Implemented in #2090Blueone wrote:it is possible to change the colors from the lights live when adding the lights to a scene?
[122] Philips Hue support
- gizmocuz
Re: [122] Philips Hue support
dennusb
Strange behaviour here.... i want to add the Hue Bridge so a added "hardware" ->
All looking good... but when i click "Register on Bridge" i get :
What to do?
What to do?
- gizmocuz
Leave the username empty, then press register, it should give you a new username.
i think domoticz is to short, or because it is registered as device 'domoticz' you can not also use the username 'domoticz'
dennusb
Yes, that is it. You cant fill in a username by yourself. Maybe good idea to disable that input box and say next to it will be automatically filled! This is confusing!gizmocuz wrote:Leave the username empty, then press register, it should give you a new username.
globalassist
I don't get it.
Using build 2084 on Windows, I can only add the Hue Bridge with username "newdeveloper" which I created on the Hue Bridge.
I cannot register it or add it with a different username (it also does not generate a user).
Even when I add it with the newdeveloper-user it doesn't list any lights.
In the logging the following is displayed:
Tue Oct 28 20:44:06 2014 Philips Hue: Worker started...
Tue Oct 28 20:44:06 2014 EventSystem stopped...
What am I doing wrong?
dennusb
Add a bridge to the hardware page but DON'T fill in the username, just click "Register on bridge", a username is generated automatically.globalassist wrote:I don't get it.
globalassist
Nops, then a Red blob is displayed : Undefined
- gizmocuz
Blueone
Everything is working goed now
Is it possible to read the current color from lights in the webinterface from domoticz instead of only the script? (maybe with a text field below the rgb color picker or something?)
Last edited by Blueone on Wednesday 29 October 2014 21:56, edited 1 time in total.
dennusb
I suggested that in a separate topic alreadyBlueone wrote:Everything is working goed now![]()
Is it possible to read the current color from lights in the webinterface from domoticz? (maybe with a text field below the rgb color picker or something?)
globalassist
I really hate to bother you guys with this, but I'm still not getting it to work.
The register-proces works now (creates a random user) and then I press "add" and everything seems ok.
However, there are no lights added to the devices tab.
Screenshot added:
Screenshot added:
- Screenshot of added hardware Hue
- PhilipsHue.jpg (176.64 KiB) Viewed 26176 times
- gizmocuz
Can you post the output ofglobalassist wrote:I really hate to bother you guys with this, but I'm still not getting it to work.
Screenshot added:
http://HUE_IP/api/USERNAME/lights/
(Change the IP and Username to the on in the hardware setup)
globalassist
I won't post all output, but here's the starting bit:
{"lights":{"1":{"state": {"on":true,"bri":240,"hue":15331,"sat":121,"xy":[0.4448,0.4066],"ct":343,"alert":"none","effect":"none","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "Mediacenter 1", "modelid": "LCT001","uniqueid":"00:17:88:01:00:e6:ea:f3-0b", "swversion": "66010820", "pointsymbol": { "1":"0a00f1f01f1f1001f1ff100000000001f2000000", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }},"2":{"state": {"on":true,"bri":240,"hue":15331,"sat":121,"xy":[0.4448,0.4066],"ct":343,"alert":"none","effect":"none","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "Keukentafel 1", "modelid": "LCT001","uniqueid":"00:17:88:01:00:d0:fa:ab-0b", "swversion": "66010820", "pointsymbol": { "1":"0a00f1f01f1f1001f1ff100000000001f2000000", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }},"3":{"state": {"on":true,"bri":240,"hue":15331,"sat":121,"xy":[0.4448,0.4066],"ct":343,"alert":"none","effect":"none","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "Mediacenter 