Qubino (Goap) ZMNHOD1 not directly stopping
K0enH
Post by K0enH »
Hi All,
I have a Qubino (Goap) ZMNHOD1 Flush Shutter DC+,
based on a switch I want do directly stop the movement of my curtain to stick to the current position.
whenever Domoticz gives the stop command (via url), the shutter doesnt stop, and sometimes even moves the curtain to previous location.
for example, when the curtain is closed, and is opened and I use the stop command it can even go back to closed state.
is this configurable with the parameters to not let this happen?
AllesVanZelf
Domoticz version: 12467
Re: Qubino (Goap) ZMNHOD1 not directly stopping
Post by AllesVanZelf »
Does it help if you change it to a Blind precentage?
K0enH
Post by K0enH »
it is already blinds percentage...
so I was more thinking about module parameters in the zwave config.
but cant find any clue in this..
Bigmoose
Domoticz version: 3.8153
Post by Bigmoose »
I have the Qubino (Goap) ZMNHCDx Flush Shutter + and operate my roller shutter with it. It turns out that the Somfy ilmo engine does not work well with Qubino. Do you also have a Somfy engine?
K0enH
Post by K0enH »
No, It is a Luxaflex with their own engine
