LISTEN      470/sshd
tcp6       0      0 :::1883                 :::*                    LISTEN      457/mosquitto
udp        0      0 0.0.0.0:44744           0.0.0.0:*                           252/systemd-timesyn
udp        0      0 0.0.0.0:51413           0.0.0.0:*                           462/transmission-da
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           294/avahi-daemon: r
udp        0      0 0.0.0.0:68              0.0.0.0:*                           455/dhcpcd
udp        0      0 0.0.0.0:41031           0.0.0.0:*                           294/avahi-daemon: r
udp6       0      0 :::45765                :::*                                294/avahi-daemon: r
udp6       0      0 :::5353                 :::*                                294/avahi-daemon: r
service domoticz status
● domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; generated)
   Active: active (exited) since Thu 2020-05-14 22:48:12 CEST; 6min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 458 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
May 14 22:48:19 raspberrypi domoticz[491]: #5  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
May 14 22:48:19 raspberrypi domoticz[491]: #6  0x769ea230 in __GI_abort () at abort.c:79
May 14 22:48:19 raspberrypi domoticz[491]: #7  0x0096d02c in __gnu_cxx::__verbose_terminate_handler() ()
May 14 22:48:19 raspberrypi domoticz[491]: #8  0x008d04cc in __cxxabiv1::__terminate(void (*)()) ()
May 14 22:48:19 raspberrypi domoticz[491]: #9  0x008d0540 in std::terminate() ()
May 14 22:48:19 raspberrypi domoticz[491]: #10 0x008daff0 in __cxa_throw ()
May 14 22:48:19 raspberrypi domoticz[491]: #11 0x006ecaec in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
May 14 22:48:19 raspberrypi domoticz[491]: #12 0x006f2b98 in Json::Value::resolveReference(char const*, char const*) ()
May 14 22:48:19 raspberrypi domoticz[491]: #13 0x0037bca0 in http::server::CWebServer::GetJSonDevices(Json::Value&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, s
May 14 22:48:19 raspberrypi domoticz[491]: #14 0x7c204156 in ?? ()
Can anyone please help ?
Romel
Re: Cant start domoticz Error: Domoticz(pid:2881, tid:2892('MainWorker')) received fatal signal 6 (Aborted)
Post by Romel »
really nobody who can help ??
Romel wrote: Wednesday 20 May 2020 16:37 really nobody who can help ??
What have you tried so far?
Did you check your database integrity ? If the database is ok then start without any plugin or scripts and activate these one by one.
Romel
Post by Romel »
waaren wrote: Wednesday 20 May 2020 17:53
hi waaren, thank you for helping !
last week I builded new domoticz and import backup and it works.. But next time (I hope that this situation will not accure to me :shock: ) i will try disable plugins and scripts.
** CLOSED **
Quax1507
Post by Quax1507 »
Similar problem here!
I am running Domoticz V2020.1 (build 11957) on RPI
Domoticz is running fine for 2 or 3 weeks and suddenly crashes. See logs below. The only solution I have found by now, is to restore domotict.db from last nightly backup.
Thread 12 is crashing. It is "MainWorker"
Domoticz_crash.log:
[New LWP 714]
[New LWP 727]
[New LWP 728]
[New LWP 730]
[New LWP 731]
[New LWP 732]
[New LWP 733]
[New LWP 734]
[New LWP 735]
[New LWP 736]
[New LWP 737]
[New LWP 738]
[New LWP 743]
[New LWP 746]
[New LWP 747]
[New LWP 748]
[New LWP 749]
[New LWP 750]
[New LWP 751]
[New LWP 752]
[New LWP 753]
[New LWP 754]
[New LWP 755]
[New LWP 756]
[New LWP 757]
[New LWP 758]
[New LWP 759]
[New LWP 760]
[New LWP 763]
[New LWP 765]
[New LWP 770]
[New LWP 771]
[New LWP 787]
[New LWP 788]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
__GI___nanosleep (remaining=0x7edda988, requested_time=0x7edda988) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
28	../sysdeps/unix/sysv/linux/nanosleep.c: No such file or directory.
