- gizmocuz
Re: Domoticz app 2.0
The authentication method currently being used is available since years, for sure in recent stable versions.
There is no need to update to 2020.2 is you do not want to, all you have to do is make sure in your settings that the Normal Login page is used.
Basic Authentication will be removed soon and that is why application developers switching to this method.
We are working on OAuth authentication
- galadril
- Domoticz version: latest
Im pushing a new version as we speak.. maybe it fixes some issues that you had.
- jvdz
- Domoticz version: 4.107
Fully understandable, but one could imagine that http with port 8080 remains supported without any authentication for backwards compatibility.gizmocuz wrote: Thursday 07 May 2020 7:20 Basic Authentication will be removed soon and that is why application developers switching to this method.
I am happily running 3.78 with an reasonable sized zwave network, and haven't had the need to upgrade for functionality, and since there have been quite some zwave related issues reported in the releases since then, also haven't felt the urge to dive in the deep.
So some simple form of backwards compatibility as suggested would be welcome.
Jos
- galadril
I think this should be fixed in the new Android app thats coming in the store any moment.... LET ME KNOW pleasejvdz wrote: Thursday 07 May 2020 9:21 Fully understandable, but one could imagine that http with port 8080 remains supported without any authentication for backwards compatibility.
videodrome
The new app's version (0.2.213) doesn't work. I have domoticz 10717. I hope this issue will be fixed soon.
Snowtiger
- Domoticz version: 4.10915
In Domoticz - goto Settings - Website authentication - supply username and password and Authentication to Login Page, this should work, I am on a Beta between 4.10717 and 2020 and works like a charmevideodrome wrote:The new app's version (0.2.213) doesn't work. I have domoticz 10717. I hope this issue will be fixed soon.
- galadril
@Snowtiger, thanks for the assistance!Snowtiger wrote: Thursday 07 May 2020 11:03In Domoticz - goto Settings - Website authentication - supply username and password and Authentication to Login Page, this should work, I am on a Beta between 4.10717 and 2020 and works like a charmevideodrome wrote:The new app's version (0.2.213) doesn't work. I have domoticz 10717. I hope this issue will be fixed soon.
btw 0.2.214 is coming any moment in the app store.. that solves some little issues
videodrome
It doesn't even work that waySnowtiger wrote: Thursday 07 May 2020 11:03In Domoticz - goto Settings - Website authentication - supply username and password and Authentication to Login Page, this should work, I am on a Beta between 4.10717 and 2020 and works like a charmevideodrome wrote:The new app's version (0.2.213) doesn't work. I have domoticz 10717. I hope this issue will be fixed soon.
gdmr
same here. "timeout or no connection
handshake failed"
on android app version 0.2.213
pi Version: 2020.1
handshake failed"
pi Version: 2020.1
- galadril
It looks like 0.2.214 is available in the play store
Darsh
- Domoticz version: 2022.1
Domoticz 4.10726, app 0.2.214 (7369), Authentication: Login Page.
Three mobile phones cannot connect. Was working fine before the upgrade to 0.2.213/214.
App error: "OOPS! Something went wrong. Server error."
Server doesn't have any entries in the log (was logging incoming connections before 0.2.213/0.2.214).
Darsh
Darsh
- galadril
Authentication Login Page + a Username and Password set??Darsh wrote: Thursday 07 May 2020 13:33 Domoticz 4.10726, app 0.2.214 (7369), Authentication: Login Page.
Can you try to update Domoticz?
Darsh
Yes.
It was all working before 0.2.213/214 app version. Domoticz itself is still working stable, it is accessible via the web using a browser, and also from Garmin watch using Garmoticz widget. It is only the app access to it that is broken. I wasn't planning to upgrade Domoticz, to be honest. I will only do it if this is absolutely necessary. At the moment this looks like an app issue, not the Domoticz one.
Darsh
- jvdz
Thanks for the update @galadril!galadril wrote: Thursday 07 May 2020 10:13I think this should be fixed in the new Android app thats coming in the store any moment.... LET ME KNOW pleasejvdz wrote: Thursday 07 May 2020 9:21 Fully understandable, but one could imagine that http with port 8080 remains supported without any authentication for backwards compatibility.![]()
It didn't work at first as it seems it is still trying to open /logincheck first, and since that call fails in my ancient setup, it still failed, so I simply created a empty file logincheck in directory \home\pi\domoticz\www which fixed that.
Tested this work-around on v3.8793 and v4.1062.
Jos
Darsh
Tried that - still doesn't work, but this changes the error message in the app to "Invalid credentials. IMPORTANT: Please check if your Domoticz system uses Login Page as the authentication method. Basic Auth is going to be removed from Domoticz from the next update!"jvdz wrote: Thursday 07 May 2020 14:01I simply created a empty file logincheck in directory \home\pi\domoticz\www which fixed that.![]()
Darsh
- galadril
Ok good to know @jvdz..
The best way is to update Domoticz and set the authorisation on Login Page and with a username and password.
If you still have issues after installing the mobile 0.2.214 update, and you don't like to update Domoticz,
Simply created a empty file logincheck in directory \home\pi\domoticz\www which fixed that.
- galadril
Can you send my your home details, and create a test user for me on your system so i could debug?Darsh wrote: Thursday 07 May 2020 14:17Tried that - still doesn't work, but this changes the error message in the app to "Invalid credentialstials. IMPORTANT: Please check if your Domoticz system uses Login Page as the authentication method. Basic Auth is going to be removed from Domoticz from the next update!"jvdz wrote: Thursday 07 May 2020 14:01I simply created a empty file logincheck in directory \home\pi\domoticz\www which fixed that.![]()
Darsh
if so, please PM me the details
- jvdz
Prerequisites for this workaround:Darsh wrote: Thursday 07 May 2020 14:17Tried that - still doesn't work, but this changes the error message in the app to "Invalid credentialstials. IMPORTANT: Please check if your Domoticz system uses Login Page as the authentication method. Basic Auth is going to be removed from Domoticz from the next update!"jvdz wrote: Thursday 07 May 2020 14:01I simply created a empty file logincheck in directory \home\pi\domoticz\www which fixed that.![]()
1. Make sure the LAN IP range is defined in the LocalNetwork in the Domoticz setup: Something like: 127.0.0.1;192.168.0.*
2. In the APP setup you simply use the Local IP with the HTTP port (8080) and leave the Userid and password fields empty.
3. Create the aforementioned file in your domoticz setup
..... and you should be back in business.
Jos
Darsh
I confirm the app starts to connect with these prerequisites.
Galadril, I'll create a username for you shortly and PM it to you.
Darsh
- galadril
I've created a new version after testing with Darsh > 0.2.215
Should come within 2 hours on your phone
