I have been using SetPiont to define values for temperature, but now I need an interactive way to set max and min values for humidity, that is being able to input these values (as integers) from the dashboard. I could possibly use SetPoint, and extract the values, but it seems odd to display SetPoint in degrees, when it is a number for the humidity.
Is there any way I can make this happen?
Best regards
Ulf
Utility to set limit for humidity [Solved]
- waaren
Re: Utility to set limit for humidity
If you only need a limited number of steps you could use two selectors. (one for max and one for min value)ulfh2018 wrote: Friday 08 May 2020 18:15 I need an interactive way to set max and min values for humidity.
ulfh2018
Might be a solution. Didn’t even know that one existed! Thanks a lot! I’ll give it a try tomorrow
ulfh2018
Hi Waaren.
Yes, that's a good starting point.
What I need now is:
1. getting a selected value from two selectors, one for max and one for min. This will be integers
2. defining the two values as persistent variables (so they can survive a reboot)
3. access the two variables from dzVents, take action if they are changed, using checkFirst()
Tried to look at some examples. In node-red I would have stored the varibles in a database, but I understand Domoticz has an internal database(?) but how do I access it?
I have tried to create a global_data.lua in the script directory:
helpers = {},
data = {
MaxHum = { initial = 80 },
MinHum = { initial = 60 }
From dzvent I try to access use the variables:
if (hum >= (domoticz.globalData.MaxHum)) then -- Turn on fan
domoticz.devices(4).switchOn().checkFirst() -- Turn on fan
elseif (hum <= (domoticz.globalData.MinHum)) then -- turn off fan
domoticz.devices(4).switchOff().checkFirst()
Gives me an error:
attempt to compare nil with number
And then, off course, I need to upgrade MaxHum and MinHum from the Selector Switch.
What I need now is:
helpers = {},
data = {
Gives me an error:
- waaren
I think you over complicate it.ulfh2018 wrote: Saturday 09 May 2020 7:08 What I need now is:
This will also do the job without persistent vars and will survive a boot.
return
on =
timer =
'every minute',
logging =
level = domoticz.LOG_DEBUG,
execute = function(dz)
local humidity = dz.devices('humSensor').humidity
local maxHumidity = tonumber(dz.devices('max Humidity').levelName) or 100 -- the or parts are for cases that the levelname is not numeric
local minHumidity = tonumber(dz.devices('min Humidity').levelName) or 0
local fan = dz.devices(4)
if humidity >= maxHumidity then
fan.switchOn().checkFirst()
elseif humidity <= minHumidity then
fan.switchOff().checkFirst()
ulfh2018
Re: Utility to set limit for humidity [Solved]
Dear Waaren
First I have one question: Do you ever sleep?
Thank you so much - that was a life savior!
Why do things complicated, when it can be done simple and elegant!
My main problem is, as it comes with a few other members, lack of experiense. I try to check google and the forum, but I have to admit that most of the stuff I find there is too complicated. This one, by the way, was easy to understand, but I would not have been able to dig it out my self in a million years.
Have a lovely day - I'll have a pint of beer at the varanda to celebrate you and your work!!!!!
How do I report this as solved???
All the best from
Ulf
All the best from
Ulf
