HOWTO get the value of the Domoticz URL?  [Solved]
dlube
Post by dlube »
If I follow the DzVent manual I should use the following
print('Domoticz url '..domoticz.settings.url)
This code produce the error below
dzVents: Error: (3.0.2) Test: An error occurred when calling event handler Test
dzVents: Error: (3.0.2) Test: ...e/pi/domoticz/scripts/dzVents/generated_scripts/Test.lua:20: attempt to concatenate a nil value (field 'url')
The dump of the table domoticz.settings:
serverPort: 8080
dzVentsVersion: 3.0.2
Log level: 2
longitude: 1.387347
latitude: 43.630555
Domoticz url: http://127.0.0.1:8080
domoticzVersion: 2020.2
How to get the value of Domoticz url?
Raspbian Buster on Raspberry pi 3 B+ Domoticz Version: 2023.2 (build 15474)
Re: HOWTO get the value of the Domoticz URL?  [Solved]
dlube wrote: Friday 08 May 2020 12:05 How to get the value of Domoticz url?
Thx for reporting !
Is indeed a bug and will be solved in next beta. Please use
print('Domoticz url '..domoticz.settings['Domoticz url'])
until fixed.
dlube
Post by dlube »
Tank you
dlube wrote: Friday 08 May 2020 14:42Thank you
Fixed in V 2020.2 build 12018 (dzVents 3.0.5)