2", "modelid": "LCT001","uniqueid":"00:17:88:01:00:f8:07:03-0b", "swversion": "66010820", "pointsymbol": { "1":"0a00f1f01f1f1001f1ff100000000001f2000000", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }},"4":{"state": {"on":true,"bri":240,"hue":15331,"sat":121,"xy":[0.4448,0.4066],"ct":343,"alert":"none","effect":"none","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "Keukentafel 2", "modelid": "LCT001","uniqueid":"00:17:88:01:00:bf:64:44-0b", "swversion": "66010820", "pointsymbol": { "1":"0a00f1f01f1f1001f1ff100000000001f2000000", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }},"5":{"state": {"on":true,"bri":240,"hue":15331,"sat":121,"xy":[0.4448,0.4066],"ct":343,"alert":"none","effect":"none","colormode":"hs","reachable":true}, "type": "Extended color light", "name": "Bank", "modelid": "LCT001","uniqueid":"00:17:88:01:00:e0:f9:3c-0b", "swversion": "66010820", "pointsymbol": { "1":"0a00f1f01f1f1001f1ff100000000001f2000000", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }},"6":{"state": {"on":true,"bri":254,"hue":8191,"sat":4,"xy":[0.4377,0.4047],"alert":"none","effect":"none","colormode":"xy","reachable":true}, "type": "Color light", "name": "Mediacenter 3", "modelid": "LST001","uniqueid":"00:17:88:01:00:cf:cf:c5-0b", "swversion": "66010400", "pointsymbol": { "1":"0a00f1f01f1f1001f1ff100000000001f2000000", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}},"groups":{"1":{"name":"Mediacenter","lights":["1","3","6"],"type":"LightGroup","action": {"on":true,"bri":254,"hue":8191,"sat":4,"xy":[0.4377,0.4047],"ct":343,"effect":"none","colormode":"xy"}},"2":{"name":"Keukentafel","lights":["2","4"],"type":"LightGroup","action": {"on":true,"bri":240,"hue":15331,"sat":121,"xy":[0.4448,0.4066],"ct":343,"effect":"none","colormode":"xy"}},"3":{"name":"Bank","lights":["5"],"type":"LightGroup","action": {"on":true,"bri":240,"hue":15331,"sat":121,"xy":[0.4448,0.4066],"ct":343,"effect":"none","colormode":"xy"}}},"config":{"name": "Notofyourinterest","zigbeechannel": 15,"mac": "00:17:88:14:e6:4c","dhcp": true,"ipaddress": "192.168.1.222","netmask": "255.255.255.0","gateway": "192.168.1.1","proxyaddress": "none","proxyport": 0,"UTC": "2014-10-30T11:33:28","localtime": "2014-10-30T12:33:28","timezone": "Europe/Amsterdam","whitelist":{"BAMY5yxBKD093YS":{"last use date": "2014-10-27T20:20:40","create date": "2014-01-07T16:08:34","name": "iPad"},"l9xpeyrma6oxmjpwigu40jhcgq":{"last use date": "2014-05-12T21:41:30","create date": "2014-01-07T18:01:38","name": "Oni Light Control for Windows Phone"},"c75656bf23ee2767e115c55e38bc9921":{"last use date": "2014-01-07T20:01:20","create date": "2014-01-07T19:58:46","name": "PC"},"0f510d002fe80a4391e3620f439167f1":{"last use date": "2014-01-09T21:12:43","create date": "2014-01-07T20:13:38","name": "xbmc-player"},"iuPpZOA6NccN2S4D":{"last use date": "2014-10-29T19:11:39","create date": "2014-01-07T22:01:57","name": "Esther"},"0f607264fc6318a92b9e13c65db7cd3c":{"last use date": "2014-04-05T21:48:53","create date": "2014-01-07T22:05:09","name": "Esther"},"aNo4TTID2ZEdI5zE":{"last use date": "2014-10-02T15:03:19","create date": "2014-03-19T16:33:21","name": "iPad"},"162A38E99DE559441F99B6B97170E020":{"last use date": "2014-04-06T14:14:02","create date": "2014-04-06T10:33:08","name": "Philips hue"},"v6pbk2ou7ZiOShJy":{"last use date": "2014-09-21T18:16:02","create date": "2014-05-07T18:38:26","name": "philips.lighting.hue#iPhone etc. etc.
- gizmocuz
I get 6 lights with this, are you sure 'accept new hardware' is enabled in the application settings ?
globalassist
Damn. I feel dumb. You are right. My apologies!
simonrg
- Domoticz version: 3.8807
Using the new functionality of otherdevices_svalues for the Hue lightsgizmocuz wrote:In the next beta you have the sat;hue in the sValue
Unfortunately, the sat;hue returned by otherdevices_svalues are just the last values sent from Domoticz and are not the current colour of the lights.