  Id   Target Id                                     Frame
* 1    Thread 0x7606c010 (LWP 708) "domoticz"        __GI___nanosleep (remaining=0x7edda988, requested_time=0x7edda988) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
  2    Thread 0x75b93220 (LWP 714) "Watchdog"        __GI___nanosleep (remaining=0x75b92bd0, requested_time=0x75b92bd0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
  3    Thread 0x75392220 (LWP 727) "SQLHelper"       syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  4    Thread 0x74b91220 (LWP 728) "PluginMgr"       syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  5    Thread 0x73de4220 (LWP 730) "InfluxPush"      syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  6    Thread 0x735e3220 (LWP 731) "Webem_ssncleane" 0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x735e2378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
  7    Thread 0x72de2220 (LWP 732) "WebServer_8080"  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x72de1348, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
  8    Thread 0x723ff220 (LWP 733) "Webem_ssncleane" 0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x723fe378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
  9    Thread 0x71bfe220 (LWP 734) "WebServer_9443"  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x71bfd348, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
  10   Thread 0x711ff220 (LWP 735) "Scheduler"       syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  11   Thread 0x709fe220 (LWP 736) "TCPServer"       0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x709fd378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
  12   Thread 0x6ffff220 (LWP 737) "MainWorker"      __waitpid (options=0, stat_loc=0x6fffcdf0, pid=766) at ../sysdeps/unix/sysv/linux/waitpid.c:30
  13   Thread 0x6f7fe220 (LWP 738) "MainWorkerRxMsg" futex_wait_cancelable (private=0, expected=0, futex_word=0xaba830 <m_mainworker+520>) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
  14   Thread 0x6ebff220 (LWP 743) "HardwareMonitor" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  15   Thread 0x6e3fe220 (LWP 746) "ZWaveBase"       _int_malloc (av=av@entry=0x6ec00010, bytes=bytes@entry=9312) at malloc.c:3817
  16   Thread 0x6dbfd220 (LWP 747) "Fritzbox"        syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  17   Thread 0x6d3fc220 (LWP 748) "Domoticz_HBWork" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  18   Thread 0x6cbfb220 (LWP 749) "Kodi"            syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  19   Thread 0x6c3fa220 (LWP 750) "OpenWeatherMap"  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  20   Thread 0x6bbf9220 (LWP 751) "Darksky"         syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  21   Thread 0x6b1ff220 (LWP 752) "Daikin"          futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6b1fe7d0, expected=0, futex_word=0xf1b518) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
  22   Thread 0x6a9fe220 (LWP 753) "Daikin"          futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6a9fd7d0, expected=0, futex_word=0x65474cd0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
  23   Thread 0x6a1fd220 (LWP 754) "Daikin"          futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6a1fc7d0, expected=0, futex_word=0x6ed0c0d8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
  24   Thread 0x699fc220 (LWP 755) "WU"              syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  25   Thread 0x691fb220 (LWP 756) "NotificationSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x691fabcc, expected=0, futex_word=0xabb150 <m_mainworker+2856>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
  26   Thread 0x689fa220 (LWP 757) "Fritzbox"        0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x689f9378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
  27   Thread 0x681f9220 (LWP 758) "Fritzbox"        futex_wait_cancelable (private=0, expected=0, futex_word=0xef1228) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
  28   Thread 0x679f8220 (LWP 759) "KodiNode"        syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  29   Thread 0x671f7220 (LWP 760) "Plugin_ASIO"     0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x671f6350, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
