Meters combination Topic is solved
dorenberg
Domoticz version: 4.10982
Meters combination
Post by dorenberg »
I just wanted to ask if there would be an option to merge 2 values from a P1 meter. The current usage only reflects one value. The return is not seen in Dashticz or is reported in a positive value. Very confusing. It is possible to do this in the graph section, which works rather fine!
To explain it a bit more, my p1 meter in domoticz reports 99watt (usage), -1517watt (return). I only see the last number reported in dashticz, and it is always positive. I would like to report 99-1517 = -1418watt in this example.
Lokonli
Re: Meters combination
Post by Lokonli »
Your P1 meter cannot have a usage value and a usagedeliv value at the same time ...
Can you explain what you would like to see?
Lokonli
Post by Lokonli »
dorenberg
Post by dorenberg »
Yes, it is definitely possible. I have a 3-phase connection. Return is on phase number 1 only. But there is usage on the other 2 phases (also on phase 1). These are reported in the p1 meter as the netto usage on phase 1 (which can be return), and if that is the case 2 values are reported. See attachment jpg.
jake
Post by jake »
My p1 meter generated 7 devices: 2x L1/2/3 and 1 that produces a string of information: meter values and current usage/return values. That last device is used in my dashticz.
dorenberg
Post by dorenberg »
In Domoticz I have 3 voltage sensors, 3x return and 3x usage. And the current use as pictured above and totals.
I have managed to get both values in one block. Now the question, how to substract both from each other. Usage-UsageDeliv.
blocks.js
(72.04 KiB) Downloaded 396 times
dorenberg
Post by dorenberg »
Solved it. Attached the blocks.js
function getSmartMeterBlock(block) {
var device = block.device;
var idx = device.idx;
block.width = block.width || 4;
if (device['SubType'] === 'Energy') {
var value1=parseFloat(device['Usage']);
var value2=parseFloat(device['UsageDeliv']);
var usage = value1 - value2 + 'Watt';
Now I only get the nett use or return. Both substracted from each other.
blocks 2020-05-08.js
(71.92 KiB) Downloaded 399 times
Lokonli
Post by Lokonli »
dorenberg wrote: Friday 08 May 2020 15:16 Solved it. Attached the blocks.js
I would not recommend modifying blocks.js, because if there is a Dashticz update you have to reapply your changes, and updating may be more difficult.
There is an easier way, that works for most devices. (assuming you run a recent beta version of Dashticz)
If you Domoticz device id is 43, and has subdevices (like a smartmeter), add subdevice '43_1' to a Dashticz column, and the following to custom.js:
function getStatus_43_1(block) {
  block.value = value1 - value2 + ' Watt';
And then as weekend bonus: If you have solar panels, and you would like to know your actual energy usage, then you can compute it with (pseudocode):
P1meter _in + Solar - P1meter_out.
and in real, assuming your Solar panes are a energy device, with device ID 6:
   var solar = Domoticz.getAllDevices()[6];
   var value3=parseFloat(solar['Usage']);
   var nettusage = value1 + value3 - value2;
   block.value = 'Usage: ' + nettusage;
As you can see you have access to other Domoticz device data as well, which you can use to create your block.value
Enjoy :)
dorenberg
Post by dorenberg »
thanks for this. I just changed it to your suggestion and it works perfect.
I also wanted to do this for the nett usage per day. But sometimes I get values with a lot of decimals (15 or so). How can I fix this to 2 decimals? Learning js every day.
function getStatus_62_2(block) {
var valueA=parseFloat(device['CounterToday']);
var valueB=parseFloat(device['CounterDelivToday']);
block.value = valueA - valueB + ' kWh';
Lokonli
Post by Lokonli »
Change the block.value line to:
block.value = (valueA - valueB).toFixed(2) + ' kWh';
dorenberg
Post by dorenberg »
yes, that does the trick. Kudos!