Of course this is obvious when I think about it,
So a direct query of the Philips Hue bridge from Lua will still be the best way to get the true colour values to both capture different states of the lights as set by other apps, but also to check that the lights were actually displaying the expected colours.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
- gizmocuz
When you change the hue of a light, wait at least 10 seconds, then check the svalue in the database, it should be there (see the code)
simonrg
The svalues don't seem to change (v2.2095), I have had a look at the code, but afraid my C++ is not up to understand the abstraction.gizmocuz wrote:When you change the hue of a light, wait at least 10 seconds, then check the svalue in the database, it should be there (see the code)
I have a very simple script:
print('Hue Lamp 1 '..tostring(otherdevices_svalues['Hue Lamp 1']))
print('Hue Lamp 2 '..otherdevices_svalues['Hue Lamp 2'])
print('Hue Lamp 3 '..otherdevices_svalues['Hue Lamp 3'])
Fri Oct 31 08:38:18 2014 LUA: Hue Lamp 1 209;13198
Fri Oct 31 08:38:18 2014 LUA: Hue Lamp 2 209;13198
Fri Oct 31 08:38:18 2014 LUA: Hue Lamp 3 209;13198
Fri Oct 31 08:38:18 2014 Script event triggered: /home/pi/domoticz/scripts/lua/script_device_hue_test.lua
Fri Oct 31 08:38:31 2014 LUA: Hue Lamp 1 209;13198
Fri Oct 31 08:38:31 2014 LUA: Hue Lamp 2 209;13198
Fri Oct 31 08:38:31 2014 LUA: Hue Lamp 3 209;13198
Fri Oct 31 08:38:31 2014 Script event triggered: /home/pi/domoticz/scripts/lua/script_device_hue_test.lua
Fri Oct 31 08:38:55 2014 LUA: Hue Lamp 1 209;13198
Fri Oct 31 08:38:55 2014 LUA: Hue Lamp 2 209;13198
Fri Oct 31 08:38:55 2014 LUA: Hue Lamp 3 209;13198
Fri Oct 31 08:38:55 2014 Script event triggered: /home/pi/domoticz/scripts/lua/script_device_hue_test.lua
Fri Oct 31 08:39:04 2014 LUA: Hue Lamp 1 209;13198
Fri Oct 31 08:39:04 2014 LUA: Hue Lamp 2 209;13198
Fri Oct 31 08:39:04 2014 LUA: Hue Lamp 3 209;13198
Fri Oct 31 08:39:04 2014 Script event triggered: /home/pi/domoticz/scripts/lua/script_device_hue_test.lua
Fri Oct 31 08:39:07 2014 LUA: Hue Lamp 1 209;13198
Fri Oct 31 08:39:07 2014 LUA: Hue Lamp 2 209;13198
Fri Oct 31 08:39:07 2014 LUA: Hue Lamp 3 209;13198
Fri Oct 31 08:39:07 2014 Script event triggered: /home/pi/domoticz/scripts/lua/script_device_hue_test.lua
Fri Oct 31 08:39:18 2014 LUA: Hue Lamp 1 209;13198
Fri Oct 31 08:39:18 2014 LUA: Hue Lamp 2 209;13198
Fri Oct 31 08:39:18 2014 LUA: Hue Lamp 3 209;13198
Fri Oct 31 08:39:18 2014 Script event triggered: /home/pi/domoticz/scripts/lua/script_device_hue_test.lua
Fri Oct 31 08:39:31 2014 LUA: Hue Lamp 1 209;13198
Fri Oct 31 08:39:31 2014 LUA: Hue Lamp 2 209;13198
Fri Oct 31 08:39:31 2014 LUA: Hue Lamp 3 209;13198
Fri Oct 31 08:39:31 2014 LUA: Air Quality 0Code: Select all
{"1":{"state": {"on":true,"bri":249,"hue":174,"sat":250,"xy":[0.6686,0.3242],"ct":500,"alert":"none","effect":"none","colormode":"xy","reachable":true}, "type": "Extended color light", "name": "Hue Lamp 1", "modelid": "LCT001", "swversion": "65003148", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }},"2":{"state": {"on":true,"bri":251,"hue":65527,"sat":253,"xy":[0.6736,0.3221],"ct":500,"alert":"none","effect":"none","colormode":"xy","reachable":true}, "type": "Extended color light", "name": "Hue Lamp 2", "modelid": "LCT001", "swversion": "65003148", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }},"3":{"state": {"on":true,"bri":124,"hue":58085,"sat":253,"xy":[0.4693,0.2087],"ct":385,"alert":"none","effect":"none","colormode":"xy","reachable":true}, "type": "Extended color light", "name": "Hue Lamp 3", "modelid": "LCT001", "swversion": "65003148", "pointsymbol": { "1":"none", "2":"none", "3":"none", "4":"none", "5":"none", "6":"none", "7":"none", "8":"none" }}}Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
mvdarend
Thanks for adding Hue support. I've just downloaded Domoticz to try it out, and all works well, great
One thing I'm missing though is the 'transitiontime' argument, is there a way to accomplish this (via the interface of LUA)? As it's my first day working with Domoticz I'm very unfamiliar with the system.
The reason I want this is for a wake up light, and soft transitions from one scene to another.
Thanks in advance for any help.
- gizmocuz
No this is not supported, but with a bit of work, you can make this work....mvdarend wrote:Thanks for adding Hue support. I've just downloaded Domoticz to try it out, and all works well, great
You have to add timers, for example each minute further more brightness
Is this transition time possible via the API ?