  30   Thread 0x669f6220 (LWP 763) "Plugin_Sonos"    syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  31   Thread 0x65db7220 (LWP 765) "Plugin_xiaomi-m" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  32   Thread 0x653ff220 (LWP 770) "Plugin_xiaomi-m" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  33   Thread 0x648ff220 (LWP 771) "Plugin_BatteryL" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  34   Thread 0x63cff220 (LWP 787) "Plugin_SVT"      syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
  35   Thread 0x634fe220 (LWP 788) "Plugin_xfr_pws"  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
Thread 35 (Thread 0x634fe220 (LWP 788)):
#0  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
#1  0x0092223c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
#2  0x00620df8 in Plugins::CPlugin::Do_Work() ()
#3  0x009447cc in execute_native_thread_routine ()
#4  0x76c15494 in start_thread (arg=0x634fe220) at pthread_create.c:486
#5  0x76ac8578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 34 (Thread 0x63cff220 (LWP 787)):
#4  0x76c15494 in start_thread (arg=0x63cff220) at pthread_create.c:486
Thread 33 (Thread 0x648ff220 (LWP 771)):
#4  0x76c15494 in start_thread (arg=0x648ff220) at pthread_create.c:486
Thread 32 (Thread 0x653ff220 (LWP 770)):
#4  0x76c15494 in start_thread (arg=0x653ff220) at pthread_create.c:486
Thread 31 (Thread 0x65db7220 (LWP 765)):
#4  0x76c15494 in start_thread (arg=0x65db7220) at pthread_create.c:486
Thread 30 (Thread 0x669f6220 (LWP 763)):
#4  0x76c15494 in start_thread (arg=0x669f6220) at pthread_create.c:486
Thread 29 (Thread 0x671f7220 (LWP 760)):
#0  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x671f6350, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#1  0x003dfa3c in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
#2  0x003e0fc0 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#3  0x00625c58 in Plugins::BoostWorkers() ()
#4  0x007c2894 in thread_proxy ()
#5  0x76c15494 in start_thread (arg=0x671f7220) at pthread_create.c:486
#6  0x76ac8578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 28 (Thread 0x679f8220 (LWP 759)):
#2  0x004c6f78 in CKodiNode::Do_Work() ()
#3  0x007c2894 in thread_proxy ()
#4  0x76c15494 in start_thread (arg=0x679f8220) at pthread_create.c:486
Thread 27 (Thread 0x681f9220 (LWP 758)):
#0  futex_wait_cancelable (private=0, expected=0, futex_word=0xef1228) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1  __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0xef1200) at pthread_cond_wait.c:502
#2  __pthread_cond_wait (cond=0xef1200, mutex=0x0) at pthread_cond_wait.c:655
#3  0x003e10a8 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#4  0x003ef484 in boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_scheduler_runner>::run() ()
#5  0x003deb00 in boost_asio_detail_posix_thread_function ()
#6  0x76c15494 in start_thread (arg=0x681f9220) at pthread_create.c:486
#7  0x76ac8578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 26 (Thread 0x689fa220 (LWP 757)):
#0  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x689f9378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3  0x003e7a1c in boost::asio::io_context::run() ()
#4  0x009447cc in execute_native_thread_routine ()
#5  0x76c15494 in start_thread (arg=0x689fa220) at pthread_create.c:486
Thread 25 (Thread 0x691fb220 (LWP 756)):
#0  futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x691fabcc, expected=0, futex_word=0xabb150 <m_mainworker+2856>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1  __pthread_cond_wait_common (abstime=0x691fabcc, mutex=0x0, cond=0xabb128 <m_mainworker+2816>) at pthread_cond_wait.c:539
#2  __pthread_cond_timedwait (cond=0xabb128 <m_mainworker+2816>, mutex=0x0, abstime=0x691fabcc) at pthread_cond_wait.c:667
#3  0x002c0bc0 in CNotificationSystem::QueueThread() ()
#5  0x76c15494 in start_thread (arg=0x691fb220) at pthread_create.c:486
Thread 24 (Thread 0x699fc220 (LWP 755)):
#2  0x005f67d8 in CWunderground::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x699fc220) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0x6163695e
Thread 23 (Thread 0x6a1fd220 (LWP 754)):
#0  futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6a1fc7d0, expected=0, futex_word=0x6ed0c0d8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1  __pthread_cond_wait_common (abstime=0x6a1fc7d0, mutex=0x0, cond=0x6ed0c0b0) at pthread_cond_wait.c:539
#2  __pthread_cond_timedwait (cond=0x6ed0c0b0, mutex=0x0, abstime=0x6a1fc7d0) at pthread_cond_wait.c:667
#3  0x0029dfbc in MainWorker::CheckAndPushRxMessage(CDomoticzHardwareBase const*, unsigned char const*, char const*, int, bool) ()
#4  0x0029e5ec in MainWorker::PushAndWaitRxMessage(CDomoticzHardwareBase const*, unsigned char const*, char const*, int) ()
#5  0x0041b2dc in CDaikin::InsertUpdateSwitchSelector(unsigned char, bool, int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#6  0x0041baac in CDaikin::GetControlInfo() ()
#7  0x0041cb18 in CDaikin::Do_Work() ()
#8  0x009447cc in execute_native_thread_routine ()
#9  0x76c15494 in start_thread (arg=0x6a1fd220) at pthread_create.c:486
Thread 22 (Thread 0x6a9fe220 (LWP 753)):
#0  futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6a9fd7d0, expected=0, futex_word=0x65474cd0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1  __pthread_cond_wait_common (abstime=0x6a9fd7d0, mutex=0x0, cond=0x65474ca8) at pthread_cond_wait.c:539
#2  __pthread_cond_timedwait (cond=0x65474ca8, mutex=0x0, abstime=0x6a9fd7d0) at pthread_cond_wait.c:667
#9  0x76c15494 in start_thread (arg=0x6a9fe220) at pthread_create.c:486
Thread 21 (Thread 0x6b1ff220 (LWP 752)):
#0  futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6b1fe7d0, expected=0, futex_word=0xf1b518) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1  __pthread_cond_wait_common (abstime=0x6b1fe7d0, mutex=0x0, cond=0xf1b4f0) at pthread_cond_wait.c:539
#2  __pthread_cond_timedwait (cond=0xf1b4f0, mutex=0x0, abstime=0x6b1fe7d0) at pthread_cond_wait.c:667
#9  0x76c15494 in start_thread (arg=0x6b1ff220) at pthread_create.c:486
Thread 20 (Thread 0x6bbf9220 (LWP 751)):
#2  0x0041f0f8 in CDarkSky::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x6bbf9220) at pthread_create.c:486
Thread 19 (Thread 0x6c3fa220 (LWP 750)):
#2  0x005158f4 in COpenWeatherMap::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x6c3fa220) at pthread_create.c:486
Thread 18 (Thread 0x6cbfb220 (LWP 749)):
#2  0x004c28f8 in CKodi::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x6cbfb220) at pthread_create.c:486
Thread 17 (Thread 0x6d3fc220 (LWP 748)):
#2  0x004352d8 in CDomoticzHardwareBase::Do_Heartbeat_Work() ()
#4  0x76c15494 in start_thread (arg=0x6d3fc220) at pthread_create.c:486
Thread 16 (Thread 0x6dbfd220 (LWP 747)):
#2  0x004905e8 in FritzboxTCP::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x6dbfd220) at pthread_create.c:486
Thread 15 (Thread 0x6e3fe220 (LWP 746)):
#0  _int_malloc (av=av@entry=0x6ec00010, bytes=bytes@entry=9312) at malloc.c:3817
#1  0x76a64318 in __GI___libc_malloc (bytes=9312) at malloc.c:3057
#2  0x008dae4c in operator new(unsigned int) ()
#3  0x006cc0b8 in TiXmlString::reserve(unsigned int) ()
Thread 14 (Thread 0x6ebff220 (LWP 743)):
#2  0x0049d0d0 in CHardwareMonitor::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x6ebff220) at pthread_create.c:486
Thread 13 (Thread 0x6f7fe220 (LWP 738)):
#0  futex_wait_cancelable (private=0, expected=0, futex_word=0xaba830 <m_mainworker+520>) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1  __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0xaba808 <m_mainworker+480>) at pthread_cond_wait.c:502
#2  __pthread_cond_wait (cond=0xaba808 <m_mainworker+480>, mutex=0x0) at pthread_cond_wait.c:655
#3  0x0026795c in boost::unique_lock<boost::shared_mutex>::lock() ()
#4  0x00256360 in CEventSystem::UpdateBatteryLevel(unsigned long long, unsigned char) ()
#5  0x002ac6fc in MainWorker::ProcessRXMessage(CDomoticzHardwareBase const*, unsigned char const*, char const*, int) ()
#6  0x002af688 in MainWorker::Do_Work_On_Rx_Messages() ()
#7  0x009447cc in execute_native_thread_routine ()
#8  0x76c15494 in start_thread (arg=0x6f7fe220) at pthread_create.c:486
#9  0x76ac8578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 12 (Thread 0x6ffff220 (LWP 737)):
#0  __waitpid (options=0, stat_loc=0x6fffcdf0, pid=766) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1  __waitpid (pid=766, stat_loc=0x6fffcdf0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
#2  0x002db924 in dumpstack_gdb(bool) ()
#3  0x002dbef0 in signal_handler(int, siginfo_t*, void*) ()
#5  raise (sig=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#6  <signal handler called>
#7  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#8  0x76a08230 in __GI_abort () at abort.c:79
#9  0x0096d00c in __gnu_cxx::__verbose_terminate_handler() ()
#10 0x008d04ac in __cxxabiv1::__terminate(void (*)()) ()
#11 0x008d0520 in std::terminate() ()
#12 0x008dafd0 in __cxa_throw ()
#13 0x006ecb04 in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#14 0x006f2bb0 in Json::Value::resolveReference(char const*, char const*) ()
#15 0x0037bcc0 in http::server::CWebServer::GetJSonDevices(Json::Value&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool, bool, long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#16 0x7774656e in ?? ()
Thread 11 (Thread 0x709fe220 (LWP 736)):
#0  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x709fd378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3  0x0067723c in tcp::server::CTCPServer::Do_Work() ()
#5  0x76c15494 in start_thread (arg=0x709fe220) at pthread_create.c:486
Thread 10 (Thread 0x711ff220 (LWP 735)):
#2  0x002d092c in CScheduler::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x711ff220) at pthread_create.c:486
Thread 9 (Thread 0x71bfe220 (LWP 734)):
#0  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x71bfd348, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3  0x006bf804 in http::server::server_base::run() ()
#4  0x0031bc34 in http::server::CWebServer::Do_Work() ()
#5  0x009447cc in execute_native_thread_routine ()
#6  0x76c15494 in start_thread (arg=0x71bfe220) at pthread_create.c:486
Thread 8 (Thread 0x723ff220 (LWP 733)):
#0  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x723fe378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5  0x76c15494 in start_thread (arg=0x723ff220) at pthread_create.c:486
Thread 7 (Thread 0x72de2220 (LWP 732)):
#0  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x72de1348, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#6  0x76c15494 in start_thread (arg=0x72de2220) at pthread_create.c:486
Thread 6 (Thread 0x735e3220 (LWP 731)):
#0  0x76ac89d0 in epoll_wait (epfd=<optimized out>, events=0x735e2378, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5  0x76c15494 in start_thread (arg=0x735e3220) at pthread_create.c:486
Thread 5 (Thread 0x73de4220 (LWP 730)):
#2  0x003b7204 in CInfluxPush::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x73de4220) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0x78
Thread 4 (Thread 0x74b91220 (LWP 728)):
#2  0x00626328 in Plugins::CPluginSystem::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x74b91220) at pthread_create.c:486
Thread 3 (Thread 0x75392220 (LWP 727)):
#2  0x003128f8 in CSQLHelper::Do_Work() ()
#4  0x76c15494 in start_thread (arg=0x75392220) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0xe
Thread 2 (Thread 0x75b93220 (LWP 714)):
#0  __GI___nanosleep (remaining=0x75b92bd0, requested_time=0x75b92bd0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1  __GI___nanosleep (requested_time=0x75b92bd0, remaining=0x75b92bd0) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2  0x00270c64 in sleep_milliseconds(long) ()
#3  0x002dc058 in Do_Watchdog_Work() ()
#5  0x76c15494 in start_thread (arg=0x75b93220) at pthread_create.c:486
Thread 1 (Thread 0x7606c010 (LWP 708)):
#0  __GI___nanosleep (remaining=0x7edda988, requested_time=0x7edda988) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1  __GI___nanosleep (requested_time=0x7edda988, remaining=0x7edda988) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2  0x00270bd0 in sleep_seconds(long) ()
#3  0x001eef6c in main ()
Main thread:
[Inferior 1 (process 708) detached]
Domotiz.log:
2020-06-21 22:02:21.073  Error: Thread 12 (Thread 0x6ffff220 (LWP 737)):
2020-06-21 22:02:21.073  Error: #0  __waitpid (options=0, stat_loc=0x6fffcdf0, pid=766) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2020-06-21 22:02:21.073  Error: #1  __waitpid (pid=766, stat_loc=0x6fffcdf0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2020-06-21 22:02:21.073  Error: #2  0x002db924 in dumpstack_gdb(bool) ()
2020-06-21 22:02:21.073  Error: #3  0x002dbef0 in signal_handler(int, siginfo_t*, void*) ()
2020-06-21 22:02:21.073  Error: #4  <signal handler called>
2020-06-21 22:02:21.073  Error: #5  raise (sig=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2020-06-21 22:02:21.073  Error: #6  <signal handler called>
2020-06-21 22:02:21.073  Error: #7  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
2020-06-21 22:02:21.073  Error: #8  0x76a08230 in __GI_abort () at abort.c:79
2020-06-21 22:02:21.073  Error: #9  0x0096d00c in __gnu_cxx::__verbose_terminate_handler() ()
2020-06-21 22:02:21.073  Error: #10 0x008d04ac in __cxxabiv1::__terminate(void (*)()) ()
2020-06-21 22:02:21.073  Error: #11 0x008d0520 in std::terminate() ()
2020-06-21 22:02:21.073  Error: #12 0x008dafd0 in __cxa_throw ()
2020-06-21 22:02:21.073  Error: #13 0x006ecb04 in Json::throwLogicError(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2020-06-21 22:02:21.074  Error: #14 0x006f2bb0 in Json::Value::resolveReference(char const*, char const*) ()
2020-06-21 22:02:21.074  Error: #15 0x0037bcc0 in http::server::CWebServer::GetJSonDevices(Json::Value&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool, bool, long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
2020-06-21 22:02:21.074  Error: #16 0x7774656e in ?? ()
Any idea?
